Like Tree4Likes
Old 03-11-2014, 06:18 AM   #6361
Rxfisher's Avatar
Trader Rating: 18 (100%+)
Default MIP 41 tooth spur
I tried the MIP 41 tooth spur and it slightly rubs the chassis, I didn't notice on assembly, but must have contacted after final lock down. Really heated up my motor and esc, my bad. Anyone else have this issue ?
22 Losi Buggy, HPI BLitz, ECX Torment, Duratrax Element, ten-SCTE 2.0, tekin gen1, pro4 4600, losi 8ight 3.0, orion r8 pro
Rxfisher is offline   Reply With Quote
Old 03-11-2014, 06:50 AM   #6362
you need to run 1mm shims under the mounts to clear the spur. in one of the reviews i read it... i cant remember what they used for shims though.
TLR SCTE 3.0
TLR 22SCT 2.0
Powered by SMC and Tekin
JMURACN is offline   Reply With Quote
Old 03-11-2014, 07:40 AM   #6363
Rxfisher's Avatar
Default thanks
Ill try that, I've got some shims from my 22 buggy that might work. Thanks
Old 03-12-2014, 04:09 AM   #6364
banana rt's Avatar
i have a binding issues for front stabilizer link. it feels my front arms didnt move freely like my rear coz the stabilizer didnt fit right. it seems the front links too short, and reeaally close to the dogbones. is this normal? any tips for this issues?
No guts No glory
banana rt is offline   Reply With Quote
Old 03-12-2014, 05:22 AM   #6365
I'm guessing you mean sway bar? Don't push the sway bar in the mounts as deep as the rear. I sit the car flat on a table without wheels on then tighten sway bar mount when the mount is straight up and down.
potatobed409 is offline   Reply With Quote
Old 03-12-2014, 10:54 AM   #6366
Redwings's Avatar
Originally Posted by JMURACN View Post
you need to run 1 mm shims under the mounts to clear the spur. in one of the reviews i read it... i cant remember what they used for shims though.
I just added my MIP 41 tooth as well. I was told that it was to make it sound quieter but still sounds like a coffee grinder. I didn't check the clearance to the chassie but I'll add the shims as a precaution. Is this normal or will it get quieter down the road.
Redwings is offline   Reply With Quote
Old 03-12-2014, 11:06 AM   #6367
Redwings's Avatar
Originally Posted by Roken View Post
Who's using the diff oil combination of 5-7-5, how is it working?
I believe the stock set up is the same. I running that with no problems.
I have to say that I did not have any problems when I build my kit what so ever. I just noticed that the rear drive shaft has a slight bent in it after 6 runs on it. Is this usual?
Old 03-12-2014, 06:27 PM   #6368
Did you hit something hard? Check your hinge pins.
Roken is offline   Reply With Quote
Old 03-12-2014, 06:31 PM   #6369
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
It should be quiet right away. Noticeably quieter.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 03-16-2014, 07:15 AM   #6370
Trader Rating: 120 (100%+)
Just a few questions. I love the scte 2.0 and mine is all tricked out with all the best upgrades but I am not a big fan of the losi shocks. I have upgraded to the losi 3.0 buggy shocks but had to modify the front shock tower to make it work. Here are my questions.
1. Does anybody make a aftermarket front tower to let you run the losi 2.0 or 3.0 buggy shocks?
2. I know that proline has a nice set of shocks as well for the losi scte and just wanted to know if anyone is running them and if so what are your thoughts?
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 03-16-2014, 08:29 AM   #6371
Errokk's Avatar
I can tell you the proline shocks are not as good as the stock scte 2.0 shocks.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 03-16-2014, 02:17 PM   #6372
Hey guys I just got this truck. Was wondering what weight fluid everyone is running in shocks and diffs. I'm in st.louis area and run a tighter indoor track and 2 bigger outdoor tracks. Thanks
brawley25 is offline   Reply With Quote
Old 03-16-2014, 03:22 PM   #6373
joel804's Avatar
Trader Rating: 58 (100%+)
Hey guys that are running the Tekin pro4 hd 4300. What tooth pinion are you running?
LOSI 8IGHT T 2.0 E
RC8BE
TECHNO SCT410
LOSI LST2
joel804 is offline   Reply With Quote
Old 03-16-2014, 07:16 PM   #6374
JEFFs SC10's Avatar
Running 3.0 shocks wont get down to 24/25 mm ride height will it?
I run my truck on an 1/8 scale track and the shocks are just fine.
XRAY 2017 T4
Xray X12-17' GT12
Old 03-16-2014, 07:20 PM   #6375
ta_man's Avatar
Trader Rating: 151 (100%+)
Answers:
1) Yes, I have one, SNR GRaphite.
2) Proline shocks are not as good as the original SCTE shocks.
FYI: I have a 1.0 SCTE with King Heads chassis and Losi 8 shocks (with that shock tower) and a 2.0 with the stock shocks. I can't really say that the 8 shocks are much better.
ta_man is offline   Reply With Quote
