Like Tree4Likes
Old 11-30-2013, 08:37 PM   #5731
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
Hello peeps..I am currently running the 2-11-13 set up on my 2.0 and like it pretty well but was wondering how the latest set up 7-1-13 compares to the original set up? I am getting these set ups on Casper's site..
Thanks,
rifraf is offline   Reply With Quote
Old 12-02-2013, 09:35 AM   #5732
Casper's Avatar
Trader Rating: 33 (100%+)
Ryan and I run the 7/1/13 setup most everywhere. We will need to post up a blue groove setup soon as we run some slightly different settings for shock diff and rear camber link for high traction conditions but the 7/1 setup has more agressive steering while still not sacrificing rear traction. The Feb setup is a little more tame and easier to drive but has a little bit of a push to it.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-02-2013, 01:50 PM   #5733
Send a message via AIM to zuki250
Hey guys...I have been running on a tight indoor track...packed clay...I am getting a lot of push on power around corners...any good tips to help this out? I am new to racing and tuning for that matter...you don't have to tune much when you bash...hahaha
zuki250 is offline   Reply With Quote
Old 12-02-2013, 02:13 PM   #5734
Casper's Avatar
What is your setup right now?
Old 12-02-2013, 02:20 PM   #5735
I think its basically stock set up...bought it used with one day of use on it
Old 12-02-2013, 04:35 PM   #5736
Casper's Avatar
I would double check the setup.
I have two good setups posted here.
http://www.casper-rc.com/
The latest one is more agressive on the steering dept and what we run now. We used this setup this past weekend on a smaller size track and both of our trucks were really good. (that being Ryan and I)
If the truck is used and you don't know the setup it would not be a bad idea to rebuild the shocks and the diffs just to know for sure what is in those.
Remember droop settings (now much you unscrew the bottom of the shocks) and ride height are important.
Old 12-02-2013, 04:48 PM   #5737
Thanks Casper..
Old 12-02-2013, 05:11 PM   #5738
banana rt's Avatar
hey casper any suggestion for rough dusty low grip track set up? thx for helps
No guts No glory
banana rt is offline   Reply With Quote
Old 12-02-2013, 06:49 PM   #5739
Servo suggestions.
Most common appear to be Savox and hitec.
I have a savox 1258tg currently. Within months, it does not turn nearly as sharp on carpet. Gears are fine. Torque burnout???
I hear good things about hitec.
braderb is offline   Reply With Quote
Old 12-02-2013, 06:51 PM   #5740
TCCustoms's Avatar
Originally Posted by braderb View Post
Servo suggestions.
Na, Spectrum S6040 is a great one and not power hungry
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 12-02-2013, 07:14 PM   #5741
Servo suggestions.
give it 7.4v with your RX8 gen2 and you will be happy.
rob4448585 is offline   Reply With Quote
Old 12-02-2013, 07:25 PM   #5742
rcgod's Avatar
Trader Rating: 27 (100%+)
Servo suggestions.
Did you check the servo saver?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-03-2013, 05:25 AM   #5743
TCCustoms's Avatar
+1... if u haven't completely tightened then backed off 2-3 turns and loctited the screw that would be the first place to look
Old 12-03-2013, 09:55 AM   #5744
Originally Posted by travymoto11 View Post
Can someone help me out here. Doing a rebuild for the first time on my truck. With regards to the steering turnbuckles.....the manual has you build the steering links with the outside rod end pivot flange up and the inside pivot flange up. I know at one point Ryan came on here and said run both flanges up or down...just cab't remember which one. Thanks in advance to anyone that can set me strait.
The angle of the steering link effects the bumpsteer, you can check this easily by watching the toe change when pushing the suspension up an down. I usually use a straight edge against the tires to help see the change in angle. In general if you move the inner camber link down you need to move the inner steering link pivot down as well or the outer link up to prevent bumpsteer. I totally disagree with using bump steer as a tuning option on any off road vehicle (and almost all on road) because it makes the car unpredictable every time the front suspension is compressed. I think way too many people just blindly use whatever their favorite setup sheet recommends. If you learn to measure it yourself you can easily set the bumpsteer on any vehicle
Brian Watson
http://vectorworksrc.com/
Carbon Fiber RC Upgrades
dirtracin58 is offline   Reply With Quote
Old 12-03-2013, 10:29 AM   #5745
Speaking of this. On the setup sheet from Casper it says to use camber link position 1 but when I do this it interferes with the sway bar link. I try to move them out of the way a little but it just doesn't seem right.
Again thought like you said I never really did proper testing to know if 1 is what is best for me.
JS70 is offline   Reply With Quote
