Like Tree4Likes
Old 01-23-2014, 11:51 AM   #5986
drepus's Avatar
so you checked the outdrives?
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 01-23-2014, 02:04 PM   #5987
Default Traction Roll
This past weekend I went racing in Flowood,Ms. It was first time to expierence an indoor high bite track. There was some decent straight always and I had a huge problem traction rolling. I ran the latest dun ford setup. What are some ways of stopping traction rolling? I liked my setup otherwise. The top guys running thus class really didn't have any trouble with rolling.
Tekno SCT 410.3 rx8gen2/pro 4 4300HD 1267 savox servo
Tekno EB 48.3 rx8gen2/t8 1900kv 1267 savox servo
Tekno NB 48.3 Novarossi 5PXLT 1267 savox servos
all controlled with spektrum dX4R
skyler hays is offline   Reply With Quote
Old 01-23-2014, 02:16 PM   #5988
I would say if you are traction rolling in sweepers, then maybe you'd want to have more negative camber.
If you are rolling in a sharp 180 turn, then I'd try limiting droop. It is an adjustment that is rarely used in off road by many, but I've had success with it. The idea is that you transfer less weight to the outside wheels because your inside wheels lift less.
Whatever you do to fix the problem, let us know.
JK47 is offline   Reply With Quote
Old 01-23-2014, 03:10 PM   #5989
Tires has a lot to do with that. What tires and foams are you running? What were they running?
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 01-23-2014, 04:11 PM   #5990
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Dropping a mm or 2 of ride height front and rear will a lot of times solve traction rolling problems too.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 01-23-2014, 07:34 PM   #5991
Thanks for the replies guys. I was rolling in sweepers and at end of straits. Was running bar codes front and rear.
I doubt I will be on a high note track again in the near future...but I will store the info for future use
Old 01-24-2014, 04:09 AM   #5992
that seems to be the culprit... but i didnt think the outdrives would wear so quickly. Then they are assembled (lately) i find the pins to be a snug fit (they just dont drop out on their own)... i'm assuming the tolerences got tighter, but i'm finding them to wear quickly.
i ran the truck 60-70 times when i first got it before i found outdrive wear to be an issue.
TLR SCTE 3.0
TLR 22SCT 2.0
Powered by SMC and Tekin
JMURACN is offline   Reply With Quote
Old 01-25-2014, 05:15 AM   #5993
Im pretty surprised about the reports on all this drive shaft wear and breakage. I haven't had a single problem since owning the truck.
beanstalk is offline   Reply With Quote
Old 01-25-2014, 03:37 PM   #5994
Default Shock ?
just started to build my new kit, got to the shock build section. Has anyone had issue's with the shocks? The bottom of the shocks where the washer/ oring seal for shock shaft. I can't get the cap to tighten all the way down, any suggestions?
Rich68 is offline   Reply With Quote
Old 01-25-2014, 05:24 PM   #5995
ironzgti35's Avatar
The first run of 2.0s had an issue with the shock bottom caps. They will need a little extra force to thread on properly, aka a pair of vise grips or similar. I'm a little surprised you would find a kit that was still an issue as I believe TLR fixed the issue.
ironzgti35 is offline   Reply With Quote
Old 01-25-2014, 09:25 PM   #5996
lowspark's Avatar
Contact Horizon Hobbies and ask them to send you the correct replacement caps. They have some small bags with 4 caps in them. If the tech doesn't know what you are talking about, ask for someone else.
The first time I asked ( a few months ago), they sent me the standard shock kit bag and it had the same caps that don't fit. After reading in this thread I called again, (a month ago), and the tech knew about the problem and dropped the correct replacements in the mail.
The correct replacements screwed right on by hand, no tools required.
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 01-27-2014, 03:33 PM   #5997
sbrewer's Avatar
Has anyone used the SCTE 9MM TALLER FRONT TOWER with the 3.0 shocks?
If so what springs pistons one oils did you use? also how did that work?
- AKA - Team Associated - Dark Side RC Racing - Os Speed - Jc Designs - Futaba - Boca Bearings-
sbrewer is offline   Reply With Quote
Old 01-27-2014, 03:42 PM   #5998
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
why would you use those oversized shocks?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 01-27-2014, 03:59 PM   #5999
sbrewer's Avatar
was just wondering I ran the 2.0 shocks on my 1.0 and liked it. I usually run on big 1/8 tracks
Old 01-27-2014, 05:42 PM   #6000
rcgod's Avatar
Trader Rating: 27 (100%+)
The taller towers are made for the 2.0 shocks. The 3.0 shocks are longer and would cause the same issues as running the 2.0 shocks with stock towers. Not enough up travel and too much down travel. Not to mention all that weight up high. The truck would end up handling like a tekno. :-)
Dialed RC Hobbies
rcgod is offline   Reply With Quote
