Like Tree4Likes
Old 02-13-2014, 10:23 AM   #6136
I'd much rather have some overkill than some underkill
SDRC
Associated
TLR
Tekno
uclabruins89 is offline   Reply With Quote
Old 02-13-2014, 10:38 AM   #6137
Trader Rating: 15 (100%+)
Oooohh...I see now B-main was comparing the Pro 4 HD 4300 to the Pro 4 4600. I missed the HD part. I see now. I'm just running a Pro 4 4000kv.
Tommygun1 is offline   Reply With Quote
Old 02-13-2014, 12:12 PM   #6138
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by BlackStarRacing View Post
Quick question: how do you like the 4.5t on you're scte vs the other motor?
I run the same combo as BSCFlash and i love it. I copied MonsterSummit originally after he was dominating all things pro4 and continues to do so in our area. The 2 pole is a lot smoother rolling on the throttle you dont have to worry about the wheels spinning as much. It has enough power to make any jump and hang with or even out run any 4 pole down a straight away. It seems to run a lot cooler than my 4 pole ever did (130s vs 190s). The thing i hated about my 4 pole was it was an on and off switch, really no in between and the 2 pole has as much as your squeezing the trigger. Since i've switched i have become a lot more consistent and have been doing better results wise as well.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 02-13-2014, 12:28 PM   #6139
The 4-pole tends to be very agressive on the low end (more torque), while the 2-pole has less torque, and a better "actual use of" the power, almost like a built-in traction control. The 2-pole seems to hook up much better while not blowing the tires off, but still has awesome upper-end power and speed with the right ESC settings. It is still a beast, although it's a 2-pole, because it does have a massive 550 can.
I have used the HD 4300, and it is far too much power for such a light truck. I prefer the 4600 over the 4300 all day day long if you must go 4-pole.
Most of the local TLR guys have gone to the 2-pole 4.5t, and, in fact, one of our guys TQd at the Midwest Nationals with my exact configuration.
As you can see by my vehicles below, I run both motor configurations, but prefer the 2-pole on smaller indoor tracks. We have yet to try the 2-pole on the outdoor tracks due to winter.
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 02-13-2014, 01:04 PM   #6140
Default Diff Assembly
Hi all,
Putting together my first diff and wanted to see if these bearings are suppose to fit flush against the gear housing as it was really tight to get them on to where they are now. Is this ok?
Also no issues screwing on the diff screws pre threaded them first
Ken
PYRO689 is offline   Reply With Quote
Old 02-13-2014, 01:10 PM   #6141
Originally Posted by PYRO689 View Post
Hi all,
Ken
Ok just figured out they do need to be flush...any tricks to get these pushed in more?
Old 02-13-2014, 01:19 PM   #6142
Little tap with hammer got it
Old 02-13-2014, 01:40 PM   #6143
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Most of the local TLR guys have gone to the 2-pole 4.5t, and, in fact, one of our guys TQd at the Midwest Nationals with my exact configuaration.
Great heads up..... I think I'm going to make the switch..... My 4700 is like you said hard or soft.... I'm going to try a 4.5t... Would a 3.5 be cutting it close?
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 02-13-2014, 01:45 PM   #6144
Try to avoid using a hammer, they aren't meant to take that sort of side force. The bearings are a tight fit, just takes a little patience to install them.
TPJ International
071crazy is offline   Reply With Quote
Old 02-13-2014, 01:46 PM   #6145
Originally Posted by BmainStar View Post
the 2.0 comes with that!!!
Not sure it matters,snug up the ends till they stop then unscrew 2x complete turns and You will have it!!!
4600 for sure the 4300 is over kill !!!!!!!!!not needed anywhere!!!unless you are Dunford LOL
BmainStar my 2.0 came with the gold shafts and pins not the new black ones?
Whitey_Wangster is offline   Reply With Quote
Old 02-13-2014, 01:56 PM   #6146
Casper's Avatar
Trader Rating: 34 (100%+)
I don't know anyone that makes a 550 3.5T?
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-13-2014, 02:03 PM   #6147
Lol...... You maybe right....lol
Old 02-13-2014, 05:02 PM   #6148
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
Will the servo/rx box from the 8ight e 3.0 fit on this truck? If so, why aren't more people just doing that so their rx isn't exposed to all that dirt?
Thank you to the following companies for their support in 2017:
* Futaba * O.S. Engines * RC Racing Communications *
CaptainHowdyt13 is offline   Reply With Quote
Old 02-13-2014, 05:13 PM   #6149
Grandturk's Avatar
Because dirt doesn't do any harm to it?
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 02-13-2014, 07:00 PM   #6150
We use some fine sandpaper to turn them down a tick. The bearing then "wiggles on" without the use of excess force, and are still plenty snug. Remember, if you hammer them on, you could risk damaging the bearing, and ultimately have a bearing that is very difficult to remove.
