Like Tree4Likes
Old 02-13-2014, 06:05 PM   #6151
Originally Posted by BlackStarRacing View Post
Great heads up..... I think I'm going to make the switch..... My 4700 is like you said hard or soft.... I'm going to try a 4.5t... Would a 3.5 be cutting it close?
Don't try to reinvent the wheel. The 4.5t is a proven combo that my guys have had a great deal of success with. We run a 12 pinion on small tracks and a 13 on large tracks. Proper ESC settings (boost, timing, etc.) are critical with a 2-pole. We can help you out with Orion or Tekin settings as we have run both.
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 02-13-2014, 06:15 PM   #6152
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
yeah i agree..... i run HW but some of the setting are similar..... I'm goig to grab their 2 pole 4.5T motor.......
ill pick your brains once i get it in hand....
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 02-13-2014, 06:27 PM   #6153
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
just run a smaller pinion on the hobbywing, the hobbywing is a nice motor I run a 4700.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 02-13-2014, 06:34 PM   #6154
i run a 12t on it at coral springs..... i get a lot of wheel spin on it want to tune it down some more!.......
Old 02-13-2014, 06:35 PM   #6155
BmainStar's Avatar
Originally Posted by Whitey_Wangster View Post
BmainStar my 2.0 came with the gold shafts and pins not the new black ones?
Oh gotta it, thought perhaps you were coming from a 1.0 to the 2.0 as the gold shafts are coated as well.
I did run the TP 4.0 550 2- pole with the gen 2 RX8//Butter smooth and beyond fast..
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 02-13-2014, 09:28 PM   #6156
Originally Posted by 071crazy View Post
Try to avoid using a hammer, they aren't meant to take that sort of side force. The bearings are a tight fit, just takes a little patience to install them.
Thanks yeah I barely tapped and it fell into place
PYRO689 is offline   Reply With Quote
Old 02-14-2014, 01:16 AM   #6157
Mclogo's Avatar
I've been running my 4pole orion vst2 540 4600kv on my rango SC since the indoor season. Had tried a 5.5t 550 vst2 on my (medium) outside track and it was enough with a little bit of boost.
Now with the SCTE 2.0 I think I will go with the TP 4,5turn 550, guess it'll be easier to get it dialed.
Btw. I had been running the 15tooth pinion with the 5.5turn, is it really 2teeth less with the 4.5turn TP? (change from 15/41MIP - 10.63 to 13/41 - 12.27)
Will race my TLR for the first time this weekend
Yokomo B-Max4 III // B-Max2 MR
Yokomo YZ-2 << NOSRAM >>
Mclogo is offline   Reply With Quote
Old 02-14-2014, 10:04 AM   #6158
Default Savox Servos
What Savox Servo would you guys recommend for this truck?
Ken
Old 02-14-2014, 11:26 AM   #6159
Ken
I have used "Savox SB-2270SG "Monster Torque" Brushless Servo" @7.4v and the "Savox SC-1256TG Standard Digital "High Torque" Titanium Gear Servo" @ 6v. Both worked flawlessly. No issues at all. Some like faster servos, but we prefer .12 to .15 on the trucks. I run much faster servos on my 1/10 buggies.
Old 02-14-2014, 11:30 AM   #6160
Please keep in mind that the SCTE is light, compared to some other trucks. We have had great success with the 4.5t 2-pole, but proper ESC settings are CRITICAL to wake it up. If you run 4-pole type settings without timing (among others), it WILL be a turd! My guys dominate with 2-poles.
Old 02-14-2014, 11:32 AM   #6161
JEFFs SC10's Avatar
12? Lol
I ran a 18 tooth last week for practice. Its all in your finger.
I may knock it down a tooth or two but I like being able to blip over a jump.
XRAY 2017 T4
Xray X12-17' GT12
Old 02-14-2014, 11:44 AM   #6162
Mclogo's Avatar
A question for Casper or Hacker,
If I order the bottom caps set LOSB2904 from amain or so in the US, then I should get the updated ones?
(I was "lucky" to get 2 SCTE 2.0 kits with the shrunk bottom caps)
Old 02-14-2014, 12:00 PM   #6163
Mclogo's Avatar
Ok, my former truck was lighter... But I guess not half as durable
I did not mean to run it without adjusting the ESC to the track checking motor temps etc. I was just thinking about the gearing, where for example in buggy mod classes people tend to use the gearing more than boost or specially turbo, since its more linear... This does not seem to be like that in 4wd SC?
Old 02-14-2014, 02:13 PM   #6164
Casper's Avatar
Trader Rating: 33 (100%+)
I am sure there is some old stock out there still. the best bet would have been to contact Horizon Customer Service and they would have sent you out new bottom caps. Again not sure what the status is of A-mains stock on these parts? Ryan my know better.
4.5T straight up is good. You can boost it though and get some more out of it. Everyone seems to be looking for max power for these trucks! They handle pretty darn good so guys keep wanting to go faster!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-14-2014, 02:29 PM   #6165
Mclogo's Avatar
Thanks a lot!
I had raised a request online with Horizon a week ago, but not heard of them yet... Will call them on Monday if I don't hear from them...
