Like Tree4Likes
Old 09-26-2013, 05:17 PM   #5311
TCCustoms's Avatar
Originally Posted by rob4448585 View Post
i'll take a set for free to try.
Good Luck...when they were in the prototype stage i offered to give feedback if they would hook me up on a set and that didnt happen
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 09-26-2013, 05:25 PM   #5312
Trader Rating: 15 (100%+)
I wonder if there is any advantage from one wheel to another? As far as flex goes I mean mostly. I wouldn't there is much difference from one to another but I'm going to order 10 pairs so I'll be stuck with whatever I get for a while.
Tommygun1 is offline   Reply With Quote
Old 09-26-2013, 07:33 PM   #5313
TCCustoms's Avatar
from 1 brand to another there IS A BIG difference in the flex but to stay the same brand and same wheel they should be relatively close...
Someone did a write up and i think it was for the 1.0 on the different rims available(avid sabertooths, proline f-11s, jconcepts hazzards and i think 1 more for the truck and compared weight, flexiblilty, and a few other things
Old 09-26-2013, 08:30 PM   #5314
XXXDad's Avatar
Trader Rating: 195 (100%+)
Exclamation You can run DE 17mm SCT rims with this setup.
Nice product... pair them with DE 17mm hex rims and your golden! You can also run 1/8 buggy rims for practice or to run your lightweight 2.0 in E Buggy indoors. Just add a 810 Buggy body.
Originally Posted by m2cracing View Post
Mitch from M2C RACING here.
I made this kit so you guys could run the buggy tires in the yard or where ever.
my question is that I need to know if this kit is what you guys need.
I have hear of guys using the larger axles from the 10-t .
If you want something else that will make it better. let me know as these have been
selling quite well all of a sudden.
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 09-27-2013, 02:55 PM   #5315
Trader Rating: 17 (100%+)
Subscribing. Loved this truck after 1 night of racing with it. Switched from the 1.0 to this one.
Snafujg is offline   Reply With Quote
Old 09-28-2013, 06:21 PM   #5316
Anyone try RCSHOX
V2 losi SC 2 stage shock pistons, 4 pistons and 4 washers?
For 2.0?
braderb is offline   Reply With Quote
Old 09-28-2013, 07:52 PM   #5317
Trader Rating: 120 (100%+)
Does anyone know the part # for the Jammin front shock tower (or one similar) that is made to accept the losi 8ight 2.0 front shocks.
B6D
B64D
Tekno EB410
JoeC is offline   Reply With Quote
Old 09-29-2013, 06:15 AM   #5318
TCCustoms's Avatar
Had these on my 1.0 with the 8ight shocks and fit great
http://www.snrgraphite.com/index.php...ex&cPath=13_14
Old 09-29-2013, 06:30 AM   #5319
which nut driver size do I need for this kit?
Thanks!
B0tt0mline is offline   Reply With Quote
Old 09-29-2013, 06:39 AM   #5320
Thanks!
You can get by with just a 1/4" nut wrench, but will need .05, 1.5, 1/16", 5/64" and 3/32 hex wrenches.
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 09-29-2013, 08:55 PM   #5321
glock man's Avatar
Hey guys. I have a few questions about Dunford's new new set up.
Question #1 On the notes for the front suspension; They read 0 insert on front outer and 0 insert on front inner. What does this mean?
Question #2 What does full plus shock eyelets 2 turns mean?
Question #3 can some one clear this up. " rear hex spaced out 0.5mm. will have witness marks on front of arms and steering links. dremel acoudrinly"?
this notes are for the rear suspension and I don't really understand this. Pics would be great thanks guys.
TLR 22, TLR TEN SCTE 2.0, XXX-SCT, Xray B4, AIRTRONICS, TEKIN, ORION
glock man is offline   Reply With Quote
Old 09-29-2013, 11:01 PM   #5322
Casper's Avatar
Trader Rating: 34 (100%+)
1: these are the front pivot inserts. You want the zero inserts all around. This gives 15 deg kickup.
2: Do not use the droop screws. Let the shocks limit down travel. Screw the eyelets all the way onto the shock shafts and then back them out 2 full turns for extra droop.
3: We used 5X7 shims and placed them between the bearing and the axle pin for the hex on the rear end. This moves the hexes out .050 to widen the rear end slightly.
For the front end we raised the link on the spindle and as a result depending on the toe settings you have the wheel may rub on the steering link of the front of the arm. If you notice rub marks on either of these parts dremel the part slightly until you don't see a mark from the wheel anymore.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-30-2013, 09:02 AM   #5323
I wonder if a shorty pack (or light pack like the orion weight tranfer battery) would work well indoors? Or have I been smelling too much CA glue?
Old 09-30-2013, 09:09 AM   #5324
maddog9's Avatar
Trader Rating: 29 (100%+)
You would most likely run into run time issues as well as puffing a pack.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 09-30-2013, 10:14 AM   #5325
Thank you for the reply, that's a good point. So I checked how many mah's my battery took after running the main yesterday and it was 3003 mah. The shorty I was thinking of getting is 4600, I think the shorty would be ok mah wise. I need it for my buggy anyways so I'll try it in the 4wd and see.
