Like Tree4Likes
Old 01-27-2014, 05:48 PM   #6001
maddog9's Avatar
Trader Rating: 29 (100%+)
Theres a way to run the 2.0 8 shocks with the stock scte shock towers. I believe you limit the droop to 89 front and 101 rear. Also if using the standard standoffs you need to space it out so the shock cap isnt touching the tower or option 2 is use the 2.0 8 standoffs and drill out the shock tower to receive them.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 01-29-2014, 05:45 AM   #6002
Casper's Avatar
Trader Rating: 33 (100%+)
http://www.tlracing.com/Products/Def...odID=TLR332014
New wider hexes for the SCTE. These are only for the rear. The front is already at max width. Also be careful if you run run more then 3 deg of rear toe. Just another tuning option. We have been shimming or running these on the latest Dunford setup at www.casper-rc.com
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-29-2014, 06:55 AM   #6003
sanny632's Avatar
Trader Rating: 17 (100%+)
Sweet. Hey Casper I put the tlr3100 in w two shims on each side. Good place to start? It's smooth on ring and pinion.
TLR-SCTE 2.0 TLR-8-e 3.0 Tlr Micro Brushless SCT Team Losi Jrx2. Custom Works SE-3 Custom Works GBX-3 HPI RS4 Pro Chatioc Crawlers Switch xr10 Mattzilla scx10 trugge Axial Wraith
sanny632 is offline   Reply With Quote
Old 01-29-2014, 11:21 AM   #6004
On the setup sheet. What are witness marks? That puzzles me.
Tekno SCT 410.3 rx8gen2/pro 4 4300HD 1267 savox servo
Tekno EB 48.3 rx8gen2/t8 1900kv 1267 savox servo
Tekno NB 48.3 Novarossi 5PXLT 1267 savox servos
all controlled with spektrum dX4R
skyler hays is offline   Reply With Quote
Old 01-29-2014, 11:30 AM   #6005
Grandturk's Avatar
Rubbing marks from the wheel hitting the arm
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 01-29-2014, 11:39 AM   #6006
Suspended
dominick i.'s Avatar
Trader Rating: 123 (97%+)
thanks for clarifying that Tony.....
club racing is always great racing......
I am probably the only non sponsored racer in the usa.....:)
dominick i. is offline   Reply With Quote
Old 01-29-2014, 12:15 PM   #6007
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Originally Posted by MonsterSummit View Post
I'm sure some people will have some different opinions, but there are a couple reasons for me to run a 2-pole. I run the Orion R10pro with a Thunder Power 4.5T motor. One reason for me is because I don't have to run an 1/8 esc. And like Dakotah said the turbo and boost settings in the Orion are awesome. With the 4.5T I am usually geared 12 or 13/40. But usually I just adjust my boost/turbo in the esc. I ran the Pro4 4600 for a while and bought the 4300HD and ran it for 1 race and sold it. To me, those motors are just way to much UNUSABLE power in these trucks. Where as the 2 pole is just as fast, but the power coming on throttle is extremely smooth. I run against Pro4 4300HD's on a regular basis and never get out motored. And I have yet to find a jump on a track that I am unable to do with the 4.5T. The biggest reason I run the 2-pole is that it seems to be so much easier on batteries. No more worrying if you will make the main with enough battery, nor have I puffed a single pack since going to the 2-pole. I always said if I ever felt as if I got beat because of running a 2-pole motor I would go back to the 4-poles. But in all honesty, I don't ever see that becoming a problem. The biggest test for me came at the CRCRC Winter Midwest Champs a couple weeks ago. I was able to TQ Matt Olson and run a faster lap overall throughout the weekend. The mains were a different story with me choking, but overall I did not feel as though I was at a disadvantage to Olson.
I was thinking about trying the new speed passion blaze 5700kv in my truck. any advice on gearing compared to the 4pole setups?
and wanted to say whats up to everyone else in the thread. I have 2 scte/mip trucks on the way. hopefully they work out and I can hang out around here a while
Alan Hall
AlanHall is offline   Reply With Quote
Old 01-30-2014, 01:18 AM   #6008
BSR31's Avatar
Default TLR SCTE 2.0 with 16mm shock
Official TLR TEN-SCTE 2.0 Kit Thread-20140123_205417-rs-x.jpg   Official TLR TEN-SCTE 2.0 Kit Thread-20140122_094317x.jpg
BSR31 is offline   Reply With Quote
Old 01-30-2014, 03:43 AM   #6009
JKoiva's Avatar
Where are you putting the .5mm spacer on the rear hubs. I thought I read somewhere to shim between hub, outer bearing and the cross pin. I put a .5mm clutch shim in there and it binds? I'm running the aluminum rear hubs.
Tki3 , O.S.
D413
B5M
Futaba
JKoiva is offline   Reply With Quote
Old 01-30-2014, 09:26 AM   #6010
Hoese37's Avatar
Same length as the 12mm?
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 01-30-2014, 10:34 AM   #6011
drepus's Avatar
It goes between the bearing and the pin.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 01-30-2014, 05:35 PM   #6012
BSR31's Avatar
Originally Posted by sbrewer View Post
Has anyone used the SCTE 9MM TALLER FRONT TOWER with the 3.0 shocks?
If so what springs pistons one oils did you use? also how did that work?
yes.. I use 3.0 shock... the cup use Tekno sct410, the spring use tekno spring R Black and F Pink. for the piston i made split hole... bigger hole. the oil f 32.5, R 27.5 AE oil shock
the reason using tekno cup, so i can choose a lot of spring in the market (diameter of spring is the same on each end point-eight spring has different diameter on each end point)
i am using 16mm shock because has the same reason with you... most of our track (indonesia) is for 1/8 buggy engine track..... and very rough track...
thx
Old 01-30-2014, 06:14 PM   #6013
Finished my build!! Rx8 pro 4HD 4300 setup. It's amazing!!
Kaussy is offline   Reply With Quote
Old 01-30-2014, 07:54 PM   #6014
sbrewer's Avatar
Trader Rating: 20 (100%+)
Anyone have a good shock setup for 1/8 fairly rough tracks?
- AKA - Team Associated - Dark Side RC Racing - Os Speed - Jc Designs - Futaba - Boca Bearings-
sbrewer is offline   Reply With Quote
Old 01-31-2014, 03:45 AM   #6015
JKoiva's Avatar
Right , so I put a .5mm clutch shim in, there is just not enough room. it binds up and won't spin freely by hand....
Tki3 , O.S.
D413
B5M
Futaba
