Like Tree4Likes
Old 08-18-2014, 07:11 AM   #7051
.AJ.'s Avatar
Haha, you should come to the UK, our dirt tracks are like that 75% of the year, that's why I stick to Astro tracks
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 08-18-2014, 12:27 PM   #7052
Default rear ring and pinion
installed a new ring and pinion in the rear.
had a broken tooth on the ring.
after assembly and before connecting to center with drive shaft.
rotate wheels forward nice.
rotate wheels backwards pinion goes in and binds up.
read directions (not much to read looked at pics).
am I missing something does something need to be shimmed.
if I rotate the wheels forward while installing the drive shaft.
the shaft can take the play out is this the correct way to do this.
or am I missing something.
Mike
68sportcoup is offline   Reply With Quote
Old 08-18-2014, 12:38 PM   #7053
kingofcool999's Avatar
Mike
Shouldn't have to shim it... I usually put the pinion in the case/bearing and then put the drive cup on the pinion shaft before putting the diff and other half of the case together. Takes all the play out and keeps it running free.
*** THIS SPACE UNINTENTIONALLY LEFT BLANK ***
kingofcool999 is offline   Reply With Quote
Old 08-19-2014, 11:11 AM   #7054
.AJ.'s Avatar
A bit of feedback on the pucks.....
After a weekend of heavy running there is zero sign of wear of the pucks
I done around 12-15 7min runs over the weekend and lubed the pucks with 15k diff oil and only re-oiled them once over the weekend
Spektrum DX4R Pro
Old 08-19-2014, 05:54 PM   #7055
cttech455's Avatar
With the 15 degree caster blocks (TLR334017) it says to unscrew the shock end two additional turns from where I am now. So if I'm already unthreading the shock end two turns I would now unthread them four turns? (not the math lol I just wanted to know if
the shock end would still be secure on the shaft; not pull out in a crash or if I should compensate for some of the ride height difference with the new carriers by adjusting the shock collars in this case?
cttech455 is offline   Reply With Quote
Old 08-19-2014, 05:58 PM   #7056
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Why do you have to lube the pucks?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 08-19-2014, 06:51 PM   #7057
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I think you got it right. If you are worried about ripping the eyelet off the shock, run droop screws down so they just touch the chassis at the full droop. Not a perfect solution but it might save you a DNF.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-19-2014, 07:19 PM   #7058
cttech455's Avatar
Thanks. I think it will hold together in a crash. I don't have the tabs for the droop screws to rest on on the chassis I run (MIP) so the eyelet will have to take the abuse on its own.
Old 08-20-2014, 03:04 AM   #7059
.AJ.'s Avatar
Makes them run even smoother and last longer
Spektrum DX4R Pro
Old 08-20-2014, 11:32 AM   #7060
You should be fine, I run mine that way and haven't had any issues.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 08-20-2014, 11:57 AM   #7061
cttech455's Avatar
Thanks for the help Ryan
Old 08-23-2014, 05:41 AM   #7062
Hello everyone,...
I am very new to the 1:10 Losi szene. I have a fully modded 1:5 Losi and as my son is getting very interested into RC i bought him ( me ) a TEN-SCTE 2.0 Kit.
Now I relly would like your thoughts on what engine and controller you would go for and what tuning parts.
My idea was to get a:
Vortex VST SC 550 PRO 4.0 with Vortex R10 Pro Controller
Savox 1258TG Servo
Thank you for your ideas and help - and greetings from Germany
FabsSpeed
FabsSpeed is offline   Reply With Quote
Old 08-23-2014, 06:23 AM   #7063
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Originally Posted by Braxamus View Post
WOW and WOW I would not have even considered putting my truck onto any track that I would have even thought would do that to it. That is crazy.
Originally Posted by kingofcool999 View Post
Mud... Hate when that happens...
Isn't this off road? sad to see what off road racing is becoming now in RC.
Losi 5ive T: Bartolone XP Pipe- Zenoah - Turlte Racing - Savox -Team Hoonage
SCTE 2.O BCE H1 HW SCT Pro/HW 4000/Savox
Feint Motion is offline   Reply With Quote
Old 08-23-2014, 09:28 AM   #7064
Integra's Avatar
Originally Posted by FabsSpeed View Post
Hello everyone,...
Savox 1258TG Servo
FabsSpeed
Im personally a tekin guy and cant suggest it enough. Tekin RX8 and your choice of Pro4 and your boy will be FLYING around the track. Servo is still your choice but Im not a fan of Savox, Hitec or Futaba or even the new lineup of Protek's are proving very nice.
Old 08-23-2014, 11:08 AM   #7065
Thank you very much. What Pro4 would you recomend ?
