Like Tree4Likes
Old 06-25-2013, 06:26 PM   #4276
vito's Avatar
there in bag I
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 06-25-2013, 06:28 PM   #4277
glock man's Avatar
Thanks Casper!
glock man is offline   Reply With Quote
Old 06-25-2013, 06:29 PM   #4278
glock man's Avatar
[QUOTE=Casper;12289964]For med to low bite that is a good diff setup. We have been testing higher diff fluids (7-7-5) but have been running on some really high bite lately. 5-7-5 has been what we were running the the latest posted setup.
You put shims between the diff case and the left side bearing to shim the rear diff closer to the pinion gear but make sure there is still some play as you don't want to shim too tight which is bad as well.
Ryan and I are both running the RX8 Gen 2 in our trucks and we love it.[/QUOTE
Thanks Casper!
Old 06-25-2013, 06:36 PM   #4279
vito's Avatar
need help what a do I need to pick up win I get my rx8 gen 2 esc the motor is a tekin pro 4 4600?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 06-25-2013, 06:40 PM   #4280
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Any new info on the BCE 2.0? Got my $$ ready to throw at Bill.
Losi 5ive T: Bartolone XP Pipe- Zenoah - Turlte Racing - Savox -Team Hoonage
SCTE 2.O BCE H1 HW SCT Pro/HW 4000/Savox
Feint Motion is offline   Reply With Quote
Old 06-25-2013, 06:53 PM   #4281
BmainStar's Avatar
Originally Posted by rcgod View Post
Stock setup with 2 hole #55 pistons 32.5/30, black front springs, 775 diff fluids.
Thanx,
Originally Posted by Wildcat1971 View Post
What is the part number on the shims
try these from Kyosho # 96646 12 x 15 mm shim set qty 8 price $5.99
Email him direct or order at BCESPEED.COM. rcgod is already running one and results sound great!!!Cheers!!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 06-25-2013, 08:14 PM   #4282
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Hmm, I just tried to wiggle my diff side to side and there is no play.... I am a bir concerned about binding
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-25-2013, 08:34 PM   #4283
BmainStar's Avatar
Hmmm..
when it`s apart and sitting in your hand place it in the diff housing and check it that way and if you did already try that and nada, then something is not right for sure.May need a new housing ? Def not the norm for this!!! If You can pinpoint something that is wrong Horizon may just send you some new parts.
Toy Car Playerz
West Coast
Old 06-26-2013, 06:25 AM   #4284
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Hook it up
It comes with 12g wire that should reach. But the sensor wire that comes with the motor will not work.( too short)
Depending on your Batt. you will need Deans or 4mm Bullet conectors.
60/40 Solder, Flux, a good solder iron.
Some 2 sided tape.
Make sure you have a sensor wire to reach (270mm)
14 T Pinion
Go have fun
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 06-26-2013, 07:12 AM   #4285
who makes good 4mm bullets? I thought TQ were supposed to be good, but they are trash. way too soft and loose
Old 06-26-2013, 07:25 AM   #4286
Frank L's Avatar
Trader Rating: 148 (100%+)
I have been using the protek solid bullets. They work well. Just make sure t's a solid type bullet and not the umbrella type.
On that list above I would suggest to use the kyosho zeal mounting gel [KYOZ8006]. Since I have been using this stuff I have had no issues with the rx8's
http://www.amainhobbies.com/product_...ng-Gel-1-Sheet
Old 06-26-2013, 07:27 AM   #4287
Grandturk's Avatar
I've never tried the TQ ones. I use the protec 4mm bullets. Seem to work fine. I use the "stand up" ones as they're easier to pull out. Never had a problem spreading them out if they get a little loose.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 06-26-2013, 08:12 AM   #4288
Integra's Avatar
On the topic of bullets, HOLY TIGHT wad batman,
Protek 5mm's can pick up 2X the trucks weight before the bullets pull out.
I hope other battery mfg's pick up on that and Go 5mm.
Old 06-26-2013, 08:32 AM   #4289
yeah, only a couple use 5mm. I will look into the proteks. The TQ ones were so loose, I turned over the battery and they fell out.
Old 06-26-2013, 08:38 AM   #4290
vito's Avatar
Some 2 sided tape.
14 T Pinion
Go have fun
thanks I have a 5 tooth on it
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
