Like Tree4Likes
Old 08-04-2013, 09:12 AM   #4741
kingofcool999's Avatar
Originally Posted by maddog9 View Post
Its a boot. I run an hot bodies boot over the drive shaft end and i grease the pin up
Got a part no. on that boot?
*** THIS SPACE UNINTENTIONALLY LEFT BLANK ***
kingofcool999 is offline   Reply With Quote
Old 08-04-2013, 09:17 AM   #4742
Casper's Avatar
Trader Rating: 33 (100%+)
Flip your side guards. One has a relief cut in it so the motor mount fits right.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-04-2013, 11:07 AM   #4743
hkrob's Avatar
Trader Rating: 18 (100%+)
Default Bearing Issues
Bearing Issues
My rear gear box pinion bearing has gone out for the 2nd time. First set of bearings lasted about 10 races this last set only make it through 4 race days and some practice. Running a hobbywing 4700kv anyone else run this motor or a Tekin 4300HD having this problem. I never had this problem with my tekin 4600 or Schuur Speed 4800.
I have a set of Avids that I am going to install we'll see how long they last.
hkrob is offline   Reply With Quote
Old 08-04-2013, 12:37 PM   #4744
Trader Rating: 20 (100%+)
Default What I should know?
Making the transition into SC. Any weak links to watch for? Do you install the shim behind the big gear inside the diffs or leave them out like we do on the 1/8 scales? Tyler is excited to give it a try.
Randy
RandyJones is offline   Reply With Quote
Old 08-04-2013, 12:53 PM   #4745
Looks like Dakotah Phend just wrapped up the the National Championship in 4x4 SCT with his SCTE2.0, congrats!
Jedev is offline   Reply With Quote
Old 08-04-2013, 12:58 PM   #4746
darkstar1974's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Derry View Post
I did... I put most of it together last night. ordered the 2.0 braces. I heard the plastic ends are the weak link. The part number for them is the whole brace. Can I just buy the plastic ends to have as spares? If so what part number am I looking for? Is there a more heavy duty option for the plastic ends from a different company or perhaps off the 8th scale buggy? And yes I know to screw the set screw all the way into the plastic to make them last longer.
I've broken 2 of these ends on the rear brace already. They are definitely weak.
Josh Spiewak
TLR * Horizon Hobby * Fantom Racing * Pro-Line * Spektrum * Cruizin with RC's * CR Graphics
darkstar1974 is offline   Reply With Quote
Old 08-04-2013, 03:08 PM   #4747
Casper's Avatar
Make sure you thread the set screw all the way into the plastic before you screw it into the alum strut. The plastic ends last longer this way.
Old 08-04-2013, 06:06 PM   #4748
Trader Rating: 42 (100%+)
Default rear brace
miket3 is offline   Reply With Quote
Old 08-04-2013, 06:08 PM   #4749
Originally Posted by miket3 View Post
there is a fix for this.
1- get a kings head long alum rear chassid brace for the 1.0 trk. You dremel or grind about 1/8" off the front and it bolts right in. Just trim a little and test fit.
Never break again.
pics?
rob4448585 is offline   Reply With Quote
Old 08-04-2013, 07:41 PM   #4750
skrichter's Avatar
Send a message via AIM to skrichter
When steering to the left, I cannot seem to get full throw. The steering knuckle is about a few millimeters away from getting to the caster block.
When I turn up my EPA higher, it appears the steering tie rod (for the servo) bumps up against the drag link -- not allowing the full throw. (Steering to the right does not cause this concern b/c the steering tie rod goes away from the drag link.)
Anyone else experience this issue?
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 08-04-2013, 07:56 PM   #4751
tc5 man's Avatar
I run a torque Rod on the Rear end on my 1.0 SCTE its not screwed in maybe not quite in all the way but i never broke the ends on them.
One other thing is to check the screw and nut that goes underneth the chassis it can get loose and could break the ends if you dont tighten it up so check it .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 08-04-2013, 07:59 PM   #4752
tc5 man's Avatar
Im willing to bet its the inside hole on the Losi servo arm that is causing it i couldnt get the steering tie rod to stop hitting againest the servo case . So i been using the Outside hole on the Losi horn no issues with that.
Old 08-04-2013, 08:09 PM   #4753
skrichter's Avatar
I don't think that's the issue -- the rod end is still going to be at the same location on the bellcrank. I've actually dremeled down the rod end a bit to get a little more clearance before it hits the drag link. But it still won't give me full throw to the left...
I really don't want to dremel down the drag link to allow more clearance (making it weaker).
Old 08-04-2013, 08:40 PM   #4754
Trader Rating: 15 (100%+)
For those running big, outdoor, low-traction, dusty, dirt tracks, where are you liking your droop set? Are you setting with the droop screws or shocks? thanks for any advice
Tommygun1 is offline   Reply With Quote
Old 08-04-2013, 08:53 PM   #4755
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I am running full droop. the screws just barely touch at full extension. no limiting inside either.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
