Like Tree4Likes
Old 05-29-2014, 12:30 PM   #6796
bmitch282's Avatar
Originally Posted by LosiRacer33 View Post
Use a small drill the size of the bolt and drill into the stripped head. Once you drill enough the head will actually fall off. Leaving the stud. When you get the top plate off the diff case, you'll see a small piece of the stud sticking out. Grab that stud sticking out with a pair of pliers and turn it out.
Thanks!
LOSI TEN-SCTE (1.0) w/ Jammin lightened chassis - Mamba SCT Race Pro 3800kv
Wish list: MIP Pro4mance + Pro8 to make an e buggy
bmitch282 is offline   Reply With Quote
Old 05-29-2014, 05:07 PM   #6797
bmitch282's Avatar
Last noob question! Promise! can't remember if there are any special protocol for a new lipo's first run...??
Old 05-30-2014, 09:32 AM   #6798
Nope, charge and run.
potatobed409 is offline   Reply With Quote
Old 05-30-2014, 01:27 PM   #6799
ridered4life250's Avatar
Ok so I was curious if Anyone might be able to help me out with a few issues. I FINALLLY got a chance to run my new SCTE at OCRC the other day and I have and few questions I need help with.
1. My shocks leak like a motha-fu****. I have been building shocks for years so I know I built them right. I think the single seal is the culprit. Do any of you run an aftermarket/ different brand seal that seals tighter? For example. In my sc10.2, I use HPI shocks seals because they are .2mm smaller I.d. This grips the shaft a little better and prevents leaking.
2. I can't seem to get the truck to turn very tightly. I am running 7-5-3 on a large indoor clay track. I was thinking of going to 5k up front. Anyone else run at OCRC or SDRC ? What weight diff oil are you using up front?
ridered4life250 is offline   Reply With Quote
Old 05-30-2014, 02:09 PM   #6800
hkrob's Avatar
Trader Rating: 18 (100%+)
You running dunfords set up?
hkrob is offline   Reply With Quote
Old 05-30-2014, 02:30 PM   #6801
Casper's Avatar
Trader Rating: 34 (100%+)
Run the latest dunford setup.
http://www.casper-rc.com/TLR_Ten-SCTE.htm
These shocks don't leak. There is something wrong here. Even with the one seal they don't leak. I have never had an issue with one and we have been running this truck for over 3 years now and I hardly ever service the shocks and maybe replace the o-rings once a year (I know bad but I don't feel the need to).
Both Ryan and I will be at OCRC tonight if you can make it out we would be happy to help you with your truck.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-30-2014, 02:39 PM   #6802
Ive never had the shocks leak on the 2.0. I bought the kit as soon as it came out.
Old 05-30-2014, 04:17 PM   #6803
maddog9's Avatar
Trader Rating: 29 (100%+)
I think your issue might be the bottom cap isn't screwed on all the way. If you have the ones that are too small you will have to use vice scripts to screw them until they meet the bottom of the shock body.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 05-31-2014, 09:08 AM   #6804
SoCalMX's Avatar
I have had one lower cup back out causing a leak but other than that like Casper said, these shocks don't leak. Maddog9, the plastic shock tools are cheap, I would never use a vice grip on these. I also Run OCRC and run the Dunford setup.
Losi 5ive-T monster
Kyosho RB6 mid...
Kyosho SC6 mid...
Kyosho RT6 mid...
SoCalMX is offline   Reply With Quote
Old 05-31-2014, 05:38 PM   #6805
bmitch282's Avatar
Ran the car for the first time in a while @ Mikes Hobby Shop (Porter, tx) and was wondering if there's anything I can do diff-wise or suspension-wise to fight it's nose-dive tendency on both the large and small jumps.. I could make due everywhere but the big kicker double with a low landing.. Diffs are at 5-7-5 per phend's e Nats winning setup.
Old 05-31-2014, 06:40 PM   #6806
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Its probably not the diffs. If anything it's your shock package...maybe anti-squat. What are you running? Also, stay on the throttle in the air. You can't let off completely with these things in the air. The drive train spools down and pulls the front end down hard, even with little to no drag brake.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-31-2014, 07:08 PM   #6807
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
buy the rear spring package, that'll alter how it jumps.
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 05-31-2014, 08:48 PM   #6808
bmitch282's Avatar
Shocks: stock losi 1.0s... 30 wt front and 27.5 rear. no clue what anti squat cuz idk how to adjust that... or what it does?? lol and ya im having to get used to the throttle again.. its just on that one jump even if I gunned it up the face and held full throttle I'd have to do it just right to keep it from nosing over.
Old 05-31-2014, 08:53 PM   #6809
bmitch282's Avatar
which rear spring package? MIP, losi?
Old 05-31-2014, 08:55 PM   #6810
hkrob's Avatar
You running a 1.0 or 2.0 if it's a 1.0 try the APE battery tray it helps place the battery further back. I used one on my 1.0 and it really help balance the truck out and cured my nose diving issues.
