Like Tree4Likes
Old 10-22-2014, 03:19 PM   #7321
handyman77's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Casper View Post
The rear pinon bearings can last months or they can go out in days. This is one of the harder areas of this truck on bearings.
I hear you. ..ok I will double check.
handyman77 is offline   Reply With Quote
Old 10-22-2014, 03:25 PM   #7322
rcus3r's Avatar
Originally Posted by tupapi77 View Post
... I replaced the system for a hobbywing and still doing the same.
Hobbywing SCT Pro is pretty bad at this setting. In my case, having LVC set to anything above 3V per cell would shut down in less than 5 minutes. I set it to 2.8V per cell, and now I can do 10-12 min without a problem.
Try that, but make sure you check your battery. If you set it to 2.8V per cell, check your voltage. Try not to go bellow 3.4-3.5V per cell by the time the car shuts down.
rcus3r is offline   Reply With Quote
Old 10-22-2014, 03:30 PM   #7323
handyman77's Avatar
That makes me a little nervous. ...don't want to ruin my battery but thanks for the suggestion.
Old 10-22-2014, 07:38 PM   #7324
Razorbelly's Avatar
Yes with the HW SCT Pro you will need to lower the LVC to 2.6v to get the run time out of your battery. For some reason with the HW ESC alot of us run it with a low LVC setting. Just time ur runs and check how low the battery goes down each time.I can get 13mins from a 7200mah with a HW 4700/13T on a huge track if need to. Gearing can help too. You said 14T on motor. but what motor? HW 4700=12-13T. HW 4000 =14-15T would be a good start. Also, most run lowest punch and lowest timing.
Razorbelly is offline   Reply With Quote
Old 10-22-2014, 08:00 PM   #7325
hkrob's Avatar
Trader Rating: 18 (100%+)
Use to have the same problem with run times. The sct-pro is a good esc but the LVC needs to be set at 2.6-2.8 to get proper run times with these trucks. I am running the same truck motor and esc as you and have had no issues with running LVC at 2.6 if your worried about hurting your battery run an old one with the lower LVC and see if it solves your problems.
hkrob is offline   Reply With Quote
Old 10-22-2014, 08:24 PM   #7326
handyman77's Avatar
I run the 4700 motor with a 14t...I will lower my LVC and see what happen
thanks
Old 10-22-2014, 08:26 PM   #7327
handyman77's Avatar
I will give it a try while I wait for my new battery.
thanks.
Old 10-22-2014, 08:56 PM   #7328
Razorbelly's Avatar
thanks
___________________________________
Switch to a 13T and you'll be surprised how much more running time you will have.
Old 10-22-2014, 09:02 PM   #7329
Default clarifications appreciated
This is the latest std setup
http://www.casper-rc.com/images/TEN_...r%20091014.pdf
The sugar setup is for sugar tracks or VERY high bite clay.
Use the droop screws in the rear arms to shorten the shocks.
Wider rear end is more stable.
Thanks for the clarification Casper
My track is incredibly tight with medium grip. Just trying to get a setup for this super tight turn turn turn nightmare track.
BTW:Can someone post a setup for carpet. There are none on the petitrc.com web site either.
Thanks again for the quick feedback Casper
braderb is offline   Reply With Quote
Old 10-23-2014, 03:01 PM   #7330
What's good set up for outdoors? 5-5-3?
RustyRC is offline   Reply With Quote
Old 10-24-2014, 08:30 AM   #7331
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up
I like 5/7/2 turns better and the back end is more stable
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 10-31-2014, 04:37 PM   #7332
handyman77's Avatar
Default solution
well ended up trying a 13T pinion and now I can run 12 min,
thanks for all the suggestions!
MBX7TR....O.S. SPEC 3 .NOVAROSSI PALOMA 7
MUGEN SCTE CONV. TEKIN 4600 HD HOBBYWING XR8
MBX7R..NOVAROSSI DRAKE MOTOR
HOT BODIES D413 LRP VECTOR 6.5T
LRHhobbies.com in placentia, CA.
Old 10-31-2014, 08:11 PM   #7333
Grigz's Avatar
Trader Rating: 16 (100%+)
Anyone know of the size of the grub screw for the sway bars? Some how lost mine and can't find a replacement for just the grub screw without buying the whole tuning kit? Suggestions?
Grigz is offline   Reply With Quote
Old 11-01-2014, 08:31 AM   #7334
Casper's Avatar
Trader Rating: 33 (100%+)
Should just be a short 4-40
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-01-2014, 08:49 AM   #7335
TLRacing
Frank Root's Avatar
It is a 5-40 x 1/8" set screw.
http://www.horizonhobby.com/5-40-x-1...rew-8-losa6297
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
