Like Tree4Likes
Old 10-19-2014, 09:26 AM   #7291
Probably a stupid question, but what kind of grease is everyone running for the ring and pinion? Im going through a truck I picked up and Im not sure what I should use. I tried the search function but probably didn't use the right set of keywords. It did show me that I have been building these diffs wrong lol. I have been using an automotive grease, sil-glyde, in my transmissions and gear boxes for years without any issues. It is a heavier, sticky grease and I haven't ever seen any heavy wear even with stupid power 1/8th scale e-power stuff. Im just curious if I shouldn't be using this for some reason.
mlemorie is offline   Reply With Quote
Old 10-19-2014, 09:29 AM   #7292
brian cox's Avatar
Trader Rating: 58 (100%+)
I highly recommend the casper-rc extreme grease, he makes great products!
Team Orion---Bradley Fine Line Design---AKA
brian cox is online now   Reply With Quote
Old 10-19-2014, 10:01 AM   #7293
luisv's Avatar
I've always used the Losi Black Grease:
http://www.tlracing.com/Products/Def...rodID=TLR77000
But this last build, I tried the Losi Great Grease:
http://www.tlracing.com/Products/Def...rodID=TLR77001
The great grease seems to stay put and not get thrown off and around the cover like the black grease does.
8ight TE 1.0 | MM2 2200kV | Spektrum
8ight TE 3.0 | MM2 2200kV | Savox | Spektrum
Ten-SCTE 2.0 | HW Pro SCT | Spektrum
luisv is offline   Reply With Quote
Old 10-19-2014, 11:18 AM   #7294
Thanks for the feedback. I'll be expanding my selection here soon.
Old 10-19-2014, 07:03 PM   #7295
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by bigemike View Post
I ran the dunford setup yeasterday at the ohio rc factory. The steering was good, but the traction rolling was a bit bad, I couldn't push the truck like I wanted to. The track is super high bite clay surface and we where running ghosted clay rattlers, almost bald clay typos and the traction was incredible. I went to a black front spring and orange rear spring with 5 wt heavier oil front and rear, and the truck felt better. The guys kept telling me I could lower the ride hieght but I was at 25.5 f and 25f and I was collecting alot of clay on the bottom of the chassis already. What else could I have done to limit the traction roll, so I could push the truck harder. I felt like tires helped, but I felt the problem was more in chassis setup than anything. I ran the complete dunford setup down to every detail and it felt super soft on the suspension too me right from the get go. Hopefully I will get another test day this week.
Hopefully your not running skid plates. If you are take those off bc 25.5 and 25 might actually be 28 28. Drop ride height down to 23 or 24. Drop your body post. I have my body posts all the way down. Try less droop about 2 mm less.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 10-19-2014, 08:45 PM   #7296
Casper's Avatar
Trader Rating: 34 (100%+)
http://casper-rc.com/images/TEN_SCTE...gar%202014.pdf
Did you try this one? Lower the car. Clay on the bottom of the chassis does not mean anything. The car will bottom out. This is not a bad thing. Lower the car a few mm. This should help.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-20-2014, 05:33 AM   #7297
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
No I tried the newer one, but that looks like the one I needed, is that one using the new alum front carriers? if not how should I adjust the droop accordingly?
on that note what does the new alum front carrier actually do? raise or lower the front steering block?
I am new to the truck, the second truck that I have I loaned to another local fast guy so we could have some competition and his was setup very close to the setup you posted.
Thanks for your help I really am digging the truck.
one last thing the 3 hole #56 piston, is that the stock 22 #56 piston? what is the hole size on those? is that like a 3 x 1.4 or something?
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 10-20-2014, 08:16 AM   #7298
maddog9's Avatar
the newest setup uses the 15 casters. If your using the stock plastic casters i would take the shock end and unscrew it two turns similar to the older setups
they raise the spindle itself and also increase the caster 5 degrees gives you more steering
They are the #3 pistons in the scte piston pack losb2909
I would definitely suggest the new caster blocks.
Old 10-20-2014, 08:56 AM   #7299
Braxamus's Avatar
prob. here somewhere but what is part number for the new front carriers? And next question is if it gives more steering on a stock 2.0 chassis is it safe to say it will do the same for my MIP chassis?
Braxamus is offline   Reply With Quote
Old 10-20-2014, 08:59 AM   #7300
maddog9's Avatar
TLR334017 is the part number and i would definitely give it a try. Worse comes to worse you have them for your future 2.0. I will be at Sparks Friday and Saturday if you guys need any help.
Old 10-20-2014, 09:39 AM   #7301
Braxamus's Avatar
Thanks for the part number, I checked A-Main and they are on back order. Im not sure when we will hit Sparks next, we are going to race all of the WRL at sparks but not going to the ones at the Factory. We do want to go to Sparks one time in between for practice so I'll have to get stuff I wanna switch ordered, and I'll let you know when we plan to be there next.
Old 10-20-2014, 10:45 AM   #7302
hkrob's Avatar
Trader Rating: 18 (100%+)
Ran the new setup yesterday on a tight indoor clay track med traction. Happy with the results truck begs to be driven hard did not have any traction roll issues at all. I am an aggressive driver and this new setup is perfect for guys like myself.
hkrob is offline   Reply With Quote
Old 10-21-2014, 05:25 AM   #7303
bigemike's Avatar
in the notes for the front suspension I see 0 insert front outer / inner is this referring to the plastic inserts that go into the alum arm holder?
Old 10-21-2014, 06:03 AM   #7304
maddog9's Avatar
Yes.
Old 10-21-2014, 10:35 PM   #7305
Regarding the new setup, Ryan Dunford's CCR Sugared2014. This is the latest right?
Is anyone having trouble with rear shock length ?
Im doing hole to hole, bottom turned in tight and I can't get below 102mm. Front is fine.
What purpose is the .5 rear hex?
braderb is offline   Reply With Quote
