Like Tree4Likes
Old 10-23-2013, 05:19 PM   #5506
seabass17's Avatar
Trader Rating: 40 (100%+)
Rpm rear bumper and mount, body mounts, front arms, center shafts from tekno.
These trucks really do not break parts but these are the things I have replaced on my truck. Cracked one arm which is why I replaced.
http://www.p1hobbies.com
http://www.vpprousa.com
http://www.builtrc.com for all your hobbywing needs!
seabass17 is offline   Reply With Quote
Old 10-23-2013, 05:23 PM   #5507
silveraider14's Avatar
anybody ever had a solid red light on a r10 pro 2-3s?
I am running a orion 550 vst 4.0 motor.
already asked on the r10 pro fourm and didn't get much help. just seeing if anyone else was having this problem?
B5m - speedpassion.net
Timewarp R/c Raceway
silveraider14 is offline   Reply With Quote
Old 10-23-2013, 05:39 PM   #5508
eddomak's Avatar
Originally Posted by CookieFlow View Post
Hey guys,
I read through some pages on this thread, but there are over 360 of them
Welcome! Hah hah, you should try reading the SCTE 1.0 thread.
Anyway, I have had my SCTE 1.0 for 2 years now and don't "bash" per se, but then again I don't race (so am not really trying to take the low risk & low damage route to make it to the end). In any case all my friends are so amazed at the durability of the SCTE that they have now all got them as well.
I have not truly broken any part except the body. The rest was wear and tear. The original chassis from the 1.0 bent, but you have a 2.0. ALthought I have replaced one front A-arm due to bending after a full speed crash into a light pole, I don't think it's worth it to have one on hand. Better to buy one in the UK if you really need it at that time.
Perhaps consider the kingsheads cvd pin keeper which will prevent the pin in the coupler from eventually working its way through the plastic collar. This is less necessary now as there is a set screw built into the coupler in the new design, but sometimes it still manages to work loose. If you get the Tekno centre driveshafts then don't worry about this piece as they have a metal ring collar in their design.
You might also want to consider some serrated locking nuts for the wheels (any brand you like). Sometimes the originals on the 1.0 would come loose. It did for me only on one axle, but since using serrated nuts no problems.
Also you could consider the LOSA6285 left hand threaded screws for the front right and rear left shock mounts. Sometimes, due to the action of the suspension, standard thread screws will work loose. These ones go the other way so they don't go loose.
Losi SCTE 1.0 - BCE Chassis, Hobbywing SCT Pro, Hobbywing XERUN 3656SD 4000KV, Hitech HS-7955TG
TLR 22T - Orion R10 Pro, Turnigy 10.5T 3250KV
Axial SCX10 Honcho | Traxxas Mini Summit VXL | Losi Micro Desert Truck | Tamiya Boomerang
Airtronics/Sanwa MT-4 | Flysky GT3B - Custom firmware
eddomak is offline   Reply With Quote
Old 10-23-2013, 06:26 PM   #5509
CookieFlow's Avatar
Thank you very much guys
That is great news, less money to spend!!
What about these parts :
King Headz Motor Mount w/Dual Bearing
[KHZ-SCTE-036]
King Headz Center Differential Front Upright w/Dual Bearing
[KHZ-SCTE-035]
FTW R/C Carbon Fiber Ackerman Set (2)
[FTW00014]
MIP TEN-SCTE Mod1 Spur Gear (41T)
[MIP12199]
They have a good amount of nice comments on Amain, but maybe it's more upgrades for the 1.0?
Thanks !!
Edit : another noob question, I was looking for something like we can see here at 2:22 (It probably has a name, sorry ):
http://www.youtube.com/watch?v=e1iK2hPHx7Q
to put on top on the side guards when bashing, but I can't find any on Amain.
Are those kind of stuff hand made, doesn't exist for the SCTE 2.0, or I just suck a searching?
CookieFlow is offline   Reply With Quote
Old 10-23-2013, 06:44 PM   #5510
Hey guys,
I am fairly new to the hobby and just bought a used (but perfect condition) SCTE 2.0 on this forum. I read through some pages on this thread, but there are over 360 of them
I wanted to order some spare parts to have in stock, but have no information on what is most likely to break on this truck? Or if there are some necessary upgrades to make? I heard that the Tekno RC Front//Rear-center driveshafts are a must.
I won't be able to go on the track much because of the winter coming, so I will probably do some light bashing.
Since I live in Europe, it's not as easy to get parts, so I wanted to make one big order on Amain.
