TLR TEN-SCTE 2.0 Kit Thread
#7186
ok sounds easy enough lol
#7187
Losi ten scte 2.0 build
Hello guys I am building the scte 2.0 kit and I am currently working on the differentials. There are 3 tubes of oil in the kit and I am not sure what to use where. I think the 27.5Wt goes in the shocks but where does the 5k and 3 k oils go? I searched the web and the manual and I cannot find anything on it. Please help.
Thanks,
Tom
Thanks,
Tom
#7188
Yes 27.5 in the shocks and 5000 in front diff/5000 in center diff and 3000wt in rear diff.
This might help with diff build and how to fill them properly,
http://www.youtube.com/watch?v=DbOfV5J5Z0k
#7189
Anyone have any tricks to rebuild shocks with out that special wrench with the holes to hold onto the shafts?
Trying to rebuild my SCTE shocks and put new pistons in and I can't I do the nut with out the shaft spinning. And I don't want to buy that specialized tool.
#7191
A piece of rubber like a bit bicycle inner tube wrapped round the shaft and gripped with some pliers is what I used to do
#7192
I am seeming to have issues with my center diff install. The motor mount wouldnt line up with the chassis whatsoever. Now that it is on with some brute force the spur gear seems pretty stiff. It doesnt rotate freely. Ideas? Is it normal?
#7193
No not normal. Sounds like the bearings need to be pressed onto the diff case further. Hold the diff case up to the light, there should be no gap between the bearing and the case. if there is you need to tap the bearing on further.
#7194
Thats what I thought. Bearings are almost like they are to small. Been smashing them almost just to get them on. Not to mention my hex tool just snapped off inside a screw going into the diff. What a fantastic way to start a build.
#7195
sorry about the frustration, lots of good build tips towards the beginning of this thread.
use these for your diff screws, slightly smaller diameter with a larger hex
http://www.amain.com/HPI-25x12mm-Fla...crew-10/p56197
use deep sockets to press the bearings onto the diff outdrives just make sure you are pressing on the inner race as much as you can
#7196
#7197
#7198
Ended up getting the hex head out of the screw that broke off. Stayed up from 11-5am finishing the build. I work probably a lot slower than most of you all. But good news is, it's done. Eager to get it out on the track now.
#7199
We didnt have these bend during our testing. Once they hit the public, a few bent due to some pretty hard crashes so we changed the material. The latest batch should not even come close to bending.
#7200
