Like Tree4Likes
Old 03-04-2014, 05:57 PM   #6331
Errokk's Avatar
Originally Posted by drepus View Post
You don't have your steering modded to get a tighter turn do you?
Naa, it's all stock.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 03-04-2014, 08:32 PM   #6332
gotspeed24's Avatar
Trader Rating: 39 (100%+)
Originally Posted by tripleh View Post
I had the same problem.just build it and run it.it will break in.mine is smooth as butter after one night of racing.
ditto.....diffs rubbed the case....i had to file a little bit out to make them fit correctly. i was also frustrated by this at first, but i can tell you that after that it has been fine.....it is the best 4x4 SC ive ever driven
to me, the few small issues are just that....small...this truck RULEZ!
gotspeed24 is offline   Reply With Quote
Old 03-04-2014, 08:57 PM   #6333
ironzgti35's Avatar
Trader Rating: 20 (100%+)
I just broke one at the same spot at Motorama during the A main. Hit a pothole mid turn and just snapped. I have seen a couple break on high bite off road carpet but I've had my truck since it first released and had no issues as far as I can remember
ironzgti35 is offline   Reply With Quote
Old 03-05-2014, 02:39 PM   #6334
My son (aged 9) playing in the trees;
https://www.youtube.com/watch?v=Ja8MGt1RCvQ
Good job it's almost indestructible.
poolebay is offline   Reply With Quote
Old 03-05-2014, 07:48 PM   #6335
JKoiva's Avatar
Originally Posted by ses601 View Post
any thoughts on the m2c tapered pistons?
Going to test them out this weekend. We shall see, I know one guy who runs them and does very well with em ....
Tki3 , O.S.
D413
B5M
Futaba
JKoiva is offline   Reply With Quote
Old 03-05-2014, 09:05 PM   #6336
ta_man's Avatar
Trader Rating: 151 (100%+)
Originally Posted by Errokk View Post
The CVA its self is snapping off around the barrel and pin. I'm sure that its my fat finger causing the problem but just wanted to make sure that's all it was.
Does this only happen in the front, or in the rear too?
I had this happen on a front CVD and found that the crosspin slot was not machined all the way in the other one of the pair (that didn't break). I actually ended up with 4 pieces like that. I thought about taking pics to illustrate the problem and calling Losi to get replacements but in the end I just used the ones that weren't machined properly in the rear where it didn't make any difference.
ta_man is offline   Reply With Quote
Old 03-05-2014, 09:13 PM   #6337
nEoNidas's Avatar
Default A little clueless
Putting a rx8 gen 2 and a thunder power 4.5 550 in my 2.0. I remember reading some pages back that it was critical to adjust the timing with a 550 motor. Now I see the numbers on the back of the motor, I'm assuming to adjust the timing......could u guys please break down and give me an understanding of what timing actually is, and how I should be setting this set up, up. Critical did sound pretty important. Please advise.
"Been out the game for a few years, need a point in the right direction."
nEoNidas is offline   Reply With Quote
Old 03-06-2014, 03:31 AM   #6338
maddog9's Avatar
Trader Rating: 29 (100%+)
Tekin suggested profile 4 on the timing and zero on the can. Gearing should be a 13, if on a big track then 14.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 03-06-2014, 03:50 AM   #6339
Errokk's Avatar
Unfortunately, it's all the way around the truck. The last 2 that did break were front but im sure the rears are soon to follow. Think I'll leave the scte at home for this last weekend of felt racing and have a go at it once the dirt is in place and see what happens. I will also give her a good once over again before I lay this heavyweight finger back into her again lol!
Garage:
Old 03-06-2014, 07:59 AM   #6340
+1
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 03-06-2014, 10:29 AM   #6341
[QUOTE=hacker07;13064911]Ken, this play is normal and actually for most people will make the truck easier to drive. It is that way by design.
Thanks for the response. So how do you go about getting an accurate camber and toe in/out settings with the "play" ?
Ken
PYRO689 is offline   Reply With Quote
Old 03-06-2014, 11:04 AM   #6342
Casper's Avatar
Trader Rating: 34 (100%+)
Drop the truck and roll it forward a few inches and you can get some pretty accurate measurements.
Toe is kind of by eye always.
DE setup wheels make all this so much easier and more accurate.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-06-2014, 04:00 PM   #6343
nEoNidas's Avatar
Thumbs up
Thanks MadDog, looking forward to running this motor. Ran a pro 4 4600 before, looking forward for something new.
Old 03-06-2014, 04:27 PM   #6344
ses601's Avatar
awesome, looking forward to the results!!!
TLR SCTE 2.0
ses601 is offline   Reply With Quote
Old 03-06-2014, 06:35 PM   #6345
LosiRacer33's Avatar
First... love the SCTE 2.0. Been a great truck! I went to the JR Mitch setup last week. Changed the shock inserts from the stock from stock #6 to #54 and the rear from stock #7 to #55. I closed off two of the four holed on each of them.
Truck runs great around the track, but I'm getting a nose dive effect now. I can't keep the nose up in the air off the jumps unless i'm on the gas full throttle. I have 35wt in the front and 27.5 wt in the rear. Any thoughts on what else could have cause the back to kick up and the front to nose dive? Little help here.
www.gallimods.com
TLR SCTE 2.0, 22-4, 22 2.0
Tekin Motors and Speed, Orion Batteries
superty.org
LosiRacer33 is offline   Reply With Quote
