Like Tree4Likes
Old 06-30-2013, 10:05 PM   #4336
Originally Posted by Wildcat1971 View Post
ran my scte 2.0 this weekend. Ir drove well, but I cant seem to stop the leaking in the front and rear diffs. The center holds fluid fine. The diff screws seem pretty soft also. Who makes a harder steel diff screw for the scte in a hex, not philips.
Search for part# HPI Z449
Jedev is offline   Reply With Quote
Old 06-30-2013, 10:22 PM   #4337
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
those are 2.5x12mm screws. The losi are 2.6x10mm, will that be an issue?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-30-2013, 10:28 PM   #4338
Old 06-30-2013, 11:14 PM   #4339
ran my scte 2.0 this weekend. I drove well, but I cant seem to stop the leaking in the front and rear diffs. The center holds fluid fine. The diff screws seem pretty soft also. Who makes a harder steel diff screw for the scte in a hex, not philips.
This is what i did to prevent any leaks in the diff.
Items used:
APE bushing and shims
Protek 2.5x10mm countersunk screws
Noleen sf-3 (green slime)
HD diff cases
Diff oring from rebuild kit
I bought the truck used and opened them up to find that I had two dry diff's and one half filled. They were built with HD cases.... the stock shims had deformed into oval bowls which was probably why my fluid leaked out.
I started out the rebuild by diping the oring into the green slim and placed it into the insert in the HD cases. Then I moved onto the shim and wiped a little green slim grease on the side of the shim that contacts the oring. I then dip the planetary gear side of the out drives and just slip it in and out of the HD case to lube and seal any gaps up. Do the same for the other out drive then proceed with the pin install. Use the ape shim and the bushings then fill the diff up but not all the way up. Leave room so you can place the other planetary gear without overflowing the diff fluid. I find that if you over fill and you begin to screw on the top the pressure will push out the green slim and you will jonlonger have that seal. I used the protwk screws and they work just fine no stripping. After you seal up the diff check to see if you see and diff fluid pushed out or leaked out. If so you over filled the diff with fluid and have to restart and reseal it with green slime. Doing so should net you with a leak free diff for a very long time.
dirty_rooster is offline   Reply With Quote
Old 07-01-2013, 03:42 AM   #4340
maddog9's Avatar
Trader Rating: 29 (100%+)
I would sand down the pumpkin side to take off any burrs on the diff case. Make sure you put some grease on the grooves of the out the outdrive cups and make sure your o-rings are fully seated. Easiest way to get a consistent fill and this is how ryan lutz does it....fill the diff up with your oil with the bottom gear in and your 4 spider gears(make note that you DO NOT have shims in the spider gear assembly) fill it to top of the spider gears and place the top gear on and the oil should bleed through the top gear and you simply wipe across the backside of your top gear then place your top on with your gasket in place. For the screws get a MIP wrench and start to screw them down almost in a cross pattern.
maddog9 is offline   Reply With Quote
Old 07-01-2013, 03:54 AM   #4341
Frank L's Avatar
Trader Rating: 148 (100%+)
Looks about the same as the truck above it.
Old 07-01-2013, 07:04 AM   #4342
vito's Avatar
Originally Posted by vito View Post
dose the wheel wells look line up the body is a tad back.
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-01-2013, 08:29 AM   #4343
Frank L's Avatar
The 2.5x12 screws work well just remember thay are a tiny screw and don't over tighten them.
Old 07-01-2013, 08:39 AM   #4344
Just make sure the front of the body is behind the front bumper if not the body wont last long. The wheels make it look like it should move forward but you need to keep it behind the bumper.
B-FAST R/C Performance|TLR 2.0|TLR 22 SCT|Schuurspeed
tekinACE is offline   Reply With Quote
Old 07-01-2013, 08:39 AM   #4345
vito's Avatar
thanks
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 07-01-2013, 08:45 AM   #4346
Grandturk's Avatar
Originally Posted by mxgregg View Post
Fresh paint on my SCTE. Looking to run the new BCE 2.0 chassis!
What body is that? It's pretty cool looking.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 07-01-2013, 10:47 AM   #4347
looks like hpi skorpion body.
(Team Rifles) USS Chung Hoon DDG-93
Paul Pierce is not a hall of famer, not even close.
Sierrahotel is offline   Reply With Quote
Old 07-01-2013, 11:14 AM   #4348
mxgregg's Avatar
Trader Rating: 32 (100%+)
Yes it is. It's really wide and no issues rubbing.
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 07-01-2013, 12:28 PM   #4349
XXXDad's Avatar
Trader Rating: 195 (100%+)
Arrow 17mm hex and rims
Check out my Sale of 17mm hex and Rims upgrade your 1.0-2.0 to 17mm hex
you can also run buggy rims for practice or make the ultimate lightweight 1/8 scale
TLR SCTE 17mm Hex Adaptors and Rims
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 07-01-2013, 01:17 PM   #4350
tbills66's Avatar
Proper way to rebuild diffs. I followed this procedure and have had zero issues with the diffs leaking.
http://losiracing.blogspot.com/2013/...uild-tips.html
tbills66 is offline   Reply With Quote