Thanks for you help
A set of the dog bones, the diff out drives, spur gear, all the wheel bearings, diff rebuild kits (seal, fluid).
ctuinstra is offline   Reply With Quote
Old 10-23-2013, 07:05 PM   #5511
eddomak's Avatar
[KHZ-SCTE-036]
[KHZ-SCTE-035]
[FTW00014]
[MIP12199]
Thanks !!
I guess the answer to a lot of your questions comes down to whether you are racing or not.
The Kingshead centre mounts may have helped address outdrive wobble (particularly with the 1.0 when there was a steeper angle between the centre diff to front diff). Some people liked it because it gave them more reliability. Probably most people have been fine without it.
The CF ackerman is more bling than a requirement.
The MIP Spur gear gives you more very-fine tuning options, but non-racers probably find that a simple change in pinion was enough. The spur gear was like half way between 1 tooth change in the pinions.
Those lexan pieces are commonly called side pods, some use it to stop debris flying into the chassis, others used it to prevent airflow and adding to the parachute effect. I don't know if there are any made for the SCTE 2.0. You might be able to find some Outerwears to protect from debris.
Old 10-23-2013, 07:07 PM   #5512
sanny632's Avatar
Trader Rating: 17 (100%+)
I got the king headz diff mounts LOVE THEM
TLR-SCTE 2.0 TLR-8-e 3.0 Tlr Micro Brushless SCT Team Losi Jrx2. Custom Works SE-3 Custom Works GBX-3 HPI RS4 Pro Chatioc Crawlers Switch xr10 Mattzilla scx10 trugge Axial Wraith
sanny632 is offline   Reply With Quote
Old 10-23-2013, 08:11 PM   #5513
RiceP's Avatar
Trader Rating: 70 (100%+)
The king heads is great it will save your drives and bearings a for sure up grade. Would not recommend the mip spur it wears to fast IMO just buy stock one as spare. And the ankerman if u have carbon on the 2.0. If you are building up a supply spend money on arms, spur, shock plastics, maybe body mounts, then get a few high discharge high mah lipos and have fun
RiceP is offline   Reply With Quote
Old 10-23-2013, 09:19 PM   #5514
drepus's Avatar
if your throttle trim is advanced slightly the red light comes on solid and you should hear the motor barely trying to start spinning
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 10-24-2013, 12:10 PM   #5515
CookieFlow's Avatar
Thanks so much for all the tips and detailed answers guys
There is just so much information when you start a new hobby like RC, it's hard to keep track of everything
Does the outerwear protection prevent even a little bit of dust and allow a good enough amount of Air flow for the electronics? It's seems super expensive for a piece a fabric
Also sad there are no discount coupons for the moment on Amain
Edit :
I was thinking of getting a second body, do you guys have any suggestions?
I was looking at :
JConcepts Illuzion "Ford Raptor SVT X-Flow" Short Course Truck Body (Clear) (One Size Fits Most)
[JCI0205]
JConcepts Illuzion "Hi Flow" Short Course Truck Body (Clear) (One Size Fits Most)
[JCI0222]
Pro-Line Flo-Tek Ford F-150 Raptor SVT Body (Clear)
[PRO3366-00]
Pro-Line Flo-Tek Body (Clear) (Slash, Slash 4x4, SC10)
[PRO3355-00]
For the last one, they say it's not compatible with the SCTE, is that correct?
Thanks again!!
Old 10-24-2013, 01:37 PM   #5516
Edit :
I was looking at :
[JCI0205]
[JCI0222]
[PRO3366-00]
[PRO3355-00]
Thanks again!!
The last one works just fine, it is my body of choice, and what I have used with great success for many months.
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 10-24-2013, 05:12 PM   #5517
ok I will give it a try.
thanks
Old 10-24-2013, 05:32 PM   #5518
jpk4ud's Avatar
Ok I have an scte and love it. What would be the best reasons to upgrade to the 2.0? I am thinking of getting a second truck and I want to know if there is that much difference between the two chassis.
Losi SCTE
Losi 22SCT
Slash 2wd
TC5 set up for USGT
The Hobby Shop in Dayton, Ohio
jpk4ud is offline   Reply With Quote
Old 10-24-2013, 05:42 PM   #5519
Casper's Avatar
Trader Rating: 33 (100%+)
The 2.0 has better balance for increased corner speed and better traction on corner exit. All the things you love about the 1.0 and more.
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-24-2013, 06:15 PM   #5520
jpk ... i'll turn down the horsepower and you can try mine...
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
