Like Tree4Likes
Old 02-26-2014, 04:38 AM   #6271
Errokk's Avatar
Originally Posted by JEFFs SC10 View Post
LOL I had a bearing give away too, it was spectacular.
I'd say that was a roast'em toast'em scenario!
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 02-26-2014, 06:35 AM   #6272
fredmotokx's Avatar
Originally Posted by banana rt View Post
yikes !
Those case and gears are thirst of grease. put some high pressure black grease on it.
They were allot high pressure black grease, the plastic dust got stuck in it.
TLR SCTE 2.0
Team associated B5
fredmotokx is offline   Reply With Quote
Old 02-26-2014, 07:50 AM   #6273
Mclogo's Avatar
I did just rebuild the 3 diffs and have replaced the screws with the HPI HPIZ449.
Thanks for recommending this, works perfectly.
The kit so far is really great and easy to rebuild... seems a lot of parts really fit better after it has been rebuild.
looking forward to the next race in 2 weeks
Yokomo B-Max4 III // B-Max2 MR
Yokomo YZ-2 << NOSRAM >>
Mclogo is offline   Reply With Quote
Old 02-26-2014, 11:02 AM   #6274
Default shock build help
Hi all,
Building the shocks for the first time and having a little issue. front shocks no issue, but when building back shocks after bleeding them I get very little rebound (shaft pushing out from shock) which is normal....but when I extend the shock shaft it sucks back up into shock almost all the way....I don't believe this is correct as the fronts did not do this.....
I have refilled and bled a few times with same results.....can someone chime in on what I could be doing wrong or explain the procedure for building the shocks?
Ken
PYRO689 is offline   Reply With Quote
Old 02-26-2014, 11:11 AM   #6275
LosiRacer33's Avatar
Anyone have issues with the original chassis on the 2.0? At first a few of the screws didn't fit all the way into the pre drilled holes, then the skid plates didn't exactly fit. I've done some mods but not my RPM bumper broke just infront of where it mounts to the chassis. There's a gap between the bumper mount and the frame because the countersink holes are too small. Thoughts? Is it just me?
www.gallimods.com
TLR SCTE 2.0, 22-4, 22 2.0
Tekin Motors and Speed, Orion Batteries
superty.org
LosiRacer33 is offline   Reply With Quote
Old 02-26-2014, 12:16 PM   #6276
fredmotokx's Avatar
Originally Posted by PYRO689 View Post
Hi all,
Ken
Try use TLR green slim on the o-ring, maybe will fix your issue.
TLR SCTE 2.0
Team associated B5
Old 02-26-2014, 02:44 PM   #6277
Casper's Avatar
Trader Rating: 33 (100%+)
You can slightly loosen your lower caps as well. Sometimes they can squeeze the o-rings depending on the stack up.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-26-2014, 05:55 PM   #6278
Hi all,
Ken
In regards to the O rings in the top cap
I was reading the build notes and it mentions you can you use either the ones that go up in the cap, or the ones that go on the threads.
Is one better then the other, or just personal preference. I built with both (read the notes afterwards) and curious if that could be causing my issue. I will find out tonite......anyone run both?
ken
Old 02-27-2014, 09:44 PM   #6279
Default Introducing another 2.0 ready for the track!
Finally finished my first SCT build. Took awhile but for the most part build went good. Only issue is with the shocks which I mentioned above. Will see how she rolls this Sunday!
Learned a lot from this forum
Old 02-27-2014, 11:12 PM   #6280
Errokk's Avatar
I see only one problem...
It's not dirty yet!
Garage:
Old 02-28-2014, 12:06 PM   #6281
Casper's Avatar
ken
The one that goes over the threads is better. It seals great and no way for the seal to get sucked into the shock like the cap seal may do over time.
Old 02-28-2014, 01:28 PM   #6282
DRRC's Avatar
Trader Rating: 57 (98%+)
What length of sensor wire is needed for the 2.0
And what brand is available ?
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 02-28-2014, 02:05 PM   #6283
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
How long do the pucks last with the MIP kit?
I might add this to my rig next.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 02-28-2014, 03:04 PM   #6284
Casper's Avatar
250+
Quite a few people make them here are a few.
http://www.horizonhobby.com/webapp/w...pe=productgrid
Old 02-28-2014, 06:13 PM   #6285
Pro4 HD Hang Oooooooooon!
Roken is offline   Reply With Quote
