Like Tree4Likes
Old 11-24-2013, 07:58 PM   #5671
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
Upgrades really are not needed,however I did get a king heads duel bearing center diff mounts and the center drive pin holders/rubber boots. also the TLR front top steering plate.
Welcome to the REALLY FAST side of 4x4 SC racing............
rifraf is offline   Reply With Quote
Old 11-24-2013, 08:15 PM   #5672
Originally Posted by frito View Post
Ok guys been running a tekno and just sold it ,and new 2.0 be in we'd. Any common spares or weak links, or upgrades to do right off
Get the tekno center drive shafts. The Losi ones snap the pin in the Cvd.
87MagnumII is offline   Reply With Quote
Old 11-24-2013, 08:18 PM   #5673
muggy427's Avatar
I would recommend the turnbuckles for the torque rods common break For me also drive pins
muggy427 is offline   Reply With Quote
Old 11-24-2013, 08:37 PM   #5674
Though i'd share a pic..
Old 11-24-2013, 09:43 PM   #5675
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Just finished a new build. First time with an SC. 2.0. The build went real well. The only hick up is with the diff cases. The bearings almost had to be pressed on. I'm pretty sure when a bearing goes bad I will have to replace cases and bearings...?
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 11-24-2013, 09:49 PM   #5676
No sir..you can take a small flat blade screwdriver and work it around the bearing and it will slowly come off..
Old 11-24-2013, 11:03 PM   #5677
urluzn's Avatar
Trader Rating: 28 (100%+)
MIP puck system and center gear IMO is a must. Super smooth drivetrain.
Team Associated~ Reedy~ Proline~ EZcustoms~ FDJ
urluzn is offline   Reply With Quote
Old 11-25-2013, 05:22 AM   #5678
The MIP pucks drive lines are nice but added maintenance. You have to replace the pucks every other session with the car or that's what I have to do at least. The only parts I've had break was a ball cup kept pulling off a turnbuckle and the left rear drive shaft broke.
potatobed409 is offline   Reply With Quote
Old 11-25-2013, 06:22 AM   #5679
carbons2k's Avatar
Trader Rating: 21 (92%+)
Does anyone know what the stock degree of caster is in the front? I was away this weekend and noticed that when I took caster out of my 4wd buggy (kyosho zx5) the car seemed to steer better. I went from 10* to 7& of caster... I was wondering if this concept would work with the SCTE as well. Any help?
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 11-25-2013, 07:49 AM   #5680
rcgod's Avatar
Trader Rating: 27 (100%+)
I believe stock caster is 10 degrees but not adjustable. Kick up is, and makes a noticeable difference in how much steering and where in the corner the steering is. I change it quite a lot depending on traction and track conditions.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-25-2013, 08:01 AM   #5681
carbons2k's Avatar
ok so If I wanted more steering, How would go about changing my kickup? Would I want more or less?
Tom Licata
Old 11-25-2013, 11:08 AM   #5682
skrichter's Avatar
Send a message via AIM to skrichter
Any plans for TiCn shock shafts for the SCTE?
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 11-25-2013, 11:15 AM   #5683
thebalance's Avatar
Default Drive shafts
Hey Guys,
I'm going to upgrade my drive shafts and outdrives. Anyone used the new MIP Pucks Drive System? I was also looking at the Tekno RC M6 Driveshaft & Lightened Outdrive Set. What do you guys recommend? Thanks.
thebalance is offline   Reply With Quote
Old 11-25-2013, 11:42 AM   #5684
rcgod's Avatar
Usually for more steering you want more kickup, but I've run into situations where I needed more initial steering and less kickup did it on a high bite track.
What setup are you running now?
Dialed RC Hobbies
Old 11-25-2013, 12:15 PM   #5685
urluzn's Avatar
Originally Posted by thebalance View Post
Hey Guys,
I've been using the puck system for a bit now and love it! It's super smooth. The pucks do wear like anything else being part of the drivetrain but is well worth the performance. I know some that has stated excessive wear to pucks but honestly mine have been in for a awhile however I haven't been running big power like some do.
