Like Tree4Likes
Old 10-03-2013, 09:56 AM   #5341
Originally Posted by eddomak View Post
Hi,
I am about to receive some GensAce 5300mah 30C's, and was wondering if the C rating might be a bit low for SCTE with my combo of HW3656SD 4000KV. Anyone got any experience with these particular packs? Would they be OK with the SCTE RTR motor (mate's truck).
Thanks!
As have been said, it will WORK, but my 40c GensAce seem unhappy as well.
I would shoot for something around 70c+ I have a feeling that will be a good result.
rob4448585 is offline   Reply With Quote
Old 10-03-2013, 10:06 AM   #5342
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by rcus3r View Post
Scratching my head...
Looking at the two tuning guides (JQproducts and HUDY). I found a discrepancy in description roll center adjustment, which makes me question which guide to rely on.
In HUDY: Front - Lower hole on shock tower - decreases steering into corner
In JQ: Front - Lowering the front link on the tower will increase steering into the corner.
Not sure what to make of it. What is the correct answer; which is the more accurate setup guide?
Thanks.
The lower link will soften the front, numb out initial steering, but increase it mid turn in most cases (IMO). So they are both kind of right, but lacking some details. Don't forget the Hudy guide is for on-road, which is based on high grip and not sliding around on dirt. Quite a few things in the Hudy or XXX-Main guides won't transfer to off-road directly.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 10-03-2013, 10:13 AM   #5343
Casper's Avatar
Trader Rating: 34 (100%+)
Hudy has an offroad tuning guide for there 8th scales which I think most are referencing here.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-03-2013, 03:29 PM   #5344
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Check this out guys. This gives an excellent representation of what raising (lowering roll center) and lowering (raising the roll center) the camber link mounting point does to the interaction between suspension and chassis. http://www.youtube.com/watch?v=tWdRQaz_Xq8
I believe that there is more actual camber gain to be had by changing the link length as opposed to the inner mounting height, although I haven't tested this or checked it in my CAD mockup. I might have to do some actual measurements this evening.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 10-04-2013, 09:41 AM   #5345
I have searched this thread up one side and down the other and found the question asked but no responce along with no starting point in the manual or in build tips. Here it goes and hope for the best.....
But what is the measurement from center to center on the shock for front and rear. I am a strong armed person and is well known for overtighting things especially plastic. If I know the starting point I can do the rest. Right now the shocks sit at 89mm ft and 105mm rear.
Thanks,
David "Tiny" Johnson
Tiny J Mods
Jammin_Xtream49 is offline   Reply With Quote
Old 10-04-2013, 10:31 AM   #5346
Casper's Avatar
Thanks,
That sounds about right. Now back off the eyelets from there for extra droop if you are using the latest Dunford setup.
Old 10-05-2013, 02:49 AM   #5347
racene1's Avatar
Trader Rating: 27 (100%+)
Default 2.0 Chassis for sale out there?
I am looking for a 2.0 chassis (if the price is rite) that someone might be getting rid of when they upgraded to another brand. I have a post in the wanted ad section but i don't look there much and figured this might be better. PM
TLR 2.0 chassis only please, PM me your price
JT
JT
Las Vegas, NV
702 RC Raceway; Just off the Strip Come check it out!
racene1 is offline   Reply With Quote
Old 10-05-2013, 01:04 PM   #5348
SCTE 2.0 on carpet
I'm learning carpet.
I had lots of roll issues when I started. Almost needed training wheels!
So far, shocks all in on towers, all out on arms. 30F/27.5R oil. Black front, silver rear. Still rolled.
Then I focused on sway bar. I'm at 2.4 front. Still not tight enough. Once I went 2.0 back it felt really good.
Diffs are 5/15/3. Might try 7 in the front.
Droop is critical. Work on this all by itself. Test, adjust and test some more. Really amazing its effects and often overlooked. I tried all in to all out. For me, I went all in and then turned them back 3 threads. Just spending time on this allowed speed into turns without rolling (after the above was done).
Curious what other people think of this or what else I could try that works for you
braderb is offline   Reply With Quote
Old 10-07-2013, 09:55 AM   #5349
kingofcool999's Avatar
Anyone got a cure for jumping nose down?
*** THIS SPACE UNINTENTIONALLY LEFT BLANK ***
kingofcool999 is offline   Reply With Quote
Old 10-07-2013, 10:30 AM   #5350
rcgod's Avatar
What's your setup including pistons/oil/springs and ride height?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 10-07-2013, 10:58 AM   #5351
move battery back?
Old 10-07-2013, 11:17 AM   #5352
Make sure your suspension is not binding and that your down travel is ok for the surface you are running it on.
Then either turn down the drag brake or keep the throttle on
or
Make the ride height in the front higher if you don't mind changing the handling of the truck some.
The truck does not naturally jump nose down, being its 4wd, the drivetrain and how power is or is not used will drastically affect the attitude of the truck in the air.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 10-07-2013, 11:50 AM   #5353
Battery - Mid Position
Shock Oil - 30wt
Shock Pistons - MIP #7 bypass w/white valve (compression softer than rebound)
Springs - Kit
Ride height - approx 3/4-1"
Old 10-07-2013, 11:51 AM   #5354
Originally Posted by rob4448585 View Post
move battery back?
Tried battery back, but didn't have much of an effect.
Old 10-07-2013, 11:56 AM   #5355
or
Suspension articulates freely and the shocks are limiting down travel.
I don't use drag brake. Keeping throttle on during flight didn't seem to do much. I did try adjusting ride height, but I think I was sprung too lightly.
I would have tried a stiffer front spring, but I left them at home...
