Like Tree4Likes
Old 12-12-2013, 08:03 AM   #5791
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by sbrewer View Post
Hello everyone I am fixing to start running the 2.0 rather than reading all 386 pages I thought I would just ask what are the most common things everyone's doing. you can pm me if you would like I would appreciate ant help
The truck is solid out of the box. Get the option springs and run the Dunford setup on Casper rc and it's dialed.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-12-2013, 10:50 AM   #5792
sbrewer's Avatar
Trader Rating: 20 (100%+)
Awesome Thank You
- AKA - Team Associated - Dark Side RC Racing - Os Speed - Jc Designs - Futaba - Boca Bearings-
sbrewer is offline   Reply With Quote
Old 12-13-2013, 10:52 PM   #5793
Default scte setup
I spent the day enjoying Ryan's exact setup. Just notice my rear is a little too loose. Next week I'll just modifying my diffs to 5-5-2. Track is indoor clay, medium grip tight track with sharp corners.
I only have 5% drag break but my truck nose dives really fast. Cant give it much gas because of turn right after.
braderb is offline   Reply With Quote
Old 12-14-2013, 07:37 AM   #5794
hkrob's Avatar
Trader Rating: 18 (100%+)
On Ryan's setup he has the battery forward. You could try running it in the middle or rear position if your rear end is loose and your nose heavy.
hkrob is offline   Reply With Quote
Old 12-15-2013, 04:48 AM   #5795
Does anyone know where I can buy the MIP replacement pucks besides MIP directly? The pucks don't last very long and paying list price is going to add up fast.
potatobed409 is offline   Reply With Quote
Old 12-15-2013, 05:21 AM   #5796
rcgod's Avatar
How long do the pucks last? $6 for 8 doesn't seem bad unless you have to replace them every race day.
Dialed RC Hobbies
Old 12-15-2013, 06:22 AM   #5797
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I couldn't get my kit to feel like it was in the dirt so I added 40g to the front and 65 to the rear. It really helped. Before it was skating and loose. Now I can put the power down. More testing this week with more motor and hoping to get it even faster.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 12-15-2013, 11:44 AM   #5798
kingofcool999's Avatar
Why add weight instead of going to softer springs or softer inserts in the tires?
*** THIS SPACE UNINTENTIONALLY LEFT BLANK ***
kingofcool999 is offline   Reply With Quote
Old 12-15-2013, 12:21 PM   #5799
Default Tekin 4300 w/ Mamba Max Pro
Beginner here looking for some advice. I purchased a Ten SCTE RTR. The stock ESC on it burnt out after 3mo. of use and I purchased a MMP to replace it. The stock motor is good but I now realize that it too needs to be replaced as well to stay competitive although, I did have success racing the truck right out of the box. I'm considering buying the Tekin 4300 motor and would like to know if this would be a good replacement to run w/ the MMP? Anybody got this set-up with some knowledge to offer me some advice?
Banjoblue is offline   Reply With Quote
Old 12-15-2013, 12:47 PM   #5800
ta_man's Avatar
Trader Rating: 151 (100%+)
It doesn't have to be replaced to be competitive.
In the A-main of the inaugural race of a new track near me the track owner, running a SCTE with an RX-8 and a Pro4 4600, was beat by another driver running an out of the box stock SCTE 1.0 RTR with no changes other than going up 1 tooth on the pinion and mounting up a set of Holeshots. He was given that RTR SCTE by the owner the week before as partial payment for his work in building the driver stand for the new track. For the whole race, the track owner and the other driver were not more than about 10-20 feet apart. The RTR won by 0.6 seconds. The RTR also TQed.
ta_man is offline   Reply With Quote
Old 12-15-2013, 01:43 PM   #5801
BmainStar's Avatar
Have not been racing lately but did get the chance yesterday,and to my disappointment had two dnf `s in one night.1st qual lost the rear drive shaft, it blew up and lost the bearing as well.2nd qual did ok, Main event, sittin 2nd on the grid get one lap in and the right front drive shaft blew I
Don't run indoor much but the Truck was hooked up and it felt great!!
Oh well, that`s why they call it Racing and not Fishing.....
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 12-15-2013, 04:52 PM   #5802
I'm changing them around 10-12 packs. The rear pucks last longer but the fronts wear out fairly quickly. I'm assuming it's because of the offset.
Old 12-15-2013, 05:11 PM   #5803
UN4RACING's Avatar
Our track is black top soil hard packed. When the top dries out its like driving on baby power at times. I have tried about every thing possible but even on a high bite night its like the kit is just to light. Adding the weight really made the kit feel more planted and a lot more consistent as well.. Its looking like no one has done this yet? I will post again once I mount a motor with more spunk. The 4600 is good but just a little soft on the bottom end. The softer insert wont help much on a hard pack. I'm have the best result so far with aka reds and rebar soft and super soft tires. The gridirons are working as well.
I'm heading over to the Tekin Hd thread. Any input on the 4300 vs the 4000 would be great. Our track is a medium size and just looking to get a motor with a strong bottom end snap. I have a 4300 HD to test with tues. But no 4000 HD to borrow on hand.
Old 12-15-2013, 05:37 PM   #5804
Currently building some diffs and while having difficulty getting some as smooth as I would like I have found a huge range on the gasket thicknesses supplied with my kit. I had varying sizes from .018" to .033". Is there a part #s for the various thicknesses?
Mike B is offline   Reply With Quote
Old 12-15-2013, 06:14 PM   #5805
UN4RACING's Avatar
I'm a guppy with this kit but I was told by one of the racers familiar with the kit that the thick ones are for the heavy duty diff. Not sure of the measurements.?
