TLR TEN-SCTE 2.0 Kit Thread
#6676
I have same Issue, running this truck a long time. Some days better than others, Check gear mesh, never run Drag brake. I started running softer shock oils and will try going back because the nosedive is back and when I go for big jumps the Hekno guys fly flat over. Mine dumps the nose it's the only problem I need to solve on this truck. I have to full throttle in the air. if I let off It lands nose first..... sigh.... i'm not novice
#6677
Uploaded my SCTE 2.0 high bite setup to www.casper-rc.com
Remember this is a HIGH BITE setup. We are talking about slicks on clay or blue groove/sugar tracks outdoor. Otherwise we are still running the latest dunford setup but using the new 15 deg caster blocks with that! (remember to adjust your droop with the caster blocks. The feedback so far has been very positive from what I have read!)
Also don't for get to try out the Casper-RC extreme grease for your CV joints and ring and pinion gears!
#6679
Anyone still having an issue with Nose Dive off jumps? I've tried a new motor, still happens. New softer rear springs, no change. This thing is almost un driveable. I can't find any evidence of drive train binding either. Checked gear mesh too, and that looks fine. I'm not a pro, but not a noobie either. Any help would be appreciated. SCTE 2.0 Tekin 4300HD RX8 Gen 2.
#6680
#6683
Thank you for all of the input. When I first built the truck, it was great. Somewhere along the way... I messed it up. Fail! I'm not running any drag brake. I'll have to check the pins, sway bars and shock mounts to make sure they are not too tight or binding. I don't think they are though as I'm constantly monitoring / cleaning them.
It doesn't happen on all jumps. Like XXXDad, it's just the big ones. Going over a single I'm able to nose down or nose up with the throttle. I can downside the small jumps every time. It's the big triples that get me. I stay hard on the throttle and if I come up short I'm nose dive smashing right into the upside of the jump. Lots of times I endo and do a front flip. This is killing the truck!
#6684
Does not sound like it is really an issue with the attitude more then actually clearing them jump? If you were to clear the jump would the truck be in position to land properly?
#6687
