Like Tree4Likes
Old 12-22-2013, 04:32 PM   #5821
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
just did a rebuild with change of bearings.... much needed, but it gets quicker every time!
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 12-23-2013, 05:05 AM   #5822
eddomak's Avatar
Originally Posted by Snafujg View Post
Can anyone confirm if the Tekno M6 driveshafts for front and rear require the Tekno outdrives, or do they work with the Losi Lightened and Hardened outdrives? My losi drive shafts that came with the kit are hitting the outdrives and started to wear. Want to replace them with the Tekno ones, but don't want to replace the outdrives if not required.
Like rcgod said, the centre driveshafts slot straight in (highly recommended!).
The shafts for the fronts and rears need the Tekno outdrives. Refer to the manufacturer's product page and it calls it out.
Note: These driveshafts are not compatible with the stock driveshaft parts (i.e. you canít use our shafts and the stock outdrives for example)
Losi SCTE 1.0 - BCE Chassis, Hobbywing SCT Pro, Hobbywing XERUN 3656SD 4000KV, Hitech HS-7955TG
TLR 22T - Orion R10 Pro, Turnigy 10.5T 3250KV
Axial SCX10 Honcho | Traxxas Mini Summit VXL | Losi Micro Desert Truck | Tamiya Boomerang
Airtronics/Sanwa MT-4 | Flysky GT3B - Custom firmware
eddomak is offline   Reply With Quote
Old 12-23-2013, 08:21 AM   #5823
Trader Rating: 17 (100%+)
Thanks guys, not sure how I missed that.....
Snafujg is offline   Reply With Quote
Old 12-23-2013, 08:44 AM   #5824
Redwings's Avatar
Default motor alignment issues
Since I put my scte 2.0 together, I have had issues with spacing between the pinion and spur gear. I'm running a 540 castle creation motor with supplied fan, but only have limited movement because of the side guards. I have shaved them down yet still have issues. Any recommendations?
Paul
Redwings is offline   Reply With Quote
Old 12-23-2013, 08:44 AM   #5825
What effect does placing 5000 diff oil in the rear diff have on how the car drives?
Old 12-23-2013, 08:56 AM   #5826
Often times when really pushing a 4wsc, the opposite rear tire may come up some and this will cause a snapping feeling to the rear end. The heavier rear diff oil will help the car not diff out in these situations and thus feel like you have more rear traction.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 12-23-2013, 10:10 AM   #5827
drepus's Avatar
Paul
You could always double check you have the side guards on correctly as there is a left and right and they look a little similar.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 12-23-2013, 11:54 AM   #5828
Ok thanks I set it up like most of you guys with 5/7/5 also I'm here in s.Florida so in going 32.5 f / 30 r shocks for the weather.
... Thanks to all the tlr drivers who help us every day much much appreciated
Old 12-23-2013, 06:46 PM   #5829
Default gearing
I run on a small track I have 5.5 what is good pinon to start with.thanks
FLYINGBRIAN is offline   Reply With Quote
Old 12-23-2013, 06:53 PM   #5830
YANMAN's Avatar
Trader Rating: 38 (100%+)
I have scanned back 100 pages and either I missed it or it was further back. I am just wondering if the 8ight 3.0e radio box will fit on the 2.0? Lots of great info guys. SC is growing again so I am ready to get a new ride.
Bellgate Dist. / Highest RC Servos / Procircuit Tires
Nitro Pro Race Fuel
YANMAN is offline   Reply With Quote
Old 12-23-2013, 06:57 PM   #5831
LosiRacer33's Avatar
Been having a ton of fun with the 2.0. It was pushing a bit on the short loose track so I'm gonna drop down from 5/7/5 diff to 5/7/3 to get a little more traction in and out of the corners. Man does this thing fly straight and flat though.
LosiRacer33 is offline   Reply With Quote
Old 12-23-2013, 07:05 PM   #5832
rcgod's Avatar
Trader Rating: 27 (100%+)
Here.
Official TLR TEN-SCTE 2.0 Kit Thread-preview_image_0_96553732x_zps5af26601.jpg
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-23-2013, 07:26 PM   #5833
YANMAN's Avatar
Originally Posted by rcgod View Post
Here.
Perfect, thank you. I will ordered the box with the kit!!!
Nitro Pro Race Fuel
Old 12-24-2013, 08:14 PM   #5834
lowspark's Avatar
Bearing list for the Losi 2.0
4 5x8x2.5 steering
6 12x18x4 diffs
4 5x11x4 diffs
4 10x15x4 hubs
4 6x12x4 hubs
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 12-24-2013, 08:31 PM   #5835
4 5x8x2.5 steering
6 12x18x4 diffs
4 5x11x4 diffs
4 10x15x4 hubs
4 6x12x4 hubs
thanks my lhs had a avid set so i picked them up.... truck needed them had some bearings that were not smooth at all.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
