Like Tree4Likes
Old 01-18-2014, 07:05 PM   #5941
rivalshad's Avatar
Trader Rating: 14 (100%+)
In looking at the king headz mount, does the 2nd bearing fit over the out drive?
8ight E 3.0, SCTE 2.0, TLR 22-4, B5, RC8.2 FT, SC10B FT
60% of the time it works everytime
rivalshad is offline   Reply With Quote
Old 01-18-2014, 07:25 PM   #5942
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
yup
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 01-18-2014, 07:35 PM   #5943
The King Headz unit really is a GREAT upgrade. If you talk to anyone who runs it, I doubt you'll hear anything but great sentiments.
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 01-18-2014, 08:18 PM   #5944
Originally Posted by ChrisWolfson View Post
Open the center diff. Something is broke in there. Could be gears - could be a pin.
Thanks for the help!
TLR 22 2.0
TLR 8ight-E 3.0
Chris Frisina is offline   Reply With Quote
Old 01-18-2014, 08:22 PM   #5945
Originally Posted by drepus View Post
Like Chris said definitely a broken pin or gears. How often do you disassemble and fill up the oil in your diffs?
I just recently built this truck 3 weeks ago which is the reason why Im thinking something must be broken. I havnt re-oiled any of the diffs since the build though.
TLR 22 2.0
TLR 8ight-E 3.0
Old 01-18-2014, 09:27 PM   #5946
rivalshad's Avatar
Thanks for the info. I'm going to pick it up. Do you run the front and motor mount as well?
Old 01-18-2014, 10:14 PM   #5947
nolimit1's Avatar
Hi, just reading. If you buy the front, it's good to buy the rear mount too. It keeps the center diff housing from wearing out. I have both and I don't have to worry about my center diff leaking all the time or rebuilding either!!
TEAM GOAT RACING
Kyosho RB6
Team Durango - DEX210- DEX210v2 - DEX410v4
Team C TMSC
DJI Inspire 1
nolimit1 is offline   Reply With Quote
Old 01-19-2014, 01:22 AM   #5948
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
if anyone is selling a clean roller let me know. I want to build a pro 8.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 01-19-2014, 06:21 AM   #5949
It is imperative that you run both pieces. This will give you the stability of four bearings truing your center diff. It is butter!
Old 01-19-2014, 07:14 AM   #5950
sanny632's Avatar
Trader Rating: 17 (100%+)
The king heads set is amazing I race at king hobbies Jim is a great guy his pieces are top notch. I'd say the front is a Must but the set makes the out drives solid.
http://www.kingheads.com/product_inf...roducts_id=945
TLR-SCTE 2.0 TLR-8-e 3.0 Tlr Micro Brushless SCT Team Losi Jrx2. Custom Works SE-3 Custom Works GBX-3 HPI RS4 Pro Chatioc Crawlers Switch xr10 Mattzilla scx10 trugge Axial Wraith
sanny632 is offline   Reply With Quote
Old 01-19-2014, 11:21 AM   #5951
Rxfisher's Avatar
Trader Rating: 18 (100%+)
Default Parma body works
Might not work at ROAR nationals but it works for me.
22 Losi Buggy, HPI BLitz, ECX Torment, Duratrax Element, ten-SCTE 2.0, tekin gen1, pro4 4600, losi 8ight 3.0, orion r8 pro
Rxfisher is offline   Reply With Quote
Old 01-20-2014, 01:02 AM   #5952
Default Pinion and Spur gear
Running a SCTE 2.0 at an indoor track. LSR speedway......
Anyone have a good ration for a Pinion and Spur to run?
fyrman41 is offline   Reply With Quote
Old 01-20-2014, 04:58 AM   #5953
Let us know what motor you run, this is critical info you left out! For example, the Tekin 4300 will run a much different pinion gear than the 4600.
I run the Tekin Pro4 4600, and run a 14 tooth on larger indoor tracks and a 13 on smaller tracks. Very small tracks could go as low as a 12. Top speed can be fine tuned by reducing travel on your radio to slow it down or adding some timing (up to 25 or 35 degrees) to speed it up (with the Tekin ESC).
Old 01-20-2014, 07:45 AM   #5954
TLRacing
I run an Orion 4T motor with an 11 pinion inside and outside. I adjust turbo and boost accordingly.
TLR-Team Losi Racing, Team Orion, Pro-Line, Spektrum, Nitrotane, Horizon Hobby, Darkside Designs, StickIt1 Racing, Lunsford, OCRC, LiveRC, RC Scoring Pro, AMS, & Stateline
Dakotah Phend is offline   Reply With Quote
Old 01-20-2014, 08:47 AM   #5955
rivalshad's Avatar
I have seen a few setups lately with 2 pole 4/5T motors. What's the goal behind running a 4/5T over a 4300/4600/4800? I love my Schuur Speed 4300, but was thinking of changing it up to a 4600/4800 or a 4/5T.
I ended up ordering both center diff mounts, the top plate with transponder mount and the upper steering plate, I'm a sucker for hop ups
