Like Tree4Likes
Old 09-17-2014, 10:24 AM   #7171
tiago890's Avatar
Thank you, so by unscrewing the shock shaft 2 turns you are achieving droop, haven't raced off road in a few years so trying to get back into the grove, on-road we always used droop with the set screw so thought it would be similar but it's not. Thanks for the help
Sponsors: DaWife Racing and Team Myjob
tiago890 is offline   Reply With Quote
Old 09-17-2014, 10:39 AM   #7172
Originally Posted by xyzracer View Post
On another note, anyone know what size the pistons are that come in the scte shock rebuild packs? They are unmarked. Thx
The pistons that come in the shock rebuild kits do not mirror any of the marked and numbered aftermarket pistons. The SCTE 2.0 comes with 3/4 setup in the main bag and the rest in the option bag.
yes, that adjust shock length and in turn droop assuming you are not allowing the droop screw to hit the chassis after unscrewing the shocks.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-17-2014, 01:14 PM   #7173
Hacker07 I Bn running that new setup and its awsome . I running on a tight indoor med/high grip and I was wondering what changes I might make to improve it on the tight track? Maybe move rear hubs forward. It does everything great really balanced and easy to drive hard. Just trying to make it better for me. Thanks.awsome setup!
Wg931 is offline   Reply With Quote
Old 09-17-2014, 01:48 PM   #7174
Are you running the updated alum carriers up front? What is it you are trying to get more of out of the truck?
-Ryan Dunford
Old 09-17-2014, 04:42 PM   #7175
No I don't have them ,what is the part no?i would like a little more steering on a tricky off camber . Thanks
Old 09-18-2014, 09:53 AM   #7176
The part is TLR334017 and they will be in stock towards the end of the month.
-Ryan Dunford
Old 09-18-2014, 11:07 AM   #7177
xyzracer's Avatar
What mugen sway bar are u guys using to make the 2.3mm? Amain part number?
xyzracer is offline   Reply With Quote
Old 09-19-2014, 08:41 AM   #7178
I read issues about not jumping correctly. What caught my attention was Casper and Ryan’s comments about sway bar. Other than take it on and off, I did not know what or how to adjust it.
So,
I took off the front tires and shocks. I noticed when lift one side, both arms stayed up. Additionally, when I lift the drivers side, the passenger side rises only 50% verses the other way around lifting passenger side.
Also noticed the front sway bar touches the drive shaft but is not the cause of the above issue.
I decided to take off both camber links and everything works fine ?!?!!??!????
How do I fix this?
ALSO:
I wish TLR would do a youtube on sway bar and binding. What to looks for, how it should work and how to adjust and make things right
braderb is offline   Reply With Quote
Old 09-19-2014, 08:59 AM   #7179
Dan.J's Avatar
Trader Rating: 21 (100%+)
Waiting for these, thinking they will help my setup a bit.
Dan.J is offline   Reply With Quote
Old 09-19-2014, 06:55 PM   #7180
lowspark's Avatar
New set-up question.
You note the over-all shock length in the set-up sheet. Is this measured from the very top of the shock cap to the bottom of the lower eyelet? And it is adjusted by screwing the bottom eyelet on or off correct?
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 09-19-2014, 09:10 PM   #7181
Casper's Avatar
Trader Rating: 33 (100%+)
If you need to make the shocks longer you can unscrew the shock eyelet. If you need to make the shock shorter you can use the droop screws in the arms to limit the shock down travel.
Measure from center of the upper shock mount to the center of the lower shock screw.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-19-2014, 09:30 PM   #7182
lowspark's Avatar
Thanks Casper
I had figured it out and just used the droop adjustment to get the shock length measurement.
89.5 f / 98.5 r
I am looking forward to trying the new set-up. The last one has worked well but I always open to try to find the extra .5 second a lap. I am not one of the fast guys, but can run in the middle of the A consistently.
Local track is indoor, a moist clay. Running Panther Rattlers SS and a 15/39 gear. Mikes Hobby in Carrolton TX. 20 second lap times. Sadly it is closing at the end of the month. Good news, Mike is looking at a new location just down the road.
What is your thoughts on using this new set-up on a larger indoor track. They normally run it dry and it is like sand paper. Good traction in the groove, dusty on the edges, and it eats tires. We run Proline Blockade Soft. I run 16/40 on this track and run 32 second laps (a couple seconds a lap off the pace...)
Old 09-20-2014, 12:04 PM   #7183
in the new setup the OAL shock lengths was given do you put limiters in the shocks to reach the shock lengths given ?
thanks in advance Cory
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 09-20-2014, 02:26 PM   #7184
Found the problem
Bent 15Deg aluminum spindle carriers. Only 15 trips to the track
Too thin ?????
Old 09-20-2014, 02:50 PM   #7185
lowspark's Avatar
Dirt Racer, I used the droop screw adjustment to limit the shock travel.
TLR... the new set-up was on the mark today at the indoor clay track. Truck felt planted going into and going out of turns. Jumped fine and stayed on track under power. Put a big smile on my face... unfortunately did not correct my driver error mistakes during the main.
thanks for sharing... I am going to try it a the larger track next weekend
