Like Tree4Likes
Old 02-16-2014, 07:57 PM   #6181
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Originally Posted by ctuinstra View Post
I had the same thing. 1-2mm seems a bit excessive. I had about .5mm and I shimmed it up using two .2mm x 5mm x 7mm shims on each wheel. I put the shims between the bearing and the pin.
I also replaced the ackerman arm and bushings, that seemed to tighten up most of the slop in the steering. The ball joints can wear also. The 1.0 had terrible aluminum ball joints were the 2.0 had hardened balls and they last a very long time.
Yeah i was thinking about trying that - it seems to have more pull on one side over the other.... I have the 2.0 so it seems a bit soon for them to be worn down but you can see it moving when playing with the wheel .... Im thinking about upgrade to a beefier losi 8 3.0 set of turnbuckles......
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 02-17-2014, 10:26 AM   #6182
Mclogo's Avatar
Here are 2 clips from the A-Main from the first race with my SCTE 2.0.
I was actually faster with the fast laps than with my old car, but not as consistent... the car was not so easy to drive/suspension was to soft... and of course I'm not a good enough driver yet
+ YouTube Video
+ YouTube Video
btw. Motor was a 4.5turn Thunder Power with a 13t pinion
Yokomo B-Max4 III // B-Max2 MR
Yokomo YZ-2 << NOSRAM >>
Mclogo is offline   Reply With Quote
Old 02-17-2014, 04:16 PM   #6183
Default dunfords 5-22-13 setup
Hi all
With this set up it calls for the Rear hex spaced out .5 is this the correct shim? /Losi-5mm-6mm-Metric-Shim-Set
I saw awhile back tlr came out with new rear .5 hexes are these used instead if these shims?
Also is the bump steer washer in it 2mm or .2?
Ken
PYRO689 is offline   Reply With Quote
Old 02-17-2014, 04:36 PM   #6184
Casper's Avatar
Trader Rating: 33 (100%+)
http://www.tlracing.com/Products/Def...odID=TLR332014
This is easier
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-17-2014, 04:50 PM   #6185
Delete
Last edited by PYRO689; 02-17-2014 at 06:49 PM. Reason: Found the answer to my question
Old 02-17-2014, 09:37 PM   #6186
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
is there anyone else besides stock who sells the 5-40x 17/8 button heads? looking for somthing a little stronger
Alan Hall
AlanHall is offline   Reply With Quote
Old 02-17-2014, 09:50 PM   #6187
BigRon's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to BigRon
Try here:
www.tonysscrews.com
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR ~ 4X
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 02-17-2014, 11:27 PM   #6188
AlanHall's Avatar
longest they have is 1.25
Alan Hall
Old 02-18-2014, 06:47 AM   #6189
ridered4life250's Avatar
Originally Posted by xxfile View Post
Built two with no real issues.
There is a build tips download on the first page that helps a lot.
The diffs arent a problem if you are experienced.
we counted the parts as we built and i think it was about 725 pieces total counting nuts bolts set screws body and everything.
I spread it out over a few weeks as i was teaching a total noob but I'm sure it could be done in an evening but a LONG evening mind you.
Pre order the shock caps. You CAN use the kit ones but you need to crank on them with pliers to get them on..
Does anyone know what he is talking about in reference to the caps? Is there something wrong with the kit shock caps? I FINALLY got in to 4wd SCT (I held out for the longest time due to loyalty to 2wd). My 2.0 shows up tomorrow and I want to build it this weekend. I have tried looking at all the build tips threads but none work / pics don't load anymore.
Are the caps not tapped/threaded? What is so hard about getting them on? Also, does anyone have a part number for threaded ones / "right" ones?
ridered4life250 is offline   Reply With Quote
Old 02-18-2014, 09:13 AM   #6190
He's talking about the plastic lower shock cap.s The originals were molded a little too small or something. My kit ones were real tight. They work...they are just harder to get on than they should be. I got the fixed replacements from Horizon customer support. I would think by now they have fixed ones in the kits. But maybe not.
Tommygun1 is offline   Reply With Quote
Old 02-18-2014, 09:34 AM   #6191
yeah i had a kit from last March and was able to get the caps on just fine even tho they were tight. Never got replacements and they still work a year later
SDRC
Associated
TLR
Tekno
uclabruins89 is offline   Reply With Quote
Old 02-18-2014, 08:20 PM   #6192
Trader Rating: 14 (100%+)
What is the best body to get for this truck?
Slippery Dan is offline   Reply With Quote
Old 02-18-2014, 08:28 PM   #6193
Errokk's Avatar
I like the Proline Evo body personally.
Love racing! I just suck at driving...
Garage:
Ten SCTE, TLR22, Xb4
Errokk is offline   Reply With Quote
Old 02-18-2014, 08:32 PM   #6194
AlanHall's Avatar
anyone here ran a the bce vs mip chassis?
Alan Hall
Old 02-18-2014, 08:48 PM   #6195
nEoNidas's Avatar
Trader Rating: 20 (100%+)
Will a scte 1.0 proline body fit the 2.0 chassis?
"Been out the game for a few years, need a point in the right direction."
nEoNidas is offline   Reply With Quote
