Like Tree4Likes
Old 06-23-2013, 02:58 PM   #4261
hkrob's Avatar
Trader Rating: 18 (100%+)
Originally Posted by TrailblazerSS81 View Post
What size battery 2,3 or 4s??
hkrob is offline   Reply With Quote
Old 06-23-2013, 03:55 PM   #4262
rcgod's Avatar
Trader Rating: 27 (100%+)
Wink
Originally Posted by seabass17 View Post
I would encourage everyone to pick up one the new BCE chassis's I saw it in person and raced against Kevin (rcgod) last night. The usual BCE high quality. I can honestly say I saw a major improvement in his lap times. Seems to me you get the best of both worlds. Steering and jumping ability of the 2.0 combined with the ability to push the car hard of the 1.0! I had the BCE on my 1.0 and it was awesome,never bent anything and made the car amazing. Can't wait to get mine!
Thanks Donnie! Truck was dialed. Reminds me of my 1.0 with BCE chassis only better.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 06-23-2013, 04:14 PM   #4263
glock man's Avatar
Icero, I'm running a 14 tooth pinion and the stock spur. If you use an orion speed contorl update the software to a four pole.
glock man is offline   Reply With Quote
Old 06-23-2013, 04:18 PM   #4264
glock man's Avatar
i'm running a 14 tooth pinion gear seems to be working good with my setup.
Old 06-23-2013, 04:24 PM   #4265
glock man's Avatar
Originally Posted by Frank L View Post
+1 on the longer sensor cable. The 200mm is very tight.
I used a 230mm and might need longer when I install the Orion esc.
Frank I recommend a 275 mm sensor cable with your orion. it fits perfect.
Old 06-23-2013, 04:49 PM   #4266
glock man's Avatar
Are any of you racing in the short course show down series?
Old 06-24-2013, 02:17 PM   #4267
I see. I'm assuming that you are using a mod 1 pinion? Last time I raced, there was only pitch to worry about. Like I said before, some of this stuff is completely new to me.
And thanks for the help so far guys.
DA6righthand is offline   Reply With Quote
Old 06-24-2013, 04:35 PM   #4268
glock man's Avatar
Yes, you have to use a mode 1 pinion gear. sorry i forgot to mention that.
Old 06-24-2013, 06:02 PM   #4269
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
is it even worth it to replace the rear ring gear when it chunks teeth? will it just happen again?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-24-2013, 06:18 PM   #4270
If you broke teeth on the rear ring gear, something went wrong. Possibly you may need to shim the rear diff or your brakes are very high and also putting undue stress on the electronics and rest of the drivetrain. Try shimming the rear diff and all will be well.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 06-24-2013, 09:40 PM   #4271
BmainStar's Avatar
..Set up ????
I am running a hybrid set up of sorts,some things from the 1.0 and the new 22 pistons and such, still feels really good but not stuck in yet.Should have mine in a day or two and am assuming it will be the missing link I am looking for.
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 06-25-2013, 06:18 AM   #4272
rcgod's Avatar
Originally Posted by BmainStar View Post
..Set up ????
Stock setup with 2 hole #55 pistons 32.5/30, black front springs, 775 diff fluids.
Dialed RC Hobbies
Old 06-25-2013, 05:08 PM   #4273
glock man's Avatar
Hacker07, Where should we be shimming the rear diffs if having problems with ring gear teeth breaking? Just wondering, i haven't had this issue. Also i'm running 5000 wt oil in front diff, 5000wt in the drive diff, and 3000wt oil in rear diff. are there any other oil combos you recommend? ps my truck is an animal with the orion speedo. have you tested the tekin rx8 2.0?
thanks,
oscar
Old 06-25-2013, 05:38 PM   #4274
Casper's Avatar
Trader Rating: 34 (100%+)
For med to low bite that is a good diff setup. We have been testing higher diff fluids (7-7-5) but have been running on some really high bite lately. 5-7-5 has been what we were running the the latest posted setup.
You put shims between the diff case and the left side bearing to shim the rear diff closer to the pinion gear but make sure there is still some play as you don't want to shim too tight which is bad as well.
Ryan and I are both running the RX8 Gen 2 in our trucks and we love it.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-25-2013, 06:20 PM   #4275
What is the part number on the shims
