TLR TEN-SCTE 2.0 Kit Thread
#5611
#5612
http://www.petitrc.com/setup/losi/se..._OCRC20121224/
Raise the rear hub ball stud to 3mm (sheet says 2mm) If you need more rear traction try dropping the rear oil by 2.5wt and maybe try the LF yellow or white rear spring.
#5613
Show me another 10th scale race car that has a box for the receiver? No 2wd buggy, 2wd truck or 4wd buggy has one that I am aware of. Why they need to add the weight to the 4X4? (sure there are lots of electric 8th scales, and the SC10 4X4 but we will argue if that is a "race" truck or not! I only see receiver boxes important in nitro to protect from fuel but that is my opinion. Most of the time when you see a box it is carried over from a nitro car and this was the case with the 1.0. With the 2.0 they looked at taking a much weight out of the truck as reasonable and this was one place were they saved some weight and made a better attachment for the servo as the old box and mount were a little compliant. The new setup gives better servo input and saves weight with very little risk to the receiver. If water proofness is required spektrum makes some water proof receivers! I have seen a few people make some cheap lexan covers as well.
Yes a quality servo tape holds the RX8 in just fine. I like MIP servo tape or I have been using some 5lb 3M tape I got at home depot that is working just fine. I would recommend putting two layers on to extra protection on hard flat landings.
#5614
That's what I'm talking about... Hey Casper I was thinking about running the mip turnbuckles.... Just haven't been able to accept spending 80.00 on turnbuckles. I guess the reason I ask that this is a 1/10 vehicle and do you think they need the 1/8 turnbuckles.
#5615
It is just hardware that was carried over from the 10-T which was not really meant to become the SCTE but it did. You can run smaller steering links no problem. If you upgrade to titanium 8ight 2.0 turnbuckles the weight is not so bad. Only issue I have with the MIP stuff is it uses 4-40 hardware where the SCTE was designed around 5-40 hardware so not sure how they took up the slop in the hardware holes but maybe it is not that bad. with that being said I have broke and/or bent 4-40 tie rod but never even thought I could with the stock Ten tie rods. Overkill sure, piece of mind I will take knowing I never have to replace one and the minor weight penalty.
#5616
Someone has already posted about using the 8-E-3.0 RX box for the receiver.
For the ESC, I mounted a Tekno ESC tray to my chassis (drilled and countersunk the chassis) and then you can screw the RX-8 to the tray and put a plastic wire tie around it for additional insurance.
Ive personally seen FAR too many "Servo taped" RX8's come loose and start FLOPPING around, Tugging on wires and Messing up sensor wires. I DO NOT Suggest Servo tape or Kyosho Gel or anything that has the possibility of letting go during a race.
#5617
My Activ8 has been shoe goo'd down since the truck came out feb/mar and I haven't had any issues. Definitely the way to go.
#5618
I shoo goo my ESC down in my SCTE. It's the only way to be sure - especially if you're running on 1/8 style tracks. Indoor 1/10 tracks usually won't have the jumps or tumbles big outdoor tracks will.
http://www.homedepot.com/p/Scotch-1-...5#.UoEI-_m9lik
It all comes down generally to proper surface prep. (aka clean!)
#5621
Shoe goo is great stuff but dries quite hard. It does have the benefit of sticking well can coming off fairly easy. If you have clean dry surfaces servo tape should work well. A quite wipe with some alcohol on both surfaces and servo tape should work great. I have had my cars go over many a VERY large jump and servo tape works great.
http://www.horizonhobby.com/products...FU8V7AodJBkAJw
#5622
Also there is something called Zap Goo that I get at my local hobby store. I servo tape the esc and the use the Zap goo around it. It dries hard but when you go to peel it it comes off very easy and clean.
#5624
i see on the team driver set up sheets they are using #3 and #4 shock pistons, ive looked around and cant find these or any info on them, does anyone know what part number these are or any info on them, like hole size for each and are they machined ECT. does anyone have a good piston chart with what pistons are what? like what is a #55 vs # 54 piston. ive seen the piston kit listed on horizon, but it dosent say what they are.
#5625
