Like Tree4Likes
Old 07-17-2013, 10:46 PM   #4621
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by hkrob View Post
Ran Ryans new setup last Friday TQ & 1st place win. Only thing i changed was the front springs I am running blue springs.
http://www.youtube.com/watch?v=aGAAtW7I88A
Good looking race. Good job.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-18-2013, 02:08 AM   #4622
egobrkr's Avatar
Trader Rating: 26 (100%+)
Was the track wet? How did you like the 575 diff oil vs what you used before?
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 07-18-2013, 02:21 AM   #4623
RapidRC's Avatar
I've got a Viper VTX8 and a VST4.5XL on the way and am now finding out that the SCTE 2.0 is too heavy for that motor. Is there anyone here that has used that motor in their trucks?
MBX7, MBX7eco, Slash, B5M.
JCP raceway.
RapidRC is offline   Reply With Quote
Old 07-18-2013, 07:02 AM   #4624
MonsterSummit's Avatar
Trader Rating: 15 (100%+)
Not sure who told you that motor wouldn't work. Not familiar with Viper specifically, but I run a Thunder Power 550can 4.5T 2-pole and its great. I actually prefer it over the 4300HD and 4600 Tekin motors I have. I am geared 13/40, but have also ran 12/40. All I did was add a little top end timing and this thing is awesome. Temps have yet to be over 140-150. Everyone finds it hard to believe that they are getting beat by a 2-pole motor. I've had to pull my lid off just to prove to people it is a 2 pole. I think everyone(myself included) has had it put in their head you have to run 4-pole motors and 2-poles are junk. To some maybe this is the case, but I strongly recommend anyone to drive a 2-pole just to try it if nothing else.
MonsterSummit is offline   Reply With Quote
Old 07-18-2013, 07:19 AM   #4625
blade329's Avatar
Trader Rating: 114 (100%+)
+1 Nice video.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 07-18-2013, 07:26 AM   #4626
egobrkr's Avatar
I have a guy that uses that viper system in his tekno and it is quick. I use novak 4.5 550 2pole and I love it! It is a 5000kv and I am at 14t pinion and 25deg of top end timing. I love gearing a 550 low and jacking up the timing. You will be happy with that system. It is a 4400kv I believe so I would say a 14t or a 15t pinion would be close to a good gearing on it and up the timing to get the speed.
Old 07-18-2013, 07:46 AM   #4627
Using a 14-15t pinion with the stock(40t) spur is not gearing low at all. Most common pinion size would have to be a 14(with 4-pole 4600ishkv motors) unless you run the new 4300HD, then going up to a 16t pinion is fine. From my experience 2-pole motors do not have a lot of low end to them which is why you gear them low and turn the timing up to achieve the top end you want. I would NOT start with a 14-15t pinion with a 4.5t 2-pole, you are just asking for trouble. I am at a 12-13(currently a 13t) and it is equally as quick if not quicker than 4600's and 4300hd's on big outdoor tracks. IMO, Kv ratings on a 2-pole motor are arbitrary numbers anyway.
With that being said, to each his own and if it somehow works for you then don't fix whats not broken. My point being I just do not think it is a good idea to start with such a high gearing(14t or greater pinion) with a new motor esc combo.
Old 07-18-2013, 07:49 AM   #4628
hkrob's Avatar
Trader Rating: 18 (100%+)
hkrob is offline   Reply With Quote
Old 07-18-2013, 07:56 AM   #4629
hkrob's Avatar
Track was damp and starting to dry out. I really like 5/7/5 in the diffs been running that for awhile 5k in the rear really locks it in. I was running 5/5/3 it worked good I just prefer the heaver fluid. I have also ran 10k in the center diff it's fast but harder to drive.
Old 07-18-2013, 08:36 AM   #4630
egobrkr's Avatar
You are right. At my track I felt the 14t pinion low because my temps where under 100deg after a 8min race. It had plenty of torque but no top end. Then I started messing with the timing and that woke up the motor. Right now at that gearing and 25deg of timing I come off at 6mins at 135deg and 8mins 170deg. The temp really shoots up as the lipo gets close to cut-off. I used a 6800mah lipo once for an 8min main and came off at 145degs. So yes at the op's track that could be a hot gearing. I have raced on smaller track with my setup and the temps where a tad higher do to more breaking. They where about 155-160 on a small track.
Old 07-18-2013, 10:30 AM   #4631
I used too love my track star 4T 2 pole motor . 2poles are so much smoother. Has a more controllable power band. It's not too snappy.Plus it doesn't beat the snot outta your batteries.
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 07-18-2013, 04:15 PM   #4632
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Another win for the 2.0
http://www.liverc.com/news/race_resu...8LiveRC.com%29
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 07-18-2013, 05:33 PM   #4633
RapidRC's Avatar
Thanks for the positive feedback on the 2 pole motors. Now I'm looking forward to seeing what it will do. What length sensor wire am I gonna need for this?
JCP raceway.
Old 07-18-2013, 06:18 PM   #4634
275mm sensor wire will fit good (gives a bit of slack also)
Rich D is offline   Reply With Quote
Old 07-18-2013, 06:34 PM   #4635
ballnM3's Avatar
Trader Rating: 39 (100%+)
Default RX8 Gen2 Switch
Used one of the silver screws that came with the RX8 Gen2 and screwed through the hole in the switch and then in the battery stops. Seems like it will be a good spot for it and pretty secure. We shall see though...
ballnM3 is offline   Reply With Quote
