Like Tree4Likes
Old 10-09-2013, 07:23 PM   #5371
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
hello,I am building a scte 2.0 by the set up on page 1 and it calls for #55 2 hole losi 22 pistons.I am buying everything from a-mainhobbies they show out of stock for these losi shock pistons.Is there any other manufacturer that makes this same piston?
Thanks Tommy,
rifraf is offline   Reply With Quote
Old 10-09-2013, 07:53 PM   #5372
rcgod's Avatar
Trader Rating: 27 (100%+)
Thanks Tommy,
TLR2333007
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 10-09-2013, 08:11 PM   #5373
Originally Posted by rcgod View Post
TLR2333007
I guess a-main does not stock that part # does not come up with the search bar..
Old 10-09-2013, 08:49 PM   #5374
CarlCrocco's Avatar
Trader Rating: 88 (100%+)
Sweet deal on some premounts for the Losi SCTE 2.0
Massive 4x4 SCT Tire Lot, fits Tekno SCT410 and Losi SCTE 2.0
Andrew Crocco "The Hammer"
Viper R/C
XB9E XSCT
CarlCrocco is offline   Reply With Quote
Old 10-09-2013, 09:22 PM   #5375
rcgod's Avatar
http://www.amainhobbies.com/product_...ton-Set-4-13x2
Sorry wrong part number. Here it is.
Dialed RC Hobbies
Old 10-09-2013, 09:42 PM   #5376
Thank-you Sir..
Old 10-09-2013, 09:46 PM   #5377
Trader Rating: 15 (100%+)
You may know but the latest setup from ryan uses pistons that come in the kit. They work really good imo. http://www.casper-rc.com/images/TEN_..._13_reduce.pdf
Tommygun1 is offline   Reply With Quote
Old 10-09-2013, 10:10 PM   #5378
Yeah.this is my 2nd scte 2.0.I used page 1 set-up and it worked really well on my track,but I do plan to try this set-up as well..
Old 10-10-2013, 06:07 AM   #5379
+1 on this new setup. My teammate tested literally every possible setup variation since he got his 2.0 last winter, with the two-hole pistons and everything. This new setup is, by far, the best overall setup we've tried. Truck works great everywhere, even outdoors. I have it on my new 2.0 and I love it. It makes a hack like me look fast!
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 10-10-2013, 08:13 AM   #5380
ironzgti35's Avatar
Trader Rating: 20 (100%+)
That setup shows running a pro4 hd 4300 with 35 timing advance...is that a typo?
ironzgti35 is offline   Reply With Quote
Old 10-10-2013, 08:30 AM   #5381
We don't run that timing (we run no timing), but would like to hear Ryan's theory behind the significant timing advance on the 4300HD and the use of the slight drag brake. Our track is so small that I run a 13 or 14 gear with 4300HD motor and the stock 40 spur. If these guys are running a 16, they must have massive straightaways.
Old 10-10-2013, 09:41 AM   #5382
If you run on a small track, I can understand your gearing and your settings for sure.
At the tracks in socal, they are pretty big...35 on timing setting is around 10-11 degrees of timing, Its more than most would want to run but I have a pretty soft throttle finger from days of racing parking lot races.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 10-10-2013, 09:53 AM   #5383
Ryan, you still run the slight drag brake? How does this help in your application?
Old 10-10-2013, 09:56 AM   #5384
And how does the timing help in your circumstance?
Old 10-10-2013, 09:58 AM   #5385
I try to stay on throttle as much as possible, the slight drag brake helps when I lift for a moment, it can help the car rotate a bit faster.
As for the timing, it gives more top end on the straight is all.
-Ryan Dunford
