Like Tree4Likes
Old 07-23-2013, 01:17 PM   #4666
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Casper View Post
There are some 1.0 specific parts like the chassis braces and stuff and the 1.0 carbon towers are different than the 2.0 were we added some shock mounting and some more camber link holes.
Is the rear hopup/extended brace for the 1.0 the same as the stock rear brace on the 2.0?
I really like the KingHeads aluminum sleeve and rubber boot for the front and rear driveshafts. Boot keps the grease in and dirt out, and if the joint wears, the sleeve keeps the pin from blowing through the plastic retainer.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 07-23-2013, 01:21 PM   #4667
Casper's Avatar
Trader Rating: 34 (100%+)
I really like the KingHeads aluminum sleeve and rubber boot for the front and rear driveshafts. Keeps the grease in and dirt out, and if the joint wears, it keeps the pin from blowing through the plastic retainer.
No. I believe the 2.0 is a little longer.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-24-2013, 06:59 PM   #4668
egobrkr's Avatar
Trader Rating: 26 (100%+)
Anyone know if you can use the o-ring that are in the bottom of the the 22 shocks in the 2.0 shocks? I am using the low friction o-rings in my 22b and wanted to know if and how they would work in the scte.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 07-24-2013, 07:43 PM   #4669
TCCustoms's Avatar
only 1 way to find out...
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 07-25-2013, 01:03 AM   #4670
nanoverse's Avatar
You need a 1mm spacer in there.
HB E817 | HB D815e | HB D413
Hitec Lynx 4s
nanoverse is offline   Reply With Quote
Old 07-25-2013, 05:20 AM   #4671
egobrkr's Avatar
You are right!
Old 07-25-2013, 05:23 AM   #4672
egobrkr's Avatar
It looks like it will work if I use the bottom cap and insert from a 22. I just wonder why tlr used the o-ring that's in the scte shocks and not the ones that come in the 22.
Old 07-25-2013, 09:26 AM   #4673
The build that is in the SCTE does not leak and lasts a very very long time. 4WSC is a class where a lot of people set their cars up and then run the crap out of it without much maintenance. So, we chose to stay with this setup.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 07-25-2013, 09:48 AM   #4674
egobrkr's Avatar
I agree it works well. I just got the 22b and put the low friction o-rings is and it feel much smoother then my scte shocks when new. I didn't know if it would work or not. I just like how smooth the 22b shocks were. Just wanted to know if it could have been another tuning option.
Old 07-25-2013, 09:59 AM   #4675
skrichter's Avatar
Send a message via AIM to skrichter
Describe a bit more please:
First use the LOSB2906 (stock) shock hat
Then a Low friction oring
Then TLR5090 hat washer
Finally TLR5086 shock cap
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 07-25-2013, 11:04 AM   #4676
egobrkr's Avatar
I'm on my phone so can't look up all those part numbers but if they are all the stock 22 parts for the bottom of the shock then yes. I am going to try it tonight or tomorrow and see if it works. I have spares of everything to try this. I will post back if it works.
Old 07-25-2013, 01:39 PM   #4677
Trader Rating: 35 (100%+)
A lot of us are using 22 low-friction O-rings in the SCTE shocks. The easiest way to do this is to just replace the stock O-ring with a 22 low-friction O-ring and a 1 mm spacer. You can get the perfect spacer as part of TLR5096. So the combination of the 22 O-ring and the 1mm spacer take the place of the stock O-ring. All other parts remain the same.
kazuaki is offline   Reply With Quote
Old 07-25-2013, 01:56 PM   #4678
egobrkr's Avatar
That's it? That's easy. No leaking problems with just 1 o-ring? I will give it a try.
Old 07-25-2013, 01:58 PM   #4679
Yep, it has been discussed many times on the SCTE V1 thread. I haven't noticed any leaking, although I would expect the seal will be less durable. I would expect to do rebuilds more frequently, but most racers do that anyway.
Old 07-25-2013, 06:53 PM   #4680
egobrkr's Avatar
The 22 bottom shock caps do not work on the scte shocks.
