Like Tree4Likes
Old 11-28-2013, 10:13 AM   #5701
hkrob's Avatar
Trader Rating: 18 (100%+)
Originally Posted by BmainStar View Post
Any one running the new MIP torque rods ?Do vthey feel too stiff? Thanx>>>> RACE ON !!
I installed MIP torq rods & puck drive shafts last night they are high quality & well made. The MIP shafts take out all the slop from the center drive lines all you feel now is the ring & pinon backlash from the gear case. Going to run it Saturday we'll see how she does.
hkrob is offline   Reply With Quote
Old 11-28-2013, 01:05 PM   #5702
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I've been wondering about the MIP driveshafts. I'd like to see some folks run them for a few weeks before I spring for them. I'm still running the 1.0 setup so the front shaft sees quite a bit of wear. I would like to do something about that. Happy Thanksgiving everyone!!!
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 11-28-2013, 04:09 PM   #5703
Trader Rating: 19 (100%+)
Can someone help me out here. Doing a rebuild for the first time on my truck. With regards to the steering turnbuckles.....the manual has you build the steering links with the outside rod end pivot flange up and the inside pivot flange up. I know at one point Ryan came on here and said run both flanges up or down...just cab't remember which one. Thanks in advance to anyone that can set me strait.
Travis Adams
Moto1 RC Painting
[email protected]
facebook.com/moto1rcpaint
travymoto11 is offline   Reply With Quote
Old 11-28-2013, 05:43 PM   #5704
lowspark's Avatar
Default Shock length
A simple question and I am sure there is a simple answer to it.
Looking at Ryans set-up sheet in the first post he notes his shock length as 'Full plus 2 turns' on the front shock and 'Full plus 1 turn' on the rear shock.
Does this mean the end is threaded all the way on and then threaded on an additional 2 turns to make the over-all shock length shorter? Or do I un-thread the shock end 2 turns to make over-all length longer?
And I am going to assume that a turn is a full 360 degrees.
thanks for the help
Cliff
lowspark is offline   Reply With Quote
Old 11-28-2013, 05:46 PM   #5705
Trader Rating: 120 (100%+)
Unthread it to make it longer and yes a full 360 degrees.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 11-28-2013, 05:46 PM   #5706
BmainStar's Avatar
Originally Posted by kingofcool999 View Post
I've got a set on mine. Fit great, look great, don't really notice a difference vs. stock, except the MIP's don't break.
Good to know!!!Thanx!!
Report back
Robin for sure.I think on the TLR chassis truck it will be perfect the BCE truck may be to stiff..WE`ll see thanx for the replies guys Happy Thanxgivin!!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 11-28-2013, 05:49 PM   #5707
Moderator
bds81175's Avatar
They are actually unscrewing the shock end a turn to increase the shock length. So they have the droop screws completely backed off and the shock length increased to increase the droop even more.
Tekno RC
Old 11-28-2013, 05:51 PM   #5708
in my opinion the torque rods with the bce chassis makes it to stiff.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
Old 11-28-2013, 07:31 PM   #5709
lowspark's Avatar
Thanks for the info guys,
this website rocks...
Old 11-29-2013, 07:38 AM   #5710
Does anyone know the part # for the pins that hold the outdrives in?
The manual shows LOSB3568 Diff Seals/ Shims/ Pins & Gasket: Which is a o-ring, gasket and washer set with the pins. I find it odd you have to buy these extra parts every time just to get the pins that should have been included in one of the parts I purchased below.
I purchased
LOSB3576 Losi Center HD Lightened Outdrive Set
TLR332001 Team Losi Racing HD Differential Housing w/Integrated Insert
LOSB3569 Losi Differential Gear Set w/Hardware
JS70 is offline   Reply With Quote
Old 11-29-2013, 12:01 PM   #5711
Valid point, but its only $4 for the kit, hardly a deal breaker
rob4448585 is offline   Reply With Quote
Old 11-29-2013, 12:46 PM   #5712
I agree but is a bit sketchy to not have them available or send with one of the kits.
TLR232002 I am not sure which pins these are. The ones we need are a 2mm x 10
Old 11-29-2013, 01:14 PM   #5713
rcgod's Avatar
Trader Rating: 27 (100%+)
http://www.amainhobbies.com/advanced...x10mm&x=9&y=13
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-29-2013, 04:23 PM   #5714
Originally Posted by rcgod View Post
Thanks RC. I was searching that same site but using the wrong key words like 2mmx10mm and nothing came up pins.
It really was not so much about the cost but the aggravation of buying everything to build 3 spare diffs to swap in to find out I had to pull all the old ones to get the pins out.
Old 11-29-2013, 08:15 PM   #5715
wever75's Avatar
Default Losi scte motor & ESC
I need a good motor and ESC combo or my losi scte. Will be running I 2s lipos an would like it to be around 4600kv. Spending limit is $330! Thanks all!
Rest In Peace Bill Bridges
wever75 is offline   Reply With Quote
