Like Tree4Likes
Old 02-04-2014, 07:40 AM   #6061
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by BSR31 View Post
this tower shock have 2 hole as i mention it before...
lower hole for original shock (12mm) and higher hole wich is 9mm taller than original is for big bore 16mm shock. and seat perfectly...
you may cek to SNR graphite...
thx
Yes those towers have been out a while and are designed for the 8ight 2.0 shocks which were 9mm longer than the scte shocks. The 3.0 shocks are about 9mm longer than the 2.0 were. The 3.0 shocks will physically bolt up and work but there will be the same problem as running 2.0 shocks on scte with stock towers. Too much down travel and not enough up travel for best performance.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-04-2014, 12:39 PM   #6062
Redwings's Avatar
Default now its safe and secured
Well, its finally done. Managed to find a receiver box small enough to fit the 2.0
Wires are cleaner safer. Here is the final product.
Redwings is offline   Reply With Quote
Old 02-04-2014, 12:48 PM   #6063
DoogieLee's Avatar
Trader Rating: 42 (100%+)
Is that the AE box? Looks good!
Kevin 'Doogie' Lee
\m/ SCTE 3.0*XB8e\m/
Qualifiers are just organized practice...
DoogieLee is offline   Reply With Quote
Old 02-04-2014, 05:25 PM   #6064
Redwings's Avatar
[QUOTE=DoogieLee;12975556]Is that the AE box? Looks good![/QUOTE
Shh. No Bad words but yes it is. Could shave the AE off fast enough LOL.
Got the tip from another losi scte driver on this forum. Look and sound good now
Perfect.
Old 02-04-2014, 05:51 PM   #6065
Originally Posted by hacker07 View Post
Hey guys, been fiddling around with a new setup for my SCTE 2.0 after doing some "other" testing on another platform we have. I really feel this will give you the best of both worlds traction and steering wise. I have more steering in my truck than I have ever had now and also a rear end that does not slide much at all.
Casper likes the ride height a bit different so you may want to play with that some depending on your personal driving style.
Please let me know and please if you are going to try it, try the whole thing and you can play with bits of it past that. This is the first setup specific to the SCTE 2.0 that I have done.
On the Ryan Dunford setup sheet it calls for 1 up hinge pin insert front inner and 1 down insert front outer. What about the rear inserts? stock set up?
Duunga is offline   Reply With Quote
Old 02-04-2014, 07:39 PM   #6066
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
I'm noticing that on this Dunford setup he's running a 39t spur. Does anyone other than MIP make a 39t?
Thank you to the following companies for their support in 2017:
* Futaba * O.S. Engines * RC Racing Communications *
CaptainHowdyt13 is offline   Reply With Quote
Old 02-04-2014, 08:49 PM   #6067
BmainStar's Avatar
Originally Posted by DoogieLee View Post
I was wondering if the old "go to" spring setup from the 1.0 would work on this...
Hows the class at Pegasus these days?
I'm going to be heading out there in about a month, its been 2 years since I was there last and I had a great time.
Ya,what`s up Doogie?
The track has been off and on for a while, alot of nights no 4x4 sct at all,but lately there has been some.Don't know if IERC was here last time you showed but worth a look for sure.Ya my truck had the glued up 22 pistons and then 1 came unglued LOL. I really liked how the shocks felt on the 1.0 so that's what I run.The new Dunford set up uses silver rear springs I think? My 1.0 had the BCE chassis, so does this one, maybe it just feels more like what I was used too?LMK when you get here!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 02-04-2014, 10:57 PM   #6068
Nevermind.... i did some homework and figured it out
Old 02-05-2014, 12:09 AM   #6069
BSR31's Avatar
to bad i can not upload the picture yet cos' i still new in here hope i can send u a picture to see how it work for the up and down travel...
thx
BSR31 is offline   Reply With Quote
Old 02-05-2014, 03:30 AM   #6070
Mclogo's Avatar
Hi,
I'm new to RCTECH and just in the progress of switching from a Durango DESC410v2 to the TLR SCTE 2.0.
(The desc410 is fast but I had some issues with the durability and quality of parts and I want a SC that is easy in maintenance)
I've been attending some indoor races so far with my rango and now the next 4 races with the TLR will also be on carpet... I'm looking forward to build and setup this badboy
While I had been running a 5.5turn VST2 550 2 pole Team Orion on our medium-small outdoor track, I did us a 4600kv 540 4 pole VST2 Orion for indoor carpet racing so far... seemed to have enough speed and power.
But when I look at the (US) Nats or EOS and other large races, the pro drivers seem to race 2 pole 550 cans more often? Is there a reason for that?
Thanks,
Dave
Mclogo is offline   Reply With Quote
Old 02-05-2014, 04:36 AM   #6071
DoogieLee's Avatar
I dont think IERC was around when I was out there last, I know I got to hit up Pegasus and Revelation a couple times each while I was out there.
I'll definitely give ya a buzz when I get out there, looking forward to racing out west again.
I should be picking my 2.0 up tonight, got a smoking deal on a basically new kit. All the seller has done is put the steering assembly on the chassis, the rest is in bags still.
I've already ordered a couple of feet of wire and a 275mm sensor wire for it, so hopefully TQ gets that stuff to me quick and wont hold me up too long.
I'm really looking forward to getting this one built and on the track.
Kevin 'Doogie' Lee
Old 02-05-2014, 06:06 AM   #6072
Suspended
dominick i.'s Avatar
Trader Rating: 123 (97%+)
Official TLR TEN-SCTE 2.0 Kit Thread-1618608_10202269290445029_978547649_n.jpg
fully rebuilt. the mip puck driveshafts are definitely the way to go...
club racing is always great racing......
I am probably the only non sponsored racer in the usa.....:)
dominick i. is offline   Reply With Quote
Old 02-05-2014, 06:46 AM   #6073
Grandturk's Avatar
Originally Posted by dominick i. View Post
Attachment 1162763
Good to hear. How do the mip shafts hold up on a blown out 1/8 track?
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 02-05-2014, 06:51 AM   #6074
Suspended
we will find out soon enough
Old 02-05-2014, 10:16 PM   #6075
Moderator
badaml's Avatar
Trader Rating: 127 (100%+)
Originally Posted by Mclogo View Post
Hi,
Thanks,
Dave
ROAR rules. ROAR specifies that 540 4 pole motors OR 550 2 pole motors are to be used.
Cheap, Fast, Reliable - Pick 2.
Current:Traxxas Rally/Slash 4x4-Blade MQX
Past: Kyosho Raider, Traxxas GTP, Kyosho Optima, Jato 3.3, Tmaxx 2.5, Revo 2.5, Revo 3.3, TC4, MBX5t, Hyper 7, Emaxx, Vorza, Inferno VE, XXXT, Hyper Sprint, SC8e, Erevo, Rustler VXL, RC18b, Baja 5b, Parrot AR Drone, Mini ERevo VXL, HB D8Te, D8, Slash 2wd, Slash 4wd, HB Ve8,Blade 350QX, Alien Quad 450, DJI F450, DJI F550, Losi 8 3.0, Axial Yeti XL, DJI Phantom 3 Advanced, Traxxas Summit, DJI Phantom 3 Pro
badaml is offline   Reply With Quote
