Like Tree4Likes
Old 07-14-2013, 09:21 PM   #4561
Frank L's Avatar
Trader Rating: 148 (100%+)
On small tracks 13t is more than enough. Otherwise the motor can get very hot.
Old 07-14-2013, 09:27 PM   #4562
Will dropping from a 14 to a 13 tooth pinion make a significant difference in temps or should I maybe order a 12t pinion as well?
87MagnumII is offline   Reply With Quote
Old 07-14-2013, 09:44 PM   #4563
Frank L's Avatar
I went from 15 to 13 and temps in a 6 min heat went from 190's to 150's. On the same type of smaller track. Btw speed was not effected, I think it improved my lap times.
Old 07-14-2013, 09:51 PM   #4564
Ok, good deal. I'm gonn go from 14 to 13 and I just ordered a 12 just in case. I hope this is all that's wrong because this thing was getting HOT and it was getting that way FAST!!
Old 07-15-2013, 06:42 AM   #4565
hkrob's Avatar
Trader Rating: 18 (100%+)
Originally Posted by vito View Post
will 300 buy a esc and rx and servo?
You should be able to get what you need for $300.
Hobbywing SCT-PRO esc $90
A good servo like a hitec 7955 or futaba bls351 $120-150.
hkrob is offline   Reply With Quote
Old 07-15-2013, 07:52 AM   #4566
Casper's Avatar
Trader Rating: 33 (100%+)
Spektrum S6040 is only $70. It is what most of the team uses to steer the SCTE.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is online now   Reply With Quote
Old 07-15-2013, 08:09 AM   #4567
vito's Avatar
esc will be a rx8
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-15-2013, 08:11 AM   #4568
esc will be a rx8
well the answer is NO then.
You gave a $300 budget then used $220 of it for an ESC.
Its not difficult to look up prices of parts.
$70 servo and $220 est = $10 for a RX.
rob4448585 is offline   Reply With Quote
Old 07-15-2013, 08:23 AM   #4569
vito's Avatar
thanks
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 07-15-2013, 08:33 AM   #4570
Originally Posted by maddog9 View Post
Truck was better with 2mm spacer. Running 2 hole pistons 32.5 and 30. Max kick up everything else the same as current dunford setup. The car is awesome off power steering but as soon as i roll back onto the throttle the car wants to spin out. What changes can i make. Should i go lower rear shock oil? Should i go to higher rear diff as the tekno guys refer to this as diff whip
You may want to try the whole new setup. What you are describing is the issue with the 2 hole piston setup that we found. And the diff oils we run are very important to locking in the rear end.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 07-15-2013, 09:09 AM   #4571
reckboy's Avatar
Probably. You could get a tenshock motor/ ESC combo for about $150. That would leave you sitting pretty to pick your servo and radio equipment. I run a skyfly gt3b which was about $35 ( radio and rx). Extra rx is about $7. There are lots of choices for adequate servos from $15 to over $100... Folks here seem to be in love with savox 1258tg which costs around $70. I have had decent luck with hitec myself.
-Losi Mini 8ight | Losi Mini Crawler | Duratrax Evader Brushless | Losi Ten-SCTE
reckboy is offline   Reply With Quote
Old 07-15-2013, 10:22 AM   #4572
maddog9's Avatar
Trader Rating: 29 (100%+)
I am running 575 diffs with the 2 hole setup, with max kickup everything is the same minus the 4 hole pistons.
maddog9 is offline   Reply With Quote
Old 07-15-2013, 10:26 AM   #4573
max kick will give you more steering out of a corner, this is one reason we moved to the lower kick and the toe settings. Just something you may want to try. The front kick is pretty quick to change (if you have some L pick or something, lol).
-Ryan Dunford
Old 07-15-2013, 10:48 AM   #4574
MonsterSummit's Avatar
Trader Rating: 15 (100%+)
The new setup he just put out goes back to 0 all the way around on the front. And just any FYI Maddog, I would try the whole setup. It may or may not have been the setup that tq'ed and won Saturday at the OEOSS...
Granted the same setup doesn't work for everyone, but I was like you, where I "thought" I liked the 2-hole better.... Not anymore
MonsterSummit is offline   Reply With Quote
Old 07-15-2013, 11:16 AM   #4575
goehm's Avatar
Trader Rating: 44 (100%+)
Based on history, I would say that it doesn't matter what you respond with, trust me - these questions are all hypothetical, the path is chosen.
Now that that's said..
OrangeRX DSM2 receivers are $10 from HobbyKing (prob $16 w/ shipping), a bit under $20 on EBay. He mentioned possibly using a Spektrum SR300 which is only DSM and a bit pricier (new and used). So the $300 price point seems achievable.
Making the OrangeRX adjustment, combined with what everyone seems to want to run in this truck, the order would look like this:
$219 RX8 GEN2 (or $180 for a first GEN)
$71 Savox 1258TG or Spektrum 6040 Servo
$20 OrangeRX GR300 RX
will put him right at $310 delivered to his door.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
