Like Tree4Likes
Old 09-07-2014, 10:47 AM   #7126
anyone have a parts list to convert a 1.0 to a 2.0?
Team driver for Tekno
EB48.4, ET48.3 in the process of upgrading.....
TLRrunner is offline   Reply With Quote
Old 09-07-2014, 02:10 PM   #7127
Braxamus's Avatar
Thanks Matt I'll see what matches my track I race at and give them a try, I am new to the off road racing but been in RC oval racing a long time before this
Braxamus is offline   Reply With Quote
Old 09-07-2014, 02:26 PM   #7128
tiago890's Avatar
Hey guys, tried out the scte 2.0 for first time yesterday and truck was awesome with the exception of every jump I hit it kept nose diving, any tips on how to prevent this, thanks
Sponsors: DaWife Racing and Team Myjob
tiago890 is offline   Reply With Quote
Old 09-07-2014, 02:54 PM   #7129
Casper's Avatar
Trader Rating: 33 (100%+)
Stay on power when you jump and reduce drag brake if you have it.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-07-2014, 04:29 PM   #7130
tiago890's Avatar
Old 09-08-2014, 02:15 AM   #7131
Braxamus's Avatar
I noticed the same thing on mine, it was wanting to nose dive on every jump no matter how big or small it was. I run no drag break, but I did find if I would hit the throttle in air it did help a lot. I was jumping and just letting it do what it wanted to and not trying to control it in the air, I am switching from dirt oval where there are no jumps so I never though of it at first. got a learning curve in making the switch.
Old 09-08-2014, 03:43 AM   #7132
Errokk's Avatar
Chassis plate
Chassis braces
Side guards with the screws (they come separately)
Battery strap and mount
Servo mount
Thats pretty close to all you'll need, am I forgetting anything else guys?
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 09-08-2014, 04:29 AM   #7133
Hadz's Avatar
Here is a list of the parts I used to convert my SCTE1.0.
Battery Thumb Screws (2) TLR231003
Battery Stops w Posts (2) TLR231004
Servo Mount TLR231005
Chassis Battery Pads TLR231007
MIP Pro4mance Chassis Braces #13249
HA Chassis TLR231009
Mud Guard w Side Guard (2) TLR231000
Plus some extra screws:
5-40 x 1/2" FH Screws (10) - 4x Battery Tray Installation LOSA6271
4-40 Aluminum Mini-Nuts (10) - 4 x Side Bumper Installation LOSA6306
4-40 x 5/8" Button Head Screw (6) 4 x Front Body Mount Assembly, 4 x Body Mount Installation , 4 x Side Bumper Installation LOSA6283
Optional:
Body Mount Spacers (4) TLR231006
Carbon Front Tower SCTE 2.0 TLR234001
Carbon Rear Tower SCTE 2.0 TLR234002
Team Losi Racing Differential Top Plate w/Tunnel TLR231001
SCTE 2.0, RX8, T8 1850, Hitech HS-7955TG
Tekno EB48.4 Tekin 1950 / RX8 Gen2, Hitech 9370TH
Hadz is offline   Reply With Quote
Old 09-08-2014, 06:09 AM   #7134
thanks a lot everyone!
Old 09-08-2014, 08:37 AM   #7135
Casper's Avatar
Yes there is a lot to the art of jumping. Throttle gets nose up and brake brings the nose down. Wiggling the wheels will affect the roll of the car as well but that is more advanced. 4wd cars react to throttle inputs in the air much more than 2wd cars for obvious reasons but same principles apply. For guys coming from 2wd cars to 4wd cars due to how you have to take off from jumps they feel 4wd jump nose down and I suppose they do, but you just need to stay on throttle a little longer with a 4wd car.
Old 09-08-2014, 12:58 PM   #7136
Originally Posted by MIP MATT View Post
I'd definitely recommend the MIP aluminum Center Braces as the stock ones tend to wear out or bend/break. Also the diff kits are a help as they help the efficiency of the diffs with machined parts that don't break down after a couple runs. Keeps the oil clean and will probably last the life of the truck. Will need three kits to cover the car
http://miponline.com/store/mip13246.html
http://miponline.com/store/mip13249.html
Also Kings head center diff mount will help with keeping the center diff from binding up and give the outdrives more support with the double bearing feature.
Beyond that the Center puck system http://miponline.com/store/mip13120.html but something to upgrade once your current centers go out.
Best of luck.
Matt, I have no issues with you promoting the MIP products and they are great products. But saying the existing pins and shims "break down" in a couple of runs is a bit harsh dont you think?
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-09-2014, 04:32 PM   #7137
when changing the front diff housing do you just put the pinion gear thru the hole and let if float then put on the center cvd ? seems like there's a lot of back and forth play . or should I push the pinion thru holding it against the bearing then place the center shaft on the pinion then tighten it ??
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 09-09-2014, 07:07 PM   #7138
Casper's Avatar
Make it tight.
Old 09-10-2014, 01:37 AM   #7139
does that make it to far away from the ring gear ?
or did you mean to push the pinion gear into the ring gear then tighten ? sorry for the questions but the instructions are lacking bad in info....
TLR 22T 2.0
Old 09-10-2014, 04:06 AM   #7140
maddog9's Avatar
Trader Rating: 29 (100%+)
Tight meaning there is no play in the pinion. If you have it loose it will wear the driveshaft pin and possibly wear into the diff plastic.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
