Like Tree4Likes
Old 07-12-2013, 08:47 AM   #4531
Originally Posted by mxgregg View Post
So lowering the inside steering link and raising the outside gives less bump steer?
What we are trying to do is overcome a shortcoming with the steering geometry. Typically, a vehicle has bumpsteer, but it typically means that as the suspension goes up, the wheel will steer out. Then you can adjust to go as far as keeping the wheel straight on most cars.
With the SCTE, the bump is IN, which is not good. What these changes do is make it so it stays straight.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 07-12-2013, 09:12 AM   #4532
mxgregg's Avatar
Trader Rating: 32 (100%+)
Thanks for all the help!
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 07-12-2013, 11:06 AM   #4533
maddog9's Avatar
Trader Rating: 29 (100%+)
For the 2mm spacing take one of the squares from a diff, its exactly 2mm just drill the hole a little bit with a hand drill so that the screw fits in.
maddog9 is offline   Reply With Quote
Old 07-12-2013, 11:16 AM   #4534
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by anr211 View Post
Is there supposed to be a 2mm washer under the inside and the outside ball? The bumpsteer column is cut short and I'm not sure.
I added the "*" to take you to the notes section were we state to add a 2mm ball stud washer.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-13-2013, 11:19 AM   #4535
hkrob's Avatar
Trader Rating: 18 (100%+)
Ryan or Casper can you guys post Dustin Evans sheet up sheet from the Top Gun Shootout at San Diego RC Raceway. Thanks
hkrob is offline   Reply With Quote
Old 07-13-2013, 11:59 AM   #4536
Sorry for twisting this, it's related tho. I can't seem to get any info on the setup sheets y'all post. I get the sheet but no data. On my pad and my smart phone..is it user? Or software?
fullpull is offline   Reply With Quote
Old 07-13-2013, 12:15 PM   #4537
hkrob's Avatar
The sheets show up on my iPhone but some times they wont work on my PC.
Old 07-13-2013, 01:55 PM   #4538
nanoverse's Avatar
Use the Adobe Reader app.
HB E817 | HB D815e | HB D413
Hitec Lynx 4s
nanoverse is offline   Reply With Quote
Old 07-13-2013, 07:11 PM   #4539
vito's Avatar
will 300 get my kit all done need a esc servo rx and the motor hook up.
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-13-2013, 07:20 PM   #4540
vito's Avatar
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 07-13-2013, 08:26 PM   #4541
I'm new to the LSR SCTE 2.0, high-end RC cars for that matter, and have a few quick questions on the setup. I'm currently building the kit and I'm going to use leftover electronics from my son's Redcat car. The motor is a 3750KV, so it's a bit underpowered compared to what most of you are running, and that may be just fine to start off with. I'm thinking the pinion is going to have to be something along the lines of a 13T or less. I'm wanting to order them today or tomorrow and I was thinking of getting maybe 12T, 13T, and 14T. Does that sound about right for this motor? We will be racing on an indoor clay track that is medium size tight track with some big jumps. I plan to run Proline Suburbs or possibly Gladiators or Calibers (medium). Thoughts?
ctuinstra is offline   Reply With Quote
Old 07-13-2013, 08:59 PM   #4542
vito's Avatar
esc will be a rx 8 and servo I don't know yet rx will be a sr 300?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 07-14-2013, 12:16 AM   #4543
nanoverse's Avatar
It uses mod1 pinions? More along 15-16.
Try it but make yourself a favor and get some electronics better suited for this like the Hobbywing 4000kv combo.
Hitec Lynx 4s
Old 07-14-2013, 01:23 AM   #4544
Suspended
Trader Rating: 7 (82%+)
Hey guys has any one broke a rear brace on the scte 2.0 I broke one today is there anythink u can do to get a alum one to fit the back race brace
RavensNightFury is offline   Reply With Quote
Old 07-14-2013, 05:33 AM   #4545
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
If Suburbs work at your track then the Gladiators and Calibers probably won't be so swell. They are both outdoor, rough, loose track tires. Try a Panther Rattler in clay or a JConcepts Pressure Point in soft or super soft. Can you sauce the tires? If you can, a good diesel bath the first time and then pretty much any decent tire sauce will make a big difference. I've had good luck saucing just the inside half of the tires on my SCTE as well. Adds some traction but keeps the traction rolling in the corners down. Hope this helps.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
