Like Tree4Likes
Old 02-09-2014, 08:50 PM   #6106
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by rusty123 View Post
I am almost finished building my kit but I have a question. Clear grease was included with the kit and is mentioned in the pictorial legend at the beginning of the manual but all I have to do is finish the shocks and I have not used it.
I just went through the manual again and can't find where it is supposed to be used.
What is it for?
Clear Grease? Are you sure that is not the shock oil?
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-09-2014, 09:31 PM   #6107
skrichter's Avatar
Send a message via AIM to skrichter
For those that are searching for more steering out of the 2.0, I'm not sure if anyone has tried the forward rake like the 22-4 (as described by T. Hodge)??
https://www.youtube.com/watch?v=COLwhlqm10E#t=92
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 02-09-2014, 10:23 PM   #6108
Bikemaster00's Avatar
Default Aluminum C-Hubs and Knuckles
Originally Posted by ctuinstra View Post
Are there any aluminum front spindles available for the 2.0? This is the third one we've broke in the cold weather (indoor). On top of that, the molding of the right side top king pin keeper is terrible on the new ones and strips out; I've gone through a couple of new ones just to get the allen screw in the top hole. The bottoms ones go right in without a problem.
Yes Hot Racing and STRC makes them
Bikemaster00 is offline   Reply With Quote
Old 02-11-2014, 07:23 AM   #6109
Mclogo's Avatar
Sorry for asking another newb question...
I'm trying to find a dirt cover for the SCTE 2.0. I've seen that it's possible to mount a 1/8 buggy body as inner body?
Does anybody know, what type of bodies fit best? Losi/TLR?
Thanks!
Yokomo B-Max4 III // B-Max2 MR
Yokomo YZ-2 << NOSRAM >>
Mclogo is offline   Reply With Quote
Old 02-11-2014, 07:56 AM   #6110
STRC does NOT make any that I am aware of. Hot Racing and Integy does though.
potatobed409 is offline   Reply With Quote
Old 02-11-2014, 09:15 AM   #6111
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Hey guys can we fit losi8 turn buckles on the scte?
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 02-11-2014, 12:04 PM   #6112
Casper's Avatar
Yes.
Old 02-11-2014, 01:46 PM   #6113
Mclogo's Avatar
Just went through the first 4 packs as I've already striped a rear driveshaft pin... luckily I got my second SCTE 2.0 today (need 2 to be able to have enough parts for racing).
I guess medium to high bite carpet puts more stress to them than normal.
youtu.be/FCEVzZ69m_w (just a few seconds before it striped)
I've read about the MIP Pucks Center Dive System, which I think I will get. How about stronger driveshafts? Is the Tekno RC M6 the only optional set?
Old 02-11-2014, 02:52 PM   #6114
rcgod's Avatar
Trader Rating: 27 (100%+)
I would go with tekno driveshafts front rear and center if you're running carpet. I have the MIP pucks and they are really nice and light but you might see some quick wear on the plastic inserts and aluminum bones. I run mostly on medium bite so I'm not putting as much stress on them and have minimal wear.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-11-2014, 03:08 PM   #6115
Hey guys, how do you know if your servo saver is tight,loose or just right? How many threads do you have showing?
Old 02-11-2014, 03:14 PM   #6116
I tighten mine as much as I possibly can. Using a savox 1258tg, not worried about breaking gears. Ran it like this for almost a year now with 0 issues
SDRC
Associated
TLR
Tekno
uclabruins89 is offline   Reply With Quote
Old 02-11-2014, 03:17 PM   #6117
I had tekno's on both the front and the rear. They are stronger, but also much more expensive than stock losi parts to replace. I just put the stock shafts back on the rear, left the Tekno's on the front.
I love the tekno's but 2 stub axles are $18.99 vs 9.99 for stock losi axles. Same thing with outdrives and shafts, twice the price for Tekno replacement parts. Now that i've learned to drive it better, I think the Losi's should hold up fine
SDRC
Associated
TLR
Tekno
Old 02-11-2014, 04:21 PM   #6118
DoogieLee's Avatar
Trader Rating: 42 (100%+)
Does anyone have a droop measurement for the Dunford setup?
I know it says " Full plus 2 turns" but I would like an actual mm measurement if possible.
Kevin 'Doogie' Lee
\m/ SCTE 3.0*XB8e\m/
Qualifiers are just organized practice...
DoogieLee is offline   Reply With Quote
Old 02-11-2014, 04:57 PM   #6119
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
I'd like to know the answer to this too. Front and rear settings.
Thank you to the following companies for their support in 2017:
* Futaba * O.S. Engines * RC Racing Communications *
CaptainHowdyt13 is offline   Reply With Quote
Old 02-11-2014, 05:42 PM   #6120
LosiRacer33's Avatar
Anyone know if bye MIP puck inserts will fit on the stock shafts? I want to take some play out of the driveline but am not ready to put down that coin to replace working parts.
www.gallimods.com
TLR SCTE 2.0, 22-4, 22 2.0
Tekin Motors and Speed, Orion Batteries
superty.org
LosiRacer33 is offline   Reply With Quote
