Like Tree4Likes
Old 08-09-2013, 06:50 PM   #4846
Originally Posted by ta_man View Post
A less expensive alternative for diff locker fluid:
I actually got a bottle for much less in an auction listing (he starts the auctions at one cent).
Interesting, but they don't give any ratings on the viscous. I wonder if it's a lot like this:
rcplanet.com/Associated_Silicone_Diff_Fluid_100000cst_p/asc5459.htm
ctuinstra is offline   Reply With Quote
Old 08-09-2013, 07:12 PM   #4847
BmainStar's Avatar
1 million diff fluid?????What evaaaaaaaaa............Truck is on rails never better ,,,,5-5-5-!!!!!!!!!! wanna lock down the diffs????? Run ON n Raod!!!!!!!!!..! LOL ....LOL LOL LOLK TRUCK IS HOOKED!!!!!!!!! NONE BETTER!!!!!!!!!!!!!!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 08-10-2013, 05:52 AM   #4848
Originally Posted by hacker07 View Post
Hey guys, just wanted to let you know we have a new part up on the TLR site for the SCTE 2.0. Some of you have asked for it for a bit and with the release of the 2.0 and the way the front chassis brace mounts, we finally felt it was a good part to offer.
It is an Aluminum Top Plate or front triangle as I usually call it and it will suffice to stiffen up the front end a little and helps steering be a bit more accurate.
It is already in stock.
http://www.tlracing.com/Products/Def...odID=TLR331008
Will this new part also fit the new 8e 3.0. Thanks
tripleh is offline   Reply With Quote
Old 08-10-2013, 09:16 AM   #4849
Casper's Avatar
Trader Rating: 33 (100%+)
Guys. The 8ight and the Ten platforms DO NOT SHARE PARTS other than screws.
Losi has made of of these for the 8ight for a long time.
http://losi.com/Products/Features.aspx?ProdId=LOSA4440
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-10-2013, 09:18 AM   #4850
vito's Avatar
I built it may have not ran it yet need a esc and raido gear so sad
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 08-10-2013, 09:26 AM   #4851
weavty1's Avatar
On backorder
Damn lol
Tylor "with an O" I can levitate birds. No one cares.
TLR 22 2.0 RM / TLR 22 2.0 MM / TLR 22-4 / TLR 22T / TLR 22 SCT / TLR SCTE 2.0 / TLR 8IGHT-E 3.0 / Team Losi XX-4 WE / Team Losi XXX-4 G+
weavty1 is offline   Reply With Quote
Old 08-10-2013, 11:37 AM   #4852
skrichter's Avatar
Send a message via AIM to skrichter
Originally Posted by Casper View Post
Two things. If you are doing this on a towel or high friction surface the tires may have too much friction to slide and return to ride height. This is why you see most poeple check ride height on a plexiglass setup board or on a glass counter top. Second make sure you don't have the sway bars or the top shock nuts too tight which can bind up the shocks
What I have realized, is the top/tower shock bushings stays are causing the binding. The rear shocks are at somewhat of an angle (from the arm to the shock standoff). With the stock shock bushings/stays, its causing the shock not to be able to free.
I decided to drill out a 22 shock bushing (to fit over the stock screw), and now the shock is ALOT more free on compresssion.
Curious if anyone else is using a different shock bushing (on the tower).
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 08-10-2013, 12:05 PM   #4853
Frank L's Avatar
Trader Rating: 148 (100%+)
SNR makes a nice CF top plate.
http://www.snrgraphite.com/index.php...products_id=66
Old 08-10-2013, 12:51 PM   #4854
Derry's Avatar
Trader Rating: 27 (100%+)
What's up with the front torque rod being out of stock everywhere?
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 08-10-2013, 08:27 PM   #4855
Casper's Avatar
You just need to make sure you don't over tighten the upper shock nut. This is true for all RC that use a plastic upper shock bushing. You don't need to crank these down. The stock ones work great.
Old 08-10-2013, 09:01 PM   #4856
idswass's Avatar
So after watching the 2.0 Horizon Hobby video I had a question. Are the spindle blocks the same on the 2.0 and only the caster blocks are different. I hope so because I have $40 aluminum spindles on my SCT. After hearing them talk about the improvement in weight transfer while turning I want that. I have always felt there is too fine of a line on rear traction while in a turn on the 22 SCT. I hope I will only need a $12 caster kit.
idswass is offline   Reply With Quote
Old 08-10-2013, 10:21 PM   #4857
Casper's Avatar
New caster and spindles.
http://www.tlracing.com/Products/Def...odID=TLR234006
http://www.tlracing.com/Products/Def...odID=TLR234007
Old 08-11-2013, 01:40 PM   #4858
BmainStar's Avatar
Another fun night with the 2.0!!!!!We ran 4wd buggy at the same time cuz not enough sct show up lately!It was a real fun race ,ended up 2nd between 2 buggies!!!Love the truck guys!!!!!!!!..p.s. Am I hearing rumors of an SCTE based Rally car??????????
Toy Car Playerz
West Coast
Old 08-11-2013, 03:29 PM   #4859
JasonR/C's Avatar
The rumors better be for a 4wd buggy not a rally car. Oh and I'm sitting in first in my wed and sat points series with this truck! Dominating. Love it
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 08-11-2013, 06:39 PM   #4860
What other bodies are you running on your SCTE 2.0? I tried a Proline body and I really like it, it seems to be much thicker than the original; however this Proline body requires a lot of trimming around the wheels to get it to fit and it still doesn't fit all that good. It was designed for the Slash and SC10 and listed the SCTE.
