Like Tree4Likes
Old 08-09-2013, 11:31 AM   #4831
tc5 man's Avatar
Originally Posted by hacker07 View Post
Hey guys, just wanted to let you know we have a new part up on the TLR site for the SCTE 2.0. Some of you have asked for it for a bit and with the release of the 2.0 and the way the front chassis brace mounts, we finally felt it was a good part to offer.
It is an Aluminum Top Plate or front triangle as I usually call it and it will suffice to stiffen up the front end a little and helps steering be a bit more accurate.
It is already in stock.
http://www.tlracing.com/Products/Def...odID=TLR331008
Hum im pretty sure that would work on the 1.0 also ? Do you think it would make the Front end to stiff running on dry outdoor tracks ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 08-09-2013, 12:03 PM   #4832
Casper's Avatar
Trader Rating: 33 (100%+)
It will work with the 1.0 as well. No I don't think it will make the front end too stiff.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-09-2013, 12:11 PM   #4833
vito's Avatar
is there a locker to the center diff?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 08-09-2013, 12:13 PM   #4834
Grandturk's Avatar
Originally Posted by Wildcat1971 View Post
I hate to take the top plate off to do something, i forget,. All I remember was the 20 minutes it took to get it back in place and bolted up. I might just glue it in place and call it done.
I usually keep the top plate in place. I remove the two screws in the steering posts (carefull not to lose the bearings), the bolts holding the torque rod to the chassis, and the screws holding the steering links to the spindles. Easier that way, IMO
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 08-09-2013, 12:18 PM   #4835
Casper's Avatar
Not for the Ten series at lease from TLR. Not sure if anyone else has come out with something.
+1
Old 08-09-2013, 12:23 PM   #4836
Grandturk's Avatar
Silly putty
Old 08-09-2013, 12:34 PM   #4837
Casper's Avatar
This is just the first one I found in a google search but 1,000,000 diff fluid can be spooned in as well!
http://www.spec-r.com/default/index....roducts_id=345
Old 08-09-2013, 12:39 PM   #4838
skrichter's Avatar
Send a message via AIM to skrichter
Curious...
For anyone who raises their vehicle up to maximum travel (just so the tires are about to not touch the surface), does your vehicle compress back down to ride height (when you let it go gently -- not like you would do if you were to check ride height)?
I'm not sure what's going on. I drilled out all the arms, everything feels free, but when I get the shocks back on the truck, they don't seem to compress, rebound as one would think. Not sure if the weight just isn't there to settle it back down to ride height (like a buggy would be)?
Maybe the piston/oil pack is too great for this to occur?
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 08-09-2013, 12:50 PM   #4839
hkrob's Avatar
Trader Rating: 18 (100%+)
Originally Posted by skrichter View Post
Curious...
Maybe the pack is too great for this to occur?
I had a problem with my rear hubs rubbing the rod ends. This was from running the hubs all the way back.
hkrob is offline   Reply With Quote
Old 08-09-2013, 12:55 PM   #4840
skrichter's Avatar
Hubs rubbing the rod ends? You are going to have to explain a bit more.
They are back to point wher the tie rod ball cup/rod end is causing friction at full compression/extension?
Old 08-09-2013, 01:33 PM   #4841
hkrob's Avatar
Yes the rubbing was causing inconstant ride height & problems similar to the one you described.
Old 08-09-2013, 01:46 PM   #4842
Trader Rating: 20 (100%+)
Dakotah Phend and the TLR SCTE 2.0 will his winning setup be posted
xxxtruck is offline   Reply With Quote
Old 08-09-2013, 02:40 PM   #4843
Casper's Avatar
Two things. If you are doing this on a towel or high friction surface the tires may have too much friction to slide and return to ride height. This is why you see most poeple check ride height on a plexiglass setup board or on a glass counter top. Second make sure you don't have the sway bars or the top shock nuts too tight which can bind up the shocks.
I think they are still working on this. Are you looking for his nats setup from last weekend?
Old 08-09-2013, 04:28 PM   #4844
I am still trying to get it but I think he was running the latest setup I posted.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 08-09-2013, 06:30 PM   #4845
ta_man's Avatar
Trader Rating: 151 (100%+)
A less expensive alternative for diff locker fluid:
http://www.ebay.com/itm/Traction-Goo...item19dfebe66b
I actually got a bottle for much less in an auction listing (he starts the auctions at one cent).
ta_man is offline   Reply With Quote
