Like Tree4Likes
Old 07-11-2013, 01:55 PM   #4516
Default witness marks
Originally Posted by hacker07 View Post
Hey guys, well, we said we would keep working on it some and boy have we figured some stuff out. You will have plenty of traction and plenty of steering with this one or at least should. A couple things, its hard to find space on the sheet to place more notes. This setup fixes the poor bump in condition the truck has, that is why you can run toe in and it doesn't do weird things.
-you will see witness marks on the front of the arms where the wheel turns in further now and on the steering links. Just dremel those until you get no new witness marks, doesn't take much.
-You want to use metal washers under the outer steering link balls for the additional 2mm of shimming.
Hey Ryan, What are you referring to when you say "you will see witness marks on the front of the arms" where exactly are you dremeling?
crazyhog is offline   Reply With Quote
Old 07-11-2013, 02:02 PM   #4517
Casper's Avatar
Trader Rating: 33 (100%+)
The plastic rod end will hit the rim with raising the link on the spindle. A little dremel on the plastic rod end were it rubs gives some clearance.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-11-2013, 03:07 PM   #4518
Thanks Casper
Old 07-11-2013, 03:26 PM   #4519
Originally Posted by Purdue Engineer View Post
Ryan,
I see casper is running those same ESC numbers for timing with the 4600. is that correct that I could run those same numbers with my 4600?
What difference will I see in performance with running the timing at 35 and changing the start and end curve to those RPM numbers?
Thanks for all your work.
Regarding the PM from a while ago, I'm waiting for my wife to schedule her next trip
On the 4600, I like 14/41 gearing actually. on that motor, casper and I have been playing with starting the timing even lower. Whatever the next option below the 3000 range is. He seemed to like it.
A witness mark means that you will see on the front of the arms and on the turnbuckle ends that the wheel is rubbing some. You just want to dremel it a little and run again, keep doing this until you see no witness marks or at least very faint ones.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 07-11-2013, 05:31 PM   #4520
I have a question about something I can't seem to figure out, when my truck turns too much the cvd on the outside wheel will start binding and lockup entirely, is this just going to happen with too much steering and should I turn down my epa's or is there something I'm missing?
Voloc is offline   Reply With Quote
Old 07-11-2013, 06:59 PM   #4521
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Goldin Info
Setup works great. You do not need to remove the front droop "pad/screws" with this setup. that is only needed if you run max front kickup. This setup goes back to 0/0 settings and the screws can be left in place. Since we are not using the droop screws it does not matter if they are there or not though so....
Turk, The primary major issue with the steering on the SCTE is that when the tire travels up, it bumps IN, this is a big no no and makes for a vehicle that is inconsistent under braking and under landing. What these changes do (learning from the 8 3.0), help us be able to get the car to land better, steer in and out of a turn, and brake better. Overall, the car is more consistent. The reason we lowered the amount of front kick is to get more turn in, now that we could go to some toe in, to get the steering out of the turn for a more balanced steering and vehicle.
The outer ball always has to be run ball up so this is how we left it but placed an additional 2mm metal washer under it. We used the ones from the 22 line and just held them with pliers as we drove the screw through it, lol.
I am running my motor pretty hard but it is known I apparently don't pull as hard as most as I can run an identical car as others and come off a little cooler, so just putting that out there...lol. Always check temps during your test runs.
I am geared 16/39 with the pro4 hd 4300.
timing - 35
finish - type in 17500
start - of the options, choose the one in the 3000 range
current limit - 75 (I played with this a lot, more than 75 with this motor produces wheel spin and lower lap times)
brakes - 100 in esc, 37 on radio
minimum throttle - 1
I think those are the important ones...
DISCLAIMER!!!!!
Using advance timing with 4 pole motors is harder on your batteries. AMP draw has gone up and the batteries are getting warmer. Make sure you have good batteries if you attempt to add timing to your 4 pole motors.
We are getting better top end out of the motors with additonal timing. We are ramping it with a pretty low start so you don't feel any kick in and have it ramp fairly quick so you get some benefit on short shoots as well. Gen 2 Data logging is showing these things are pulling over 30,000 RPM so you see full advance timing for most of the top end of the motor range.
Thanks guys Great info here!!!
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 07-11-2013, 08:46 PM   #4522
Casper's Avatar
Something is wrong. That should not happen even at full throw. Take the axles out and make sure everything is ok. The pin hole is not too worn or the pin is not worn etc. Make sure the CV joint is clean and lubricated.
Old 07-11-2013, 08:54 PM   #4523
Casper's Avatar
Posted the latest setup in .pdf for easier reading on my web site.
www.casper-rc.com
Direct link.
New Setup
Old 07-11-2013, 09:40 PM   #4524
www.casper-rc.com
Direct link.
New Setup
Can't thank you enough for sharing what you learn.
I have only had my 2.0 SCTE for less than a month, and sharing what you have learned has allowed me to 'tune' my car (aka, copy your setup) and really appreciate driving these trucks.
Thanks so much, and can't say it enough.
rob4448585 is offline   Reply With Quote
Old 07-12-2013, 12:57 AM   #4525
It comes two wasy. One precut with all the vents the other without the vents cutout (stock)
http://www.tlracing.com/Search/Defau...rm=performance
Are these the same original thin lexan bodies or have they been updated with the thicker lexan yet?
Jedev is offline   Reply With Quote
Old 07-12-2013, 04:29 AM   #4526
www.casper-rc.com
Direct link.
New Setup
Is there supposed to be a 2mm washer under the inside and the outside ball? The bumpsteer column is cut short and I'm not sure.
anr211 is offline   Reply With Quote
Old 07-12-2013, 05:30 AM   #4527
MonsterSummit's Avatar
Trader Rating: 15 (100%+)
Yes. You put the flange side down on the outside ball then add a 2mm washer. Had a different, but similar question earlier myself.
MonsterSummit is offline   Reply With Quote
Old 07-12-2013, 07:54 AM   #4528
Thumbs up
Put a 2mm washer under the outside ball ONLY
Rich D is offline   Reply With Quote
Old 07-12-2013, 07:56 AM   #4529
The bodies you can purchase are now the thicker bodies.
it is just under the outside ball as the inside ball is captured between two plastic flanges and cannot be spaced other than flipping the ball whichever way.
-Ryan Dunford
Old 07-12-2013, 08:11 AM   #4530
mxgregg's Avatar
Trader Rating: 32 (100%+)
So lowering the inside steering link and raising the outside gives less bump steer?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
