Like Tree4Likes
Old 10-13-2014, 07:45 AM   #7261
Braxamus's Avatar
Maddog did you race at the WRL4.1 this weekend?
Braxamus is offline   Reply With Quote
Old 10-13-2014, 11:18 AM   #7262
maddog9's Avatar
Trader Rating: 29 (100%+)
No i was at a wedding. I will be at the rest of the races. My dad was there and finished 10th in the a main with my old 2.0 truck.
maddog9 is offline   Reply With Quote
Old 10-13-2014, 12:53 PM   #7263
Originally Posted by hacker07 View Post
I would still leave the inserts at 0/o in the front. The reality is we were trying to give you some of the great stuff we learned with the 3.0 8ight line with those new aluminum caster blocks. You get the 15 degree but you also get more steering throw and we moved the spindle up 2mm to give more on power steering. So, overall, you get more steering and more rear grip where its needed. They are pretty significant.
The biggest thing is you have to figure out the droop with the new setup if you are using the plastic caster blocks as the spindle isnt raised and since we use the shock to measure droop, droop with the same length shock with the 2 different caster blocks will be very different.
I raced this weekend with the new setup (kinda) I didn't have the 15deg front castor blocks or the rear .5mm hex's. and couldn't achieve the front shock length. but in reading this it makes sense. I guess until I get those parts i'll have to make my own hybrid setup I guess .
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 10-13-2014, 01:23 PM   #7264
jmcelroy42's Avatar
I also switched from the "latest Dunford" setup to the Dunford OCRC setup this past weekend, Minus the alum hubs and I didn't have a chance to redo my diffs. but it made a huge difference. had a lot more traction overall and steering. my biggest problem is if I'm not super smooth with throttle application coming out of a corner I get snap oversteer. my diffs are 5-7-2, will changing them to the 7-7-5 help? or do I just need to learn to be smoother getting back on power?
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 10-13-2014, 01:48 PM   #7265
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
I was at the WRL 4.1 it was a well ran program, you guys will have some new SCTE blood at the next one
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 10-14-2014, 12:38 PM   #7266
A setup is designed to all go together, so yes, in your case, the diffs would help immensely. The front caster blocks would surely help too as that helps with weight transfer as well. The sway bars are important as well.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 10-14-2014, 05:56 PM   #7267
bigemike's Avatar
do you have a link to get the rear sway bar or is there a known one that fits, I ordered TLR334001 it was listed earlier in the thread and Its for the 22sct so I know that is wrong. I found a 2.3mm 8ight front sway bar in my box but I need a rear 2.2mm
Old 10-14-2014, 06:15 PM   #7268
I orderd the swaybar kit for the Ten-T and it comes with a 2.2mm rear bar that's a direct fit.
Old 10-14-2014, 06:26 PM   #7269
Try Losb2222
Old 10-14-2014, 08:01 PM   #7270
What are the three sizes in Losb2222?
potatobed409 is offline   Reply With Quote
Old 10-14-2014, 08:59 PM   #7271
Grigz's Avatar
Trader Rating: 16 (100%+)
Having a really hard time with traction rolling. Can't attack corners very fast at all with out traction rolling. I understand Pro4s tend to roll more, but I feel like theres a lot more potential there just gotta get it tuned out. Any suggestions?
Grigz is offline   Reply With Quote
Old 10-15-2014, 02:31 AM   #7272
I believe they are 1.8, 2.0, and 2.2mm but I'll double check tomorrow .
TLR 22T 2.0
Old 10-15-2014, 05:47 AM   #7273
maddog9's Avatar
Lower your ride height. Lower your body. Try different tires.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
Old 10-16-2014, 08:11 AM   #7274
Try what Maddog said and also try stiffer sway bars front and rear.
-Ryan Dunford
Old 10-16-2014, 08:12 AM   #7275
These were originally designed for the TEN-T so I will be working on a stiffer bar set as well.
The front are 2.0, 1.8, 1.6
the rear are 2.2, 2.0, 1.8
-Ryan Dunford
