Like Tree4Likes
Old 08-29-2014, 12:04 AM   #7096
.AJ.'s Avatar
Originally Posted by thebalance View Post
Hey Guys,
I'm having a weird problem with my truck. After about 5 minutes of the truck running great it cuts out and only has about a quarter throttle speed. I check it out and the low voltage red light blinks on the esc. I turn it off, try again and the same thing happens (runs for a while then cuts out). Temps are good on the motor and esc. Things I've tried: 1. Replaced motor and esc. 2. Changed receiver. 3. Tried all 5 of my 2 cell batteries and checked the voltage of batteries (still charged).
The only thing I haven't replaced electronically is the Servo. And the truck rolss freely with no binding. Any ideas?
I'm running a Reventon Pro 1.1 with 4.5t TrackStar motor. 4pl transmitter with futaba 3 ch receiver. I was running a Novak Ballistic 4.5t with Havok Esc. Thanks.
Turn off the Overheat protection on the ESC, it's a well know issue with some Reventon Pro ESC's, I ran one in a 2wd buggy last year and had exactly the same issue until someone at a local club explained the problem
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 08-29-2014, 01:14 AM   #7097
Brazman's Avatar
I also used the old 4mm bullet connectors from the esc to the battery. They are the kind that spin around. i wonder if maybe one of those is bad? I'll change them out tomorrow.
The batteries I have work fine in my Slash so I don't think it's a battery problem.
The bullet connectors will be your issue. You really need the solid ones for the amps that these things draw.
Brazman is offline   Reply With Quote
Old 08-29-2014, 04:23 AM   #7098
rcus3r's Avatar
I have seen a bad sensor wire do some weird stuff.
Hey Guys,
rcus3r is offline   Reply With Quote
Old 08-29-2014, 05:04 AM   #7099
egobrkr's Avatar
Trader Rating: 26 (100%+)
Hey Guys,
I had the same issue in my etruggy and it was my servo. I changed motor/esc, sensor wire and lipos. I then bought a new servo for it and to try but just wanted one that was better suited for the truggy and BAM! Problem fixed. I put all the old esc/motor and lipo back in and it was fine.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 08-29-2014, 08:02 AM   #7100
thebalance's Avatar
Thanks for the help guys. I'll try to change out the bullets first. If that doesn't work I'll replace the servo.
egobrkr, do you remember what servo caused this problem with you? After the motor cut did your servo still operate normally? Mine works fine after the low voltage cut.
Thanks.
thebalance is offline   Reply With Quote
Old 08-29-2014, 05:22 PM   #7101
how do you Turn off the Overheat protection on the sct pro
TheMuffinman is offline   Reply With Quote
Old 08-30-2014, 03:20 PM   #7102
Does anyone have the part no for the black fr and silver r springs used in the latest dunford setup? Thanks
Wg931 is offline   Reply With Quote
Old 08-30-2014, 03:33 PM   #7103
XXXDad's Avatar
Trader Rating: 195 (100%+)
Exclamation It's a pack you have to buy all to get one
Rearhttp://www.amain.com/Losi-Rear-Shock...-Set-8/p210184
Fronthttp://www.amain.com/Losi-Front-Shoc...-Set-8/p210185
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 08-30-2014, 03:44 PM   #7104
cttech455's Avatar
Plug the program box into the fan port. Just scroll through the list of different things you can set by pressing the item button. When you come to the one for the overheat protection press the value button to turn it off. I've had mine off for well over a year.
cttech455 is offline   Reply With Quote
Old 09-03-2014, 02:19 PM   #7105
Errokk's Avatar
Does anyone have a part number for the center diff cup half of the diff by chance? Can't seem to find it anywhere. Thanks.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 09-03-2014, 03:19 PM   #7106
I'm pretty sure that all the diffs are the same you just either put the ring gear on or the spur gear for the center diff.
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 09-03-2014, 04:46 PM   #7107
Errokk's Avatar
Thanks, I'll give it a closer look when I get her torn apart.
Garage:
Old 09-03-2014, 05:12 PM   #7108
Fabulous's Avatar
Trader Rating: 42 (100%+)
TLR332001
http://www.amain.com/Team-Losi-Racin...Insert/p248205
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 09-03-2014, 05:26 PM   #7109
Fabulous's Avatar
TLR SCTE 2.0B edition...
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Old 09-03-2014, 11:02 PM   #7110
xyzracer's Avatar
looks like your side guards are on the wrong sides
xyzracer is offline   Reply With Quote
