TLR TEN-SCTE 2.0 Kit Thread
#5641
Hey looking for some help here with my truck. When going over a jump on landing the rear of the truck keeps kicking out i run the on indoor clay and have the new dunford setup on it tryed changing the shock oil from 32.5 to 27.5 25wt and 30wt no change any ideas
#5644
#5645
I have a question when drilling pistons for the truck. To duplicate a #3 piston should you use the #58 bit or the #59 bit. It is suppose to be 1.05mm but I can not find a bit that size and want delron pistons?
#5646
The kit is cheaper if you want lots of different bit sizes.
#5648
has anyone had any problems with the diff screws winding out i am using the HPI screws and just found the front diff had leaked all the oil out. on inspection i found that i could get 1/2 - 3/4 turn -in- on the screws. i also found this happened to my center like straight away but tightened them before it leaked to much. and yes i did screw them in tight
#5649
if they are coming lose i think the housings are shot. its a metal screw going into a plastic housing, eventually they will wear out if you keep swapping fluids.
I do a diff fluid change every 2 weeks, but i'm also running the truck 3-4 times a week (2 race days and 1-2 long practice sessions).
#5651
#5653
Sand the diff cup a little,concrete works LOL as well after threading the holes
.....Cheers!!!.......
