Like Tree4Likes
Old 04-19-2014, 08:38 PM   #6556
rcgod's Avatar
Trader Rating: 27 (100%+)
Bone plunge is when the drive shaft moves into the out drive when the suspension is compressed.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-20-2014, 06:38 AM   #6557
SoCalMX's Avatar
Actually in my world bone plunge is when, awww forget it....
Losi 5ive-T monster
Kyosho RB6 mid...
Kyosho SC6 mid...
Kyosho RT6 mid...
SoCalMX is offline   Reply With Quote
Old 04-21-2014, 07:58 AM   #6558
I was about to order one of the drag link kits that has bearings, and ran into soemthing I want to try and understand. I saw that some folks are offering a short or long drag link kit. I am not sure whether stock would be considered short or long (but I would think long), but I wanted to make sure I understand this right. Is the long going to have more ackerman? That would only seam logical to me.
RMabus is offline   Reply With Quote
Old 04-21-2014, 02:03 PM   #6559
Trader Rating: 65 (100%+)
Stock was the long one on my rigs. Hope that helps. You will like the ball bearing ackerman. I prefer the short one for quicker steering, but depends on what you like. I used the long one 2 years before the swap to short.
Thunder Trail is offline   Reply With Quote
Old 04-21-2014, 11:49 PM   #6560
Guys, anybody running these?
MIP "Pucks" TLR TEN-SCTE 2.0 Center Drive System Pro4mance Pack
MIP13120
I'm running full Tekno shafts but these look good for the centre shafts, would like any feedback on them, are they much lighter?
Are they working well?
Worth the cash?
Cheers.
Losi SCTE #8NZ-2014 Tekin-savox-Tekno
S Workz 350BK1 electric converted Tekin-savox
ST RR Truggy #8NZ-2014 electric converted Tekin-savox
SC10 Tekin-savox
Baja 5B dirt mod-2015 Summer Slam Champion.
RossNZ is offline   Reply With Quote
Old 04-22-2014, 05:59 AM   #6561
MIP13120
Worth the cash?
Cheers.
Yes, I run this setup. It's buttery smooth and without slop. A bag of replacement puck is a few bucks, so don't worry if a puck eventually wears out. And as an FYI, I also run the KingHeadz center diff pieces as well, which is also buttery smooth. Not sure how light they are compared to Tekno shafts, or if they will make you faster, but I like them.
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 04-22-2014, 09:20 AM   #6562
rivalshad's Avatar
Trader Rating: 14 (100%+)
The puck center shafts are nice, I'm also running them with the king headz mounts and it makes for a super smooth drive train. Amain has them for $55 I think.
8ight E 3.0, SCTE 2.0, TLR 22-4, B5, RC8.2 FT, SC10B FT
60% of the time it works everytime
rivalshad is offline   Reply With Quote
Old 04-22-2014, 11:55 PM   #6563
Default MIP Pucks Last?
MIP13120
Worth the cash?
Cheers.
This is about as honest as I can be about it. I use the MIP Pucks. They are perfect for a track only rig if you only race, work on your car often and don't mind the extra maintenance. However, if you bash and don't like to work on your rig much, go tekno.
I'm torn myself. I only race and the plastic pucks and CV pins require maintenance long before the diffs need an oil change. The front drive cup shows a lot of wear after 40 runs and are trash if you ever let the plastic pucks wear out. The parts to keep it in top shape are not too high, but the extra work and parts increase operating cost. The Pucks System would be much better if the plastic pucks and CV pins lasted 50 to 70 lipos. Then I could replace them at the same time I do the diffs. Same for the drive cups. Looks like the front drive cup is done after 50 runs. The drive cups need to be a little stronger, harden in some way. The CVD pins need to be larger as well. The wt saved here is not the best tradeoff IMHO. I would prefer the parts weighed a little more and lasted a little longer. I think we need a MIP HD Puck System That's the ticket and you heard it here first!
Old 04-23-2014, 01:37 AM   #6564
Great info, just the kind of opinion l am looking for, l have the king heads motor mounts and run all tekno shafts, they are lasting great, been making the truck lighter and thought these would help, can't find any weight listed for them tho.
SC10 Tekin-savox
Old 04-23-2014, 04:49 AM   #6565
Send a message via AIM to zuki250
I also have the pucks...i ran 12-15 packs and the front distingrated and ruined the drive cup...I emailed MIP about this and we are in talks right now...As much as i like them i am taking them out and putting my tekno shafts back in...really dissapointed in them
zuki250 is offline   Reply With Quote
Old 04-23-2014, 09:53 AM   #6566
rcgod's Avatar
I personally wouldn't run the pucks without the kh mounts. The center diff outdrives wobble too much without them and cause the pucks to wear fast. I had almost zero wear with my pucks with kh mounts. Raced it probably 5 race days and sold it to a friend. He's still running it with the original pucks in it.
Dialed RC Hobbies
Old 04-23-2014, 10:09 AM   #6567
I have the mounts....and if he is still running the original pucks he isn't going fast enough
Old 04-23-2014, 10:19 AM   #6568
+1
potatobed409 is offline   Reply With Quote
Old 04-23-2014, 10:47 AM   #6569
rcgod's Avatar
Lol. Maybe. But if the pucks need to be replaced every month then I would be willing to deal with it considering how smooth and quiet they are. They can be replaced with the drive shafts on the truck. Now if they had to be replaced every race day or two like some guys have said then that would be different.
Dialed RC Hobbies
Old 04-23-2014, 11:04 AM   #6570
s.amadorJR's Avatar
wow that's crazy. I hope that doesn't happen to me..
I have ran 2 many packs to count on the MIP system and I think that was the best investment for the truck.
www.LAPartsHouse.com
https://www.facebook.com/LAPartsHouse
steven@losipartshouse.com
(714) 441-2274
s.amadorJR is offline   Reply With Quote
