Like Tree4Likes
Old 09-15-2013, 09:13 PM   #5206
kingofcool999's Avatar
Originally Posted by sanny632 View Post
Hey guys/Casper my center diff out drive seem to be sloppy. Well actually the front center drive shaft looks a bit bent and my truck had a horrible vibration. So I pulled the center diff and the out drive seem to move side to side
Well 24 hrs no ones suggestions so ill add details.
I had a 1.0 sold it because Its cheaper just to buy one of these. Rather than upgrade. Well I bought a used scte 2.0 that's in good shape the previous owner put the Tekno center drive shafts on ( are these better?) I noticed the front one has a slight bend. Well if I apply throttle it creates a horrible vibration. I started to follow it from the center drive to the center diff. The center diff out drives seem to be rather sloppy in how much they move. I noticed that the diff bearing mount to the plastic case. Unlike the eight 2.0 I have the diff out drive goes into the bearing. Has any one else noticed this?
Don't know about the tekno drive shafts, but I do know that the out drives are a bit sloppy on all the diffs. It's normal. Mine were sloppy from day 1. If your out drive appears sloppy because your bearing that supports the diff is shot, that's another story. I had a rear diff support bearing go out and melt the insert in the gear box. That made the slightly sloppy out drive appear very sloppy. I'd check the bearings on the center diff, straighten the center drive shaft, then see how it looks...
*** THIS SPACE UNINTENTIONALLY LEFT BLANK ***
kingofcool999 is offline   Reply With Quote
Old 09-15-2013, 09:20 PM   #5207
Originally Posted by ctuinstra View Post
Tire balancing; is it worth it?
I balance mine. I have an old prop balancer and a roll of adhesive back lead tape from the golf shop. Is it worth it? IMO it is since it doesn't cost much in time or $. You might notice a little smoother look to the vehicle on the fast parts of the track.
Old 09-15-2013, 09:41 PM   #5208
seabass17's Avatar
Trader Rating: 40 (100%+)
FYI guys if you are thinking about purchasing a BCE chassis Builtrc is currently offering them authorized by BCE!! them here is a link to the eBay store. If for some reason you prefer not to use eBay they can be purchased directly from Builtrc.com. He ships FAST!! Get one while they last as they will sell quickly!!
http://item.mobileweb.ebay.com/viewi...d=171124365522
http://www.p1hobbies.com
http://www.vpprousa.com
http://www.builtrc.com for all your hobbywing needs!
seabass17 is offline   Reply With Quote
Old 09-15-2013, 10:11 PM   #5209
Trader Rating: 15 (100%+)
I should have asked this a long time ago, but what exactly does it mean "full plus 2 turns" when referring to shock length? Does it mean thread the eyelets until threads aren't showing then OUT 2 turns or IN? I figured out but now thinking about it, it's probobly in.
I think I'm missing something with my setup (shock length or droop?). My truck appears to roll over or go up on two wheels easier than most trucks when going through high speed sweepers. These are also usually rutted turns around here. I basically run the stock setup with 26mm ride height. Any advice?
Where do the shims go on the rear to space it out 5mm, just under the wheel? Looks like the only place they could go?
Tommygun1 is offline   Reply With Quote
Old 09-16-2013, 12:14 AM   #5210
eddomak's Avatar
I am no expert on setup, but had that problem whenever I went to new Calibers with too much grip. Dropping ride height to 24mm (front and back) solves it until the tyres wear and lose some traction, then I can go back up to 26mm. Hope this helps.
Losi SCTE 1.0 - BCE Chassis, Hobbywing SCT Pro, Hobbywing XERUN 3656SD 4000KV, Hitech HS-7955TG
TLR 22T - Orion R10 Pro, Turnigy 10.5T 3250KV
Axial SCX10 Honcho | Traxxas Mini Summit VXL | Losi Micro Desert Truck | Tamiya Boomerang
Airtronics/Sanwa MT-4 | Flysky GT3B - Custom firmware
eddomak is offline   Reply With Quote
Old 09-16-2013, 06:03 AM   #5211
sanny632's Avatar
Trader Rating: 17 (100%+)
Got it fixed... The bearing that holds the diff is good but I went to king headz (my lhs...lucky). His front and rear center diff mounts are amazing. Thanks Jim!!
sanny632 is offline   Reply With Quote
Old 09-16-2013, 06:08 AM   #5212
Purdue Engineer's Avatar
Screw the shock ends on as far as you can then back off 2 turns (full plus 2 turns) or one turn.
It's .5mm You have to buy a cluch shim kit and use 2 .25mm shims per side. They go between the outer hub bearing and the drive pin on the rear axles.
Purdue Engineer is offline   Reply With Quote
Old 09-16-2013, 07:08 AM   #5213
Default Indoor/Carpet Setup Sheet
hey Casper - Ryan, you guys have a setup sheet for indoor/carpet for the 2.0? or could you point out some changes we could make to the current setup sheet.
thanks.
jay_959 is offline   Reply With Quote
Old 09-16-2013, 08:19 AM   #5214
That's a good point. I'm relatively new to offroad so my tires are newer. It seems to do it with any tire I try. I was running blockade fronts and holeshot rears. Worn blockades in front might be better. The track is difficult though in that there are some very tight "Z" 180 turns in the infield.
Thanks. I knew they were .5, I just wasn't thinking lol. I got some .2 shims they will have to be close enough for now.
Old 09-16-2013, 09:03 AM   #5215
Grandturk's Avatar
Kyosho sells a combo pack of shims, .1, .2, .3 for a couple of bucks. Buy a few. You'll use them somewhere.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 09-16-2013, 12:34 PM   #5216
Can I get a part number for the shims used in the center dif and the alum dif inserts?
I just want the shims only.
The manual says LOSB3570, but when I search for that part number a spur gear comes?
ByronM is offline   Reply With Quote
Old 09-16-2013, 12:56 PM   #5217
There is no part number for just the shims. They come in two parts, the spur gear for the nitro TEN series cars or the alum rear inserts.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-16-2013, 01:08 PM   #5218
Ok. Thanks. In that case, can you point me to a reasonable facsimile? Again, just for the shims.
Thank you.
Edit: I found these-kyosho #96646. Looks like they will work.
Old 09-18-2013, 04:16 PM   #5219
TCCustoms's Avatar
Dunno if anyone posted this...
King Heads Upper Steering Plate
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 09-18-2013, 04:58 PM   #5220
cttech455's Avatar
I like it
cttech455 is offline   Reply With Quote
