Like Tree4Likes
Old 08-01-2013, 09:14 AM   #4726
Derry's Avatar
Trader Rating: 27 (100%+)
can I use the 2.0 front brace on the 1.0?
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 08-01-2013, 09:21 AM   #4727
I am sorry but it is too long and would crash into the center diff.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 08-01-2013, 11:39 AM   #4728
mxgregg's Avatar
Trader Rating: 32 (100%+)
Get a new BCE H1 chassis and you can!
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 08-01-2013, 12:40 PM   #4729
skrichter's Avatar
Send a message via AIM to skrichter
When are we going to see a molded brace for the 2.0 for us med/low grip racers????
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 08-01-2013, 01:30 PM   #4730
xxfile's Avatar
Went past my LHS last week to order some M4 Calibers for the 2.0 and was horrified to learn they are discontinued!!!!!!! so I asked him to get M3's and hes not able to get them either... Proline still has m3's on their website but the M4 is gone......
we people in the north and East that dont have sugar coated concrete NEED these tires!!!
I just DID order 4 pairs from AMAIN where the m4's were still in stock..... getem while they're hot kids
xxfile is offline   Reply With Quote
Old 08-01-2013, 07:46 PM   #4731
Panda-PR's Avatar
Casper/Ryan
Do you think the new servo mount/top brace for the 8ight e 3.0 will fit the scte 2.0? It's regarding the receiver box. TLR241004
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 08-02-2013, 01:21 AM   #4732
egobrkr's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Panda-PR View Post
Casper/Ryan
Thay said in the 8ight 3.0E thread that none of the parts interchange with the scte only some screws will work.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 08-02-2013, 03:10 AM   #4733
Is SCTE 2.0 and SCTE MIP same car geometry wise if MIP has same shocktowers than 2.0.
I have MIP and it has weird problem when driving 180degree corner. In the last 1/4 of curve when you are accelerating out car kind of hooks and turns much more than you could anticipate.
It feels like inner rear wheel lightens up too much and rear diff cant transfer torque to outer wheel and when car settles and inner inner wheel gets good contact with track it like pushes car and it turns too much.
What to do to prevent that? I have quite basic setup. piston nr 3 all over and 30W oils. I have medium swaybars F/R. Running height is about 26mm F/R
Front has soft springs and rear medium.
I have tried quite many setups but without good results.
Diff are something like 10/7/3. I have to check reardiff because it feels like empty (New diffs installed)
I have tried different kickups and rear toe settings too.
Do you make 0 rebound for shocks with bladders? I have 0 rebound.
Bigbearfin is offline   Reply With Quote
Old 08-02-2013, 03:34 AM   #4734
maddog9's Avatar
Trader Rating: 29 (100%+)
Sounds like you have a case of diff whip as the tekno guys would say. Basically your rear diff oil is too low. Try going to 5000 in the rear. The MIP towers are different then the 2.0 scte towers.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 08-02-2013, 08:15 AM   #4735
Casper/Ryan
The no box servo mounts are identical between the two. As far as fitting the servo mount with the receiver box, it might fit with some dremeling, meaning the screw holes line up perfect to the chassis, but the sideguard gets in the way on the SCTE 2.0. So you could likely get it to fit with dremeling if you really feel you need a receiver box.
-Ryan Dunford
Old 08-02-2013, 09:50 AM   #4736
Derry's Avatar
I did... I put most of it together last night. ordered the 2.0 braces. I heard the plastic ends are the weak link. The part number for them is the whole brace. Can I just buy the plastic ends to have as spares? If so what part number am I looking for? Is there a more heavy duty option for the plastic ends from a different company or perhaps off the 8th scale buggy? And yes I know to screw the set screw all the way into the plastic to make them last longer.
Associated B64D
Associated B6D
Old 08-02-2013, 05:40 PM   #4737
Panda-PR's Avatar
thanks!!!
snake pit:
Old 08-04-2013, 02:40 AM   #4738
Originally Posted by XXXDad View Post
What is that orange band on your coupler joints??
SCTE - Pro4 @ RX8 on KH chasi
krits is offline   Reply With Quote
Old 08-04-2013, 07:09 AM   #4739
maddog9's Avatar
Its a boot. I run an hot bodies boot over the drive shaft end and i grease the pin up
Old 08-04-2013, 08:11 AM   #4740
seabass17's Avatar
Trader Rating: 40 (100%+)
Losi Rod End Set (15) (Ten-T)
[LOSB4023]
Low Price: $5.49
There are spares in this kit
http://www.p1hobbies.com
http://www.vpprousa.com
http://www.builtrc.com for all your hobbywing needs!
seabass17 is offline   Reply With Quote
