Like Tree4Likes
Old 06-26-2013, 09:07 AM   #4291
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Originally Posted by Wildcat1971 View Post
yeah, only a couple use 5mm. I will look into the proteks. The TQ ones were so loose, I turned over the battery and they fell out.
We make several types of bullets for different battery mfgs. Our HD 6-point bullets #2505 are larger in diameter, have 6 points of contact and will fit tighter than the ones we've designed for packs like RevTech and Reedy that have smaller ports - this is written on the labels.
Wildcat - PM me with your address and I'll send you a set to try.
tqwire.com
ralph m is offline   Reply With Quote
Old 06-26-2013, 09:46 AM   #4292
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by vito View Post
need help what a do I need to pick up win I get my rx8 gen 2 esc the motor is a tekin pro 4 4600?
Make sure you have the right pinion. A long sensor wire as mentioned already. Also the wire you get with the ESC should reach the motor but you will probably need some extra wire for the battery connection. Also plugs for what style of battery you are using.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-26-2013, 09:48 AM   #4293
vito's Avatar
275 mm one? and I have not the right pinion its a 15 and it will be a street truck.
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 06-26-2013, 09:49 AM   #4294
Casper's Avatar
15 should work depending on how you drive it. We usually race with a 14. I don't street race my truck so not sure how it will pull that gear but I know on large flowing 8th scale tracks guys are getting away with 15's so keep an eye on motor temps.
Old 06-26-2013, 11:34 AM   #4295
egobrkr's Avatar
Trader Rating: 26 (100%+)
I need more all around steering in my 2.0. I run box setup but have front bottom shock in middle and battery all the way back and 573 for diff oil. And help would be great.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 06-26-2013, 05:51 PM   #4296
rcgod's Avatar
Trader Rating: 27 (100%+)
Try the short Ackerman link. You'll never complain about lack of steering again.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 06-26-2013, 06:40 PM   #4297
glock man's Avatar
The 275mm sensor cable fit my setup perfect.
glock man is offline   Reply With Quote
Old 06-26-2013, 06:43 PM   #4298
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
You need to do something with the connectors for the Revtech packs mine become loose after a couple runs, will the HD ones work in the revtech packs?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 06-26-2013, 06:44 PM   #4299
glock man's Avatar
What do you mean by ackerman link? sorry this might be a stupid question
Old 06-26-2013, 06:58 PM   #4300
vito's Avatar
what setting do I run in a rx8 motor is a pro 4 4600?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 06-26-2013, 07:52 PM   #4301
BmainStar's Avatar
Follow your steering turn buckles inward where they attach.You will see a semi circle metal part kinda half moon shape.
That is the Ackerman plate.You can buy the set which will include a shorter one. I run the short one as well as remove the front sway.My truck will turn like a 2-wheel drive ,Yup 180`s on a dime. This is for a small to medium size track with some tight turns. On a bigger track with big fast sweepers keep the front sway..This is not for everybody it is very quick and aggressive!!!!Cheers!!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 06-26-2013, 08:46 PM   #4302
Frank L's Avatar
Trader Rating: 148 (100%+)
Man if you can roll this truck without a front swaybar my hats off to you. IMO it makes the truck very unpredictable, but then again I'm new to the 2wd stuff
Old 06-26-2013, 09:13 PM   #4303
rcgod's Avatar
http://www.nitrohouse.com/product.as...Qgod0BcARwThis is the Ackerman link.
Dialed RC Hobbies
Old 06-27-2013, 01:44 AM   #4304
egobrkr's Avatar
During the winter when the track stayed tacky and I was using proline ions I had more steering then I needed. I had so much that I would ask other drivers if they needed some becase I more then enough to go around! Lol. Now that it is summer and the track gets dry and using a small pin tire like panther raptors, proline square fuzzies or proline tazer I have a lack of overall steering, on and of power. My track is an out door track that has a building built over it but even when its dry it still has ok grip, more then an Out door track. Are the stock steering links long enough to compensate for the short ackerman?
Old 06-27-2013, 03:42 AM   #4305
maddog9's Avatar
Trader Rating: 29 (100%+)
You dont phyically change the steering links there is 1 hole in side on each side of where your long ackerman screws in.
maddog9 is offline   Reply With Quote
