Like Tree4Likes
Old 10-14-2013, 06:19 PM   #5431
eddomak's Avatar
Originally Posted by kenexcelon View Post
I hate to ask a silly question, but could you point me to a correct pinion? I thought I found one but part compatibility was only listed for the 8 scale buggy from Losi. Would I need to change the spur gearing as well?
Thanks!!!
Any "MOD1" Pinion would be fine, and pick your number of teeth (14T, 15T) - Here's a list of them from Amain:
https://www.amainhobbies.com/advanced_search_result.php?keywords=pinion+gear+14 t+mod&x=0&y=0
No need to change the spur.
I have tried the Novak, and the Robinson Racing, but I can't remember which one was quieter.
Losi SCTE 1.0 - BCE Chassis, Hobbywing SCT Pro, Hobbywing XERUN 3656SD 4000KV, Hitech HS-7955TG
TLR 22T - Orion R10 Pro, Turnigy 10.5T 3250KV
Axial SCX10 Honcho | Traxxas Mini Summit VXL | Losi Micro Desert Truck | Tamiya Boomerang
Airtronics/Sanwa MT-4 | Flysky GT3B - Custom firmware
eddomak is offline   Reply With Quote
Old 10-14-2013, 06:53 PM   #5432
TCCustoms's Avatar
Interesting as they have the same one not refurbished for 10 dollars more currently on sale here. Is it worth it still to get the refurb? I didn't see a package deal with the programmer card, is there one?
Thanks!
the link that you posted and it says here in your post...scroll down and you will see the COMBO's and the 4000 and 4700 are popular combos but you cant get it jsut as the ESC and card....has to be the ESC, CARD, and MOTOR!
Just click on the COMBO in blue and it will take you to the combo page
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 10-14-2013, 07:43 PM   #5433
I saw those, but already have a motor so didn't want a complete combo. I'll just get the program box separately. Thanks guys.
kenexcelon is offline   Reply With Quote
Old 10-14-2013, 07:55 PM   #5434
TCCustoms's Avatar
buy the combo and sell the motor...i ran the 4700 motor for a short time and wanted the 4000 and sold the 4700 within the first day or 2 i had it listed.
But thats up to you...and if you can flip the full bill till you sell the motor but good luck!
Old 10-14-2013, 08:48 PM   #5435
carbons2k's Avatar
Trader Rating: 21 (92%+)
I'm running 41/13 and its perfect for indoor tracks. Great punch with not too much top speed.
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 10-14-2013, 10:15 PM   #5436
Thanks RC God
Sivaaji is offline   Reply With Quote
Old 10-14-2013, 10:34 PM   #5437
I'm rebuilding my Center diff with the new hd diff housing but for some reason the Center spur gear doesn't want to fit .it seems the hole on the spur gear is a bit to small.anyone have this problem?
dmorash is offline   Reply With Quote
Old 10-15-2013, 12:05 AM   #5438
silveraider14's Avatar
anybody got a idea for gearing with a orion 550 4.0t?
gonna be running at leisure hours raceway indoor track.
also gonna be running the mip 41 tooth spur.
I will also be using a orion r10 pro esc. blinky software or mod software?
thanks
B5m - speedpassion.net
Timewarp R/c Raceway
silveraider14 is offline   Reply With Quote
Old 10-15-2013, 04:44 AM   #5439
TLRacing
thanks
I run the Orion 550 4.0T with an 11 pinion and 40T spur.
I don't run the software in blinky.
TLR-Team Losi Racing, Team Orion, Pro-Line, Spektrum, Nitrotane, Horizon Hobby, Darkside Designs, StickIt1 Racing, Lunsford, OCRC, LiveRC, RC Scoring Pro, AMS, & Stateline
Dakotah Phend is offline   Reply With Quote
Old 10-15-2013, 01:30 PM   #5440
ok thanks!
Old 10-15-2013, 01:42 PM   #5441
hkrob's Avatar
Trader Rating: 18 (100%+)
Thanks!!!
This is what you need
http://www.amainhobbies.com/product_...inion-Gear-14T
http://www.amainhobbies.com/product_...inion-Gear-15T
hkrob is offline   Reply With Quote
Old 10-15-2013, 06:49 PM   #5442
Thanks TCCustoms for the response. I can swing the full combo, but just don't want to lose any money if the motor doesn't sell well enough to cover the difference. Perhaps I could use the motor to upgrade my Traxxas Slash at a later time along with a better ESC anyway. Before I pull the trigger, does it matter if the SCT-PRO is not dual drive mode capable?
I appreciate all the help guys!
Old 10-15-2013, 07:30 PM   #5443
TCCustoms's Avatar
Dual drive...Is that sensored and non? If it is, then yes is works both ways and obviously the sensored is smoother since it knows the rotor location but its not a huge difference
Old 10-16-2013, 06:59 AM   #5444
To be clear, specifically the automatic switching.
Old 10-16-2013, 05:35 PM   #5445
eddomak's Avatar
The SCT Pro automatically switches from sensored to sensorless mode in the event there is a problem detecting the sensor signal (eg broken wire, loose plug etc), and it is instantaneous.
It doesn't support what Castle calls SMART Sense, which is starting up in sensored mode at low speeds, then switching to sensorless mode for high speeds, then switching back again.
