Like Tree4Likes
Old 08-07-2013, 09:56 AM   #4801
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Kakenballs View Post
The shock shafts are 2 full days old which are newly rebuilt by billy & running indoors. So if your saying billy cant build shocks right then I'm lost here. The o-ring is the tlr low friction gray o-ring! Will be posting pics of shocks just to show! I don't use the boots but cant see this being the problem here......
If you don't use the stock parts then any problems you may have are up to you to solve. I know that sounds kind of harsh but the reality is the stock parts work and don't leak. As Ryan pointed out the 22 o-rings are not designed to work with the SCTE shock. Just because they have the same shaft diam does not mean the rest of the stack and o-ring compression are the same. I also in no way ever stated Billy or any of those other guys you listed don't know how to build a shock but if you are going to use other o-rings to try and free up your shocks from what little sticktion the stock o-rings have then leaking is a possiblity. That is a tradeoff you need to make. I for one love that my stock shocks don't leak at all and can live with what ever slight extra fiction may exist.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-07-2013, 10:01 AM   #4802
I have been using these TLR SCTE 2.0 shocks for a while now on some of my other kit and I can assure you they are some of the best in the biz and never leaked. They may even out perform the 13mm Team Associated shocks that I use as well. However it is imperative that we follow the correct build steps using the suggested parts.
Sivaaji is offline   Reply With Quote
Old 08-07-2013, 10:39 AM   #4803
Trader Rating: 15 (100%+)
Do they make a tool to screw in the plastic part that goes on the end of the shock body?
Tommygun1 is offline   Reply With Quote
Old 08-07-2013, 10:54 AM   #4804
Casper's Avatar
No but if they are not going on easily then you need to contact Horizon CS and get replacements! The inital shipment had bad lower caps.
Old 08-07-2013, 01:14 PM   #4805
Oh.....cool thanks. That was the only issue I had building the kit so it's nice to know they fixed it. I'll just get some from the lhs sometime.
Old 08-07-2013, 01:30 PM   #4806
The ones you buy may have the same issue if they have had their stock on the wall for a bit. Go ahead and call and use the callback function, they should get back to you quickly and get you set up.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 08-08-2013, 03:16 PM   #4807
Thumbs up
Thx for your time on this Ryan & Casper. I found that the o-ring I used was the wrong one in my 2nd pair of shocks & I do understand why the team guys are using the low fricton. So Ive gotten the right o-ring now & will be rebuilding them for use this weekend.
Kakenballs is offline   Reply With Quote
Old 08-08-2013, 05:26 PM   #4808
Trader Rating: 20 (100%+)
Default Sway Bars
Why are the sway bars not right for this SC? I'm not the only one who have this issue either.
Putting Tyler's new 2.0 together and front sway doesn't go all the way into the links like they are supposed to. The bends are too narrow and rub the edges of the diff housing. The two mounts that bolt on actually bind the bar up too with the set screw out. Not sure if rear is same. I just got truck and started the build and run across this issue with the front bar. Everything else is good so far and really like the plastic quality.
TIA
Randy
RandyJones is offline   Reply With Quote
Old 08-08-2013, 05:28 PM   #4809
Trader Rating: 35 (100%+)
TIA
Silly question maybe, but any chance you have the front and rear bar switched?
kazuaki is offline   Reply With Quote
Old 08-08-2013, 05:44 PM   #4810
Purdue Engineer's Avatar
Hay Randy,
I asked about this also a while ago. The bar does not go all the way through the rod end. Set the truck at ride height like normal the make the link that connects the arm to the bar straight up and down. That's it. Front and rear are the same.
Tyler said you guys were going to get one. I talked to him at AMS. I was with all the JCP guys. Can't wait to see him wheel that thing. If you have any other questions just PM me or Tyler is friends with me on facebook. I've been on the thread since it started so I'm up to date on the changes and setup info on this truck.
Purdue Engineer is offline   Reply With Quote
Old 08-08-2013, 07:02 PM   #4811
Default ticn?
are the ticn shock shafts and hinge pins that are now standard material on the 3.0 and 22 2.0 going to be available for the scte 2.0?
ben1692 is offline   Reply With Quote
Old 08-08-2013, 08:00 PM   #4812
Originally Posted by miket3 View Post
ok. took pic for u tonight.
That feels the best for me and i have tried everything on this trk.
Okay, where the heck did you get that ultra slick boot! That thing it very cool! No better way to keep out the dirt!
ctuinstra is offline   Reply With Quote
Old 08-08-2013, 08:04 PM   #4813
Yes, mine came with the kit. It's one of the two black tools that came with the kit. It wasn't obvious at first, but there is a molded wrench in the tool.
Old 08-09-2013, 05:25 AM   #4814
Truck is done except mounting ESC!! Only issue was front sway bar. Everything else went good!!
Nope, sway bars weren't switched. Rear fit awesome!
Purdue,
I figured that's what I would do with it.
Randy
Old 08-09-2013, 07:06 AM   #4815
Integra's Avatar
That tool is for the Shock Body.
