Like Tree4Likes
Old 04-07-2014, 08:14 AM   #6496
Originally Posted by Casper View Post
Best team in the industry!
Glad to hear you are getting help and figuring it out.
I see what the fast guys are doing, but I just need more laps to try to duplicate it. When I go to the bigger races to watch, ALL of the TLR pros (all kids to me) are very, very helpful. That's why I sold all of my Tekno and Serpent stuff eight months ago and am now a TLR lifer! Great stuff, and even greater support!
Casper, you and Ryan have been very helpful as well--thanks!!!
BTW - Casper's grease is awesome!
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 04-07-2014, 08:53 AM   #6497
Casper's Avatar
Trader Rating: 33 (100%+)
Nice. Glad you like the grease. I have been extremely pleased with it as well!
Yeah pro-4 to a small extent slow if faster. Basically work on not pulling full throttle all the time on the infield. As I said before the these things have a ton of power and usually not enough traction so we tend to over drive them a lot. Some guys can run full punch and when you can fast lap times are possible but most of us (me included) have to drive a little smoother line. Watching top pro's (Cav, Maifield, Hartson, Evans, Phend) there cars are always in control and they are hitting there lines. My suggestion is to go slow enough to make sure you are hitting your lines. As you get comfortable going slow and hitting your lines then pick up the pace a little each lap. It is harder then it sounds as I am still learning patience when driving modified cars and I have been playing for 20 years!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-07-2014, 09:03 AM   #6498
Send a message via AIM to zuki250
Took the truck out yesterday for the first time on an outdoor track...running the dunford set up ...indoors the truck was money...It was great outdoors, but rotated a little to much...the track is loamy, but loose...i put on a thicker front bar and that helped...any other suggestions?
zuki250 is offline   Reply With Quote
Old 04-07-2014, 11:26 AM   #6499
Casper's Avatar
The original setup is a little more steering neutral and may be better on a looser track.
Old 04-07-2014, 01:39 PM   #6500
dtr
dtr's Avatar
Originally Posted by drepus View Post
Yes a 5-40 x 7/8" set screw is the correct length and if I remember correctly was the same size used in the 1.0. The one in my 2.0 is black if that helps.
Is it perhaps in another bag by mistake?
Thanks Dave, I'll postpone installing the servo till the end of the build and hope I'll find i in another bag. Buying standard hardware is not easy around here.
dtr is offline   Reply With Quote
Old 04-07-2014, 02:18 PM   #6501
Good time yesterday!
what are you running in your diffs?
68sportcoup is offline   Reply With Quote
Old 04-07-2014, 03:36 PM   #6502
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Does running no front sway give you more grip in the front and is better for indoor?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 04-07-2014, 04:43 PM   #6503
drepus's Avatar
If you don't find it in one of the other bags I have a few solutions to help you get out on track.
1 Check with your local shop if they can get the replacement sent to you from TLR.
2 If your local shop carries TLR they might have either a 5-40x7/8 screw you could cut the head off. Or if they stock TLR 1/8 parts you could use LOSA6045 which is the same size steering link and set screw from the 8ight series of vehicles.
3 I just checked and you could find a 3x22 set screw or cut down a 3mm bolt to 22mm long. I just tried installing a 3x8 screw into a new tie rod and could not pull it out with pliers so you should be fine using a 3mm screw. I would use some tire glue on the 3mm screw when you thread it into the tie rod.
Have fun with your new truck!
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 04-07-2014, 07:30 PM   #6504
We discovered this by accident when one of our guys had his become detached. It creates more body roll in front and it turns on a dime. We haven't tried it outdoors or in super loose conditions, but for indoors, its amazing. Crazy good steering, while still hooked up nice in the rear. Just detach it at the ball and try it, that way you can go back in 30 seconds if you don't like it.
Old 04-08-2014, 04:18 AM   #6505
Casper if i just swap the diff fluids to 5, 5, 3 instead of the 5, 7,5 would that slow the rear end from coming around...I love the way the truck is handling other than that
Old 04-08-2014, 04:28 AM   #6506
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I would drop to 3K in the rear on a loose track.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-08-2014, 04:37 AM   #6507
Leave the seven in the middle?
Old 04-08-2014, 04:40 AM   #6508
Moderator
bds81175's Avatar
The center diff mainly affects how the car accelerates. If it gets too low, you will rock back onto the back tires under power and balloon the fronts. 5K should be safe but I'm running 7K right now and it seems pretty solid front to rear.
Tekno RC
Old 04-08-2014, 04:27 PM   #6509
JEFFs SC10's Avatar
Thank you sir
XRAY 2017 T4
Xray X12-17' GT12
Old 04-08-2014, 08:55 PM   #6510
Default Need more steering
I'm using the latest Losi guys set up except 5-5-3 and all is great put push and can't turn out off corners. What can I do, I may be diving into deep.
Roken is offline   Reply With Quote
